Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: travis c. built it, Rob_B perfected it, Jeremy H. and son drove it
Old 06-17-2016, 12:29 PM   #1
Default travis c. built it, Rob_B perfected it, Jeremy H. and son drove it
And I sweet talked Jeremy into selling it back to me. Thank you Jeremy!
The truck looked like it hadn't changed since it left Rob's possession, it was a bit outdated and I wanted to update it to 2016 standards.
How I received it:
I started tearing it down for the rebuild..............................
I was very surprised to find some old school CDW tranny outputs on RPP, unfortunately they were the flat spot style as opposed to pin through. Lucky for me I have a good buddy that takes pride in his machining so off to Rob B. at SMW they went to make them pin through. Thank you Rob!
That's all for now, I will update as new parts roll in. Waiting on a chassis from Y-Town in aluminum, SMW skid, SSD D60s and a few other odds and ends. Thanks for looking!
travis c. is offline   Reply With Quote
Old 06-17-2016, 03:28 PM   #2
~THE SCALE SHOP~
Default Re: travis c. built it, Rob_B perfected it, Jeremy H. and son drove it
awesome truck. got to drive against it a few times.
you lucked out and got the custom mashers too.
STANG KILLA SS is offline   Reply With Quote
Old 06-17-2016, 04:03 PM   #3
I actually have two sets of them on the same wheels!
Thanks SKSS
Old 06-17-2016, 08:24 PM   #4
Got started on the front axle, went with the SSD D60s with the XR width mod. When I tore apart the rear axle on the Sammy I found this BEAST of a spool, although I believe it may be a RCP spool, not quite sure though. I figured I'd use it in the front SSD axle to give some weight down low and forward bias.
Tranny rebuilt with the CDW outputs and the front axle.................
I had to do some custom anodizing with a Sharpie, the grey knucks and Cs weren't doin it for me, I know it looks like crap!
Old 06-17-2016, 08:30 PM   #5
Glad to see this rig still going.
Under no circumstances, should you run that stock front axle gear cover. They get hung on every little rock in front of them. I had to learn the hard way.
Szczerba is offline   Reply With Quote
Old 06-18-2016, 07:32 AM   #6
Oppan Gangnam Style
chino63's Avatar
Very nice Travis, glad you were able to get this back. Great little truck, soon to be better!
chino63 is offline   Reply With Quote
Old 06-18-2016, 09:30 AM   #7
Thanks, yeah I noticed that while installing it, the grinder should solve that problem.
EDIT: Just ordered the SSD part #SSD00092 diff cover, it's a bit different than the one you're running on the Jeep.
Thanks Dean, You should have seen my face when it arrived and during the unboxing!
Originally Posted by clodzilla319 View Post
X2 .. those little screws are A$$-holes!
Funny, I was calling them assholes while I was installing them.
Old 06-18-2016, 09:45 AM   #8
Nice!! Always liked this build, congrats Travis!
bmuzz1 is offline   Reply With Quote
Old 06-18-2016, 09:52 AM   #9
Thanks Brian, hopefully it will be able to make it back down to Az. to crawl some of the best rock in the US.
Old 06-18-2016, 05:21 PM   #10
I'm loving all of the rebuilds/refresh going on. Those cut and shut mashers bring back some memories.
Bananaclip is offline   Reply With Quote
Old 06-18-2016, 06:27 PM   #11
Unfortunately those might not be going back on it, we'll see. I do have two sets of them, one set has a 1.9 bead glued in and the other set is just a narrowed 2.2. I spent a lot of time narrowing them that the seam in virtually invisible, almost factory.
I have a chassis on the way from Jake, new body from TBG, Holmes BR-mini, Holmes handwound 35t, and some other stuff.
Thanks for all the kind words fellas!
Old 06-19-2016, 12:32 PM   #12
Rear axle ready. The internals consist of a Blue Monkey 300M spool, U.D. gears, and stock shafts for now. I'll make up the difference in width with hubs for now. Sorry for the crappy pics, I'll be upgrading my phone soon, hopefully the new one takes better pics.
I still need to anodize (Sharpie) the lockouts.
Old 06-21-2016, 09:52 AM   #13
Going to rebuild the shocks that have been on it since the beginning. Three O-rings in the shaft seal will prevent leakage, basically remove the plastic spacer and replace with an O-ring.
Decided I wasn't too fond of the rear axle not being the same width, picked up the SSD parts needed to make it XR10 width and some new diff gear covers.
I also picked up a BR-Mini to power the rig.
Old 06-22-2016, 01:07 PM   #14
Got the cage stripped and repainted flat black.
Chassis should be here soon and then I can start assembly.
Old 06-22-2016, 05:53 PM   #15
Chassis showed up today, I believe this is the first Y-Town product I have owned!
Looks very nice Jake, now time to start building!
Old 06-24-2016, 09:43 AM   #16
Starting to look like a truk.
Due to there being no holes provided for the SMW skid, I used the forward hole in the chassis for the front of the skid and had to drill a hole for the rear hoping to achieve some forward bias.
Thanks for looking!
Old 06-24-2016, 09:51 AM   #17
Oh yeah, I'm cool now since I have reached the 2000 post count.
Old 06-24-2016, 12:16 PM   #18
Did you get a blem skid? My stock skid bolted right up to the UA chassis...
Almighty Malach is offline   Reply With Quote
Old 06-24-2016, 02:53 PM   #19
No, I'm running a SMW skid.
According to my measurements the SMW skid's mounting holes are about 22.5mm, the holes in the chassis are about 39mm unless there's something I'm missing, which does happen a lot.
Old 07-05-2016, 10:15 AM   #20
Can a moderator please move this thread to the 2.2 section?
I tried building a 1.9 but the tires just look too small for me.
This build is going to be going a different direction, as much as I want to use the tubework on the new build something keeps pulling me in a different direction. I'll hopefully have some updates in the next few days.
Thank you Mr. Moderator
travis c. built it, Rob_B perfected it, Jeremy H. and son drove it - Similar Threads
Travis C's FJ45 2.2 part Deux already built thread travis c. 2.2 Scale Rigs 62 04-07-2020 10:30 PM
Built my son a functional hockey scoreboard for Xmas Mud Puppy Chit Chat 10 12-31-2013 06:24 AM
Drove into a lake... Blinkfan5150 Vaterra Twin Hammers 8 06-10-2013 03:38 PM
JEEP TJ Designed & Built with My Son Jeepin-Paul 1.9 Scale Rigs 0 05-07-2011 05:05 PM
So i drove the nylint 1/6... cartronicshn General Crawlers 14 05-25-2006 12:39 PM
