06-06-2012, 04:56 AM | #1 |
Newbie Join Date: May 2008 Location: South Africa
| SCX10 Axled Wraith
Ok so this all started with a bee in my bonnet, googled it and dam someone else did it but oh well go ahead anyway. So i bought a second hand wraith, ripped off the axles stripped it down to the bone and started a build from ground up, cost of this build is quite extensive so we will leave that part out. Chassis: Axial Wraith Gearbox: Axial Wraith Gearing: 87/14 Motor: Axial 20T Drive shafts: rear Stock wraith front shortened scx10 Links: Front scx10 upper shafts into a 3 link setup Rear stock plastic wraith uppers and G made lowers Diffs: SCX10 rear (still awaiting straigh parts from customs) front is an AX10 diff but it is exactly the same as the scx10 front. Wheels: Mickey Thompson 1.55" super soft baja claws Rims: RC4WD steelies 1.55" Shocks: Stock wraith shocks ESC: M-Troniks viper fully waterproof Servo: TBA stock axial one glitching and causing throttle to jump when steering, tried to repair it but no good. Body: Jeep Rubi Wrangler Driver:undertaker lol till i find a better action figure. I had to shave his crotch area with the dremel to get him into a better sitting position, and then i moved the steering back a little with some nitro tubing so it made it to his hand. Front trimmed to change appearance Trimmed some of the rollcage as well still gonna do the rest Some action shots So far i am happy with the results, It climbs well has a low COG nice leaning angle great approach front and rear, Still working on the turning angle, its a bit too big for what i want, shocks are being replaced with better aluminium one for a finer shock setup. Motor will be tested but might drop it down to a 27T and well might be fitting some 1.9" on at a later stage This was supposed to be a sick build but i kinda got frustrated with it due to certain issues so its officially my basher. Considering building a second one with all the extras i was planning to put into this one... |
06-06-2012, 04:57 AM | #2 |
| Re: SCX10 Axled Wraith
can anyone tell me what class a rig like this would fall under.
06-06-2012, 06:40 AM | #3 |
Quarry Creeper Join Date: Mar 2011 Location: Universal City, TX
I would think it would be in SORCCA Class 2. Sent from my DROID3 using Tapatalk 2 |
06-06-2012, 07:14 AM | #4 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
I would try to some scx10 shocks and lower her about a inch. Preferrably the proline powerstrokes to have adjustability. If you want to stay big bore for weight go slash powerstrokes front shocks. The will cycle like no other. Good looking build. Just an opinion. Enjoy
06-06-2012, 07:27 AM | #5 | |
| Re: SCX10 Axled Wraith Quote:
06-06-2012, 10:39 AM | #6 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
Had to look at the thread, seeing "Wraith" in the 1.55 section. Great looking setup! X2 on the slightly lower ride height. Could go with some internal springs set in +/-50/50 droop. |
06-07-2012, 09:00 AM | #7 |
as the cash flow gets better i will order the chassis mount for the servo and go lower for now will have to stay high... If I go chassis mount would i have to do a panhard bar with my 3 link setup, I am a little confused about that, i read that you dont but then i read guys doing it, anyone know better lol |
06-07-2012, 10:38 AM | #8 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
In my opinion you should run a panhard and a 3 link when you mount the servo to the chassis. I used it on my 1.9 SCX axled Wraith and it's the way to go.
SCX10 Axled Wraith - Similar Threads | ||||
Wraith Axled Rigs . . . Let's see them . | INFERNAL | General Scale Talk | 13 | 12-27-2012 06:35 AM |
wraith or scx10 | kingcbell | Newbie General | 14 | 01-31-2012 11:14 PM |
r1 axled 1.9scaler? | yel98vwgti | G-Made Crawlers | 0 | 07-07-2010 12:27 AM |
WK axled BMVii | Power_Wagon | HPI Wheely King | 3 | 07-26-2008 03:41 PM |
