VXL Motor Questions
grob23
Kansas
First off, this will be going in a Kyosho Lazer ZX5 4x4 race buggy. It'll rarely see water (if EVER... probably never); I clean my cars after every run... I will not be racing with this. It will purely be a basher.
I'm working to put electronics into my buggy to get it going. I'll be running a Sidewinder SV2 ESC with a Velineon 3500 motor. My first question is about the "cover" on the back of the motor (that covers the board and wires). Can I run without this cover? I believe it's Novak that has an exposed board on their brushless motors, just didn't know if it's the same...
Here's a pic of what I mean by "board". I don't have the "cover" on in this photo"thumbsup"
Contrary to popular suggestion(s), I want to hard-wire my motor and ESC. I just like the look a bit more, and I don't change motors or speed controls enough to be worried about soldering/unsoldering my stuff. Is there anything wrong with hard-wiring my system?
My last question is about how the motor leads attatch to the motor. I would like to simply not use the motor leads that Traxxas supplied at all. I would just use the leads coming from the ESC, and solder them directly to the motor (see anything wrong with running like that?) Also, would it make a difference as to what side of the PCB board the wires are coming from? I'd like to turn them around if possible
ANY and ALL help will be GREATLY appreciated! Brushless systems aren't my specialty...
Thanks in advance!
-Greg
All that you've asked should be no problem at all. the cover is just a cover, As long as wires ABC are stilll ABC you can solder them anywhere. the less wire and connections means less crap for the power to flow through.
Yes to everything basically. With unsensored the "b" wire is the only one that really matters, then "a" & "c" can be interchanged for rotation choice. I ran the vxl3500 without a cover also without issue
I ran my vxl in my wraith for about a year without the cover. In mud and water. It still runs fine. I did take an old shock bladder and glued it over the bearing in the back to help keep mud/water out.
Thanks guys! Those were the answers I was hoping for
Now it's time to crack a cold one and fire up the soldering iron!
