03-04-2013, 08:49 PM | #1 |
Newbie Join Date: Feb 2013 Location: So. Il.
| Jeep recomendations/things to look for
I'm in the market for a jeep. I found a 92 wrangler, inline 6, 5 speed, small lift and 33's with a hard top and 140xxx miles. I'm waiting for the guy to call me back. Is there specific years to look out for? It won't be used for any hard core wheeling. Just gravel road ridin' and maybe a little puddle jumping. Nothing serious at all. |
03-04-2013, 09:24 PM | #2 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
| Re: Jeep recomendations/things to look for
Personally I like the TJ best, coils all around and I like the body lines better. They ran from 1997 to 2006. Plus they got round head lights |
03-04-2013, 09:26 PM | #3 |
Newbie Join Date: Jan 2009 Location: medford
I can't remeber for sure but I thought the 92 wrangler had the carburated 4.2 and peugot transmission? If so neither were very good. If you can find one with the fuel injected 4.0L 6 cylinder with the ax15 5 speed you are way better off. More power better fuel mileage and the ax15 is super strong for a jeep tranny. Also If you can find one with a dana 44 rearend you would be golden. The dana 35 rearend that is in most of them are prone to premature bearing failure and axle failure. Hope this helps.
03-04-2013, 09:32 PM | #4 | |
| Re: Jeep recomendations/things to look for Quote:
I am also a big fan of the tj. The only year I would stay away from is 2000 it is the first year of the nv3550 which they put behind the 4.0L. I owned one and the tranny was popping out of gear with only 14K on it. | |
03-04-2013, 09:43 PM | #5 | |
Pebble Pounder Join Date: May 2011 Location: under a bridge
Also, the 4.2 was a awesome motor! It just sucked due to having a carb on it... Sent from my HTC POS tablet using Tapatalk 2 | |
03-05-2013, 05:03 AM | #6 |
Thanks guys. I appreciate it! Most of th Tj's are way outta my price range. :( I did read onine to stay away from the peugot transmission. It said it was easy to spot because it was triangular shaped. |
03-05-2013, 07:54 PM | #7 |
Just got off the phone with the guy. The 1st person didn't buy it. So, thursday after work I'm headed to go look at it. It was an older gentleman who restores vehicles. He said he's only had the jeep a few months and that his wife talked him into buying it for her. He was vauge on the description, but said it ran good and the tires were new. No rust on the frame, all guages work and the interior is in good shape. Supposedly there is some small rust on the body. This is the only picture of it: I guess I'll find out thursday what it's like. |
03-05-2013, 10:33 PM | #8 |
Rock Crawler Join Date: Apr 2009 Location: bend
I like the 1991 with a auto trans. The frame is easy to mod for dana 60's and run air shocks. You can also get them pretty cheap.
03-05-2013, 11:36 PM | #9 |
Looks like a Sahara edition YJ. Guy didn't say what motor was in it? Mileage? Trans?
03-06-2013, 05:45 AM | #10 | |
I thought it looked like a sahara too. It's got a V6, 5 speed, with 140,000 miles. No rust on the frame. Interior is good and has the rear seat. Tires are new and all the guages work. Guess I'll find out tomorrow about 4:30 what it's like in person. It's an hour and a half away from me. | |
03-06-2013, 09:10 AM | #11 |
A V6 or straight 6? The 4.0 liter?
