davemud
I'm into micro RCs, I have a Losi Micro Crawler and Micro Trail Trekker. I want to get a larger truck that is the equivalent of my 2011 Norco Range
All Mountain Bike.
My first big RC needs to be able to climb technical terrain and then descend it just as well as my AM bike does. The Traxxas Summit seems like the ideal All Mountain RC but it is too big, too complicated and way too expensive.
The contenders are... not Axial... at least not new, they are too expensive and the RTRs are sold without a battery or charger. Adding those necessities in pushes the Axial "RTRs" into the Summit price range since I don't have any batteries or a charger.
Contenders are Traxxas Telluride, the Twin Hammers and althought not AM RCs the Vaterra Slickrock and Redcat RS 10. Every comparison of the Telluride and Twin Hammers against their Axial equivalent goes on about how the TT and TH are not scalers and not crawlers out of the box. These comments are not aimed at RCC specifically they are aimed at all forums and reviewers. I'm just posting it here because I'm a member here and spend much more time here than my posts suggest.
I have watched many many videos where both the TT and TH do very well and cover most of the terrain if not all the SCX or Wraith do even though they are never comparing an apples to apples setup. These comparisons also always focus on the crawling and technical terrain but almost never compare the flip side of the coin, a run at the race track where out of the box head to head the TT and TH will slaughter the SCX 10 and Wraith.
All of the RTR kits except the Rockslide, IMO for my use, require additional expense and upgrades to get them capable of doing what the average buyer wants.
The TT needs a comparable turn motor and locked diffs, the same gearing and the same size and brand tires for an apples to apples set up to compare against the SCX on as close to equal terms as possible but I have yet to see this done RC shop and website reviewers and where is that race track performance comparison footage?
The TH is usually compared against the Wraith using its 1.9 tires while the Wraith runs 2.2. How about some footage with the wheels swapped around, Wraith running 1.9 and TH on 2.2? Again though apples to apples Would be both vehicles running the same size wheel and tire set up.
Having watched a lot of videos on the TH and TH vs SCX I believe Jang at RCU when he says on the same wheel set up as the SCX 10 with the front diff locked and proper suspension set up the TH will out crawl the SCX 10 and I imagine this set up will keep up with the Wraith too.
TH and TT both come with a battery and charger.
Locking the diffs is free or a few bucks, a motor for the TT is half the cost of a decent charger a gear swap is a few bucks and tires about the cost of a battery.
For the TH I just need a good 2.2 crawler wheel set, some diff locking putty and time to learn how to set it up. I don't think the 2.2 tires are really necessary but with them its a quick swap to optimize the truck for the day.
Most shops sell Traxxas and Axial and Vaterra so why do so many of you hack on the TT for not being what the SCX 10 is or the TH for not being a Wraith? You should the make a sale either way.
All 4 of them need more money spent on them than the cost of the RTR kit, are the margins that much better on the Axials or what? I'm not trying to be argumentative here but these 4 vehicles are generally not being compared with comparable setups and the other side of the coin, the race track comparison isn't getting equal coverage and consideration either.
All Mountain Bike.
