Wraith Spawn Body Mount Mod - Cotter Pin
SteveB1
Las Vegas
Hey gang,
I can't seem to track down how some of you have installed the cotter pins to hold the body on? Is there a part that you screw into the frame, or did you just make your own?
I hate fooling with those little screws to remove the body.
Thanks for any suggestions.!
s
I made some mounts with velcro on mine. I put strips of velcro on the body to match up with the mounts I made.
I'd show a picture but I sold my Wraith.
Sent from my SM-G965U using Tapatalk
Hey here’s what I used, TRA3727
You’ll need 2, I threaded the posts into the holes for the factory screws then reamed the hole on the body out to fit.
Hope this helps!
You don’t need to use the plastic piece obviously but for $3 it’s the cheapest way I found
