Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: RC4WD Trail stomper
Old 02-03-2012, 06:58 PM   #1
Default RC4WD Trail stomper
Anyone got one and have any opinions on it?
88gmchog is offline   Reply With Quote
Old 02-03-2012, 08:53 PM   #2
Default Re: RC4WD Trail stomper
might want to put another hun on the table, if you can, and get the trail finder 2. imo
Weapon is offline   Reply With Quote
Old 02-03-2012, 09:11 PM   #3
Well i just got mine but havent opened it up yet, For the money i think its a good deal. Just need hard shell toyota body.
old man 52 is offline   Reply With Quote
Old 02-04-2012, 03:57 PM   #4
Well defiantly let me know what you think of it....
Old 02-05-2012, 06:42 PM   #5
I used to have one. Very little articulation, but still very fun to drive.
Snowwheeler is offline   Reply With Quote
Old 02-08-2012, 12:12 AM   #6
Yotapane's Avatar
Location: norcal.. The real NorCal , like 400 miles north of NorCal
I found that with very little tweaking using all the original suspension the trail stomper has just as much articulation as a trailfinder with red leafs, and is much more stable. They seem to be a good little rig right out of the box......but definently get a hardbody, the lexan doesnt do these rigs justice.
Yotapane is offline   Reply With Quote
Old 02-08-2012, 12:21 AM   #7
Status...ADDICTED!
ceedawwg's Avatar
First thing you're gonna want to do is replace the stock driveshafts. Mine broke on the second run...on flat ground!
ceedawwg is offline   Reply With Quote
Old 02-08-2012, 06:14 PM   #8
same here, get an abs body for that :-)
mannyr69 is offline   Reply With Quote
Old 10-25-2012, 08:04 PM   #9
what size and what type of driveshafts
trailstomper98 is offline   Reply With Quote
Old 10-26-2012, 07:47 AM   #10
I've got one. I cut and shortened the chassis/wheelbase to fit a tamiya FJ40. It takes a little suspension tuning, and a waaay bigger pinion on the motor and it's great. I had a stock driveshaft pop off once, but even a few hours running never again. I just put it back on. It came off because one of the Ujoint pins slid half out. I just utilized a nearby rock to tap it back in and since it's been great. The transmission is very noisy though. Even adjusting gear mesh, still very loud.
RC4WD Trail Finder FJ40 - YouTube
Even after adjusting the suspension the single leaf softened up a bit after a couple hours running. It flexes a little better now.
I removed all but one leaf, took the inner springs out of the shocks, and removed the o-rings from the cup on the bottom of the shock.
makaveliks is offline   Reply With Quote
RC4WD Trail stomper - Similar Threads
rc4wd trail stomper vs scx10 based scaler mattstang 1.9 Scale Rigs 3 01-04-2012 07:36 AM
Rc4wd Trail stomper? opinions on it. JH HONCHO SCX10 General Scale Talk 11 10-10-2011 10:24 AM
