Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: 6X6X4 crawler hauler
Old 07-25-2010, 09:48 PM   #1
Default 6X6X4 crawler hauler
been working on my rig for about a month now and thought it was time to post up my progress.
initial mock-up
first link placement
it's a roller!
and the current set up for testing the suspension
the only thing I've done since the last pic is semi-droop the rear shocks so I have some down travel.
DKSnipes is offline   Reply With Quote
Old 07-26-2010, 05:02 AM   #2
Nice start!
What body are you thinking of using? Like a DAF or MB cab-over in the front for the Dakar look?
Are you getting a different caseback for the second axle so you can tie it into the third axle, or using a 1:1 transfer case mounted above them?
sweli is offline   Reply With Quote
Old 07-26-2010, 11:58 AM   #3
looks a cool project,ill be watching this one
mikef350 is offline   Reply With Quote
Old 07-26-2010, 12:03 PM   #4
put a diff in that center axle and i bet it will turn on a dime! looks good so far!
2500hdon37s is offline   Reply With Quote
Old 07-26-2010, 04:47 PM   #5
Originally Posted by sweli View Post
Nice start!
going to try my hands with styrene and build a cab-over similar to this.
i tried a thru axle with my first tandem and didn't like it so went a different rout with this rig buy making a 1:1 t-case with 4 outputs you can kinda see the shaft layout here, to drive the RR axle I have the shaft going over the FR axle to a barring support then to the RR axle, this way I can have all 3 axle inputs clocked, it works well.
thats why the RR axle can steer it gives me ruffly a 3ft turn radius vs ruffly 6ft with just the front.