03-06-2013, 09:46 AM | #12 |
| Re: Jeep recomendations/things to look for I'm pretty sure they only came with a 4.0 V-6 or a 2.5 4 cyl. When I talked with the guy last night he didn't want to go outside and look. In his defense, it was late and friggin' cold here. All he did was read off the title. He's being so vauge I'm worried, but I know if I don't go look at it I will regret it. |
03-06-2013, 10:22 AM | #13 |
The internet and my old Jeep tell me otherwise. Engines 2.5L I4 TBI (fuel injected) - 121 hp @ 5000 rpm, 135 ftlb @ 3500 rpm - used in '87-'90 2.5L I4 MPI (multi-port injection) - 130 hp @ 5250 rpm, 139 ft lb @ 3250 rpm - used in '91-'95 4.2L I6 Carburated AMC 258 - 112 hp @ 3200 rpm, 210 ft lb @ 2000 - used in '87-'90 4.0L I6 MPI AMC 242 "Power Tech HO" (High Output) - 190 hp @ 4750 rpm, 220 ft lb @ 4,000 rpm - used in '91-'95 This forum has some info. as does Wiki. YJ Wrangler Stock Specs!!! - JeepForum.com Maybe you are thinking of the JK, they have a sweet bored out V6 mini van motor. |
03-06-2013, 10:57 AM | #14 |
It's a 92 and I went with edmunds specs on the one they had listed: 1992 Jeep Wrangler Sahara What's it Worth? From what you had listed the Jeep falls into the 91-95 catergory. So it's got the 4.0? I dunno. I'll find out for sure tomorrow. Oh, and thanks for the link to that forum. I will check it out! Last edited by sosume; 03-06-2013 at 11:00 AM. |
03-06-2013, 11:05 AM | #15 |
RCC Addict Join Date: May 2011 Location: Utah County
Dude stay away from that one.. Champaign color = lemon. I don't know about wranglers but on cherokees we would always look for the np231 transfer case. Sent from my SCH-I535 using Tapatalk 2 |
03-06-2013, 11:10 AM | #16 | |
How do you know you're getting the NP231 transfer case or the AX-15 transmission? | |
03-06-2013, 11:11 AM | #17 | |
I hope it's white. lol. Is the transfer case an issue if I don't plan on doing any crawling or hard core wheeling with it? I seriously doubt I ever lift it more than it is. Heck, I probably won't drive it much anyway. Maybe a couple times a month on gravel roads...... if it's nice out. | |
03-06-2013, 12:00 PM | #18 |
| Re: Jeep recomendations/things to look for Engines 2.5L I4 TBI (fuel injected) - 121 hp @ 5000 rpm, 135 ftlb @ 3500 rpm - used in '87-'90 2.5L I4 MPI (multi-port injection) - 130 hp @ 5250 rpm, 139 ft lb @ 3250 rpm - used in '91-'95 4.2L I6 Carburated AMC 258 - 112 hp @ 3200 rpm, 210 ft lb @ 2000 - used in '87-'90 4.0L I6 MPI AMC 242 "Power Tech HO" (High Output) - 190 hp @ 4750 rpm, 220 ft lb @ 4,000 rpm - used in '91-'95 Transmissions Manual transmissions AX-5 - Aisin 5-speed behind the I4 '87-'95 BA-10/5 - Peugot 5-speed behind the I6 from '87-March 9, 1989 AX-15 - Aisin 5-speed behind the I6 from March 10, 1989-'95 Automatic transmissions TF904 - TorqueFlight Automatic behind the I4 '94-'95, prior to this, the YJ was not offered in an automatic with the I4 TF999 - TorqueFlight Automatic behind the I6 Transfer Cases The transfer cases used are all chain driven with aluminum housings. NP stands for "New Process" which is the brand, if you will. NP207 - "Command-Trac" part-time only - 2.61:1 ratio low range - only in 87 NP231 - "Command-Trac" part-time only - 2.72:1 ratio low range - shift pattern 2H - 4H - N - 4L - used '88-'95 Driveshafts Axles Front Axles Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 87-95. All are vacuum disconnect, Some 95's have 5-297x u-joints due to the start of new model change over, all others have 5-260x u-joints. Rear Axles Dana 35 non c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used '87-'89 Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used '90-'95 Dana 44 non c-clip - 30 spline, 1.31" diameter shafts, 8.5" ring gear, 2.75" axle tube - used '87-'89 on a VERY limited number of Canadian YJ's. (Note with the Dana 35C- The "C" does not stand for c-clip. It stands for "custom" meaning it came from Dana unfinished.) Gearing I4 Automatic - 3.73:1 I4 Standard - 4.10:1 I6 Automatic - 3.54:1 (normally) I6 Standard - 3.07:1, 3.54:1 or 3.73:1 - must verify with the tag on the axle or by pulling the differential cover and reading the numbers stamped in the ring gear or by counting revolutions of wheel versus driveshaft. |
03-06-2013, 02:04 PM | #19 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
Check the frame very carefully. They rust out at the rear spring hanger right at the back bumper and crack beside the power steering pump. Pull the carpets and check the floor boards. The drive train will usually outlast the body. straight from my mind to tapatalk |
03-06-2013, 02:59 PM | #20 | |
Jeep recomendations/things to look for - Similar Threads | ||||
What are your recomendations? | The-Blacksheep | Axial SCX-10 | 8 | 02-05-2012 07:15 PM |
