Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: 1974 Early Bronco Build
Old 12-21-2011, 12:53 AM   #1
Talking 1974 Early Bronco Build
I am building this scale Bronco to match pretty close to my 1974 1:1 Bronco.
Let the party begin. Here is what I am starting off with.
The Body:
Rc4wd Front/Rear metal axles:
Using Losi springs for the front and rear leafs.
Rc4wd 3-Peice wheels and Rc4wd Rock Stomper:
Axial SCX Chassis:
Rc4wd 90mm Scale shocks (silver):
Rc4wd 35T brushed motor and regular black R2 Tranny:
More to come:
5150bronco is offline   Reply With Quote
Old 12-21-2011, 01:01 AM   #2
Default Making Buckets for the Coil Springs.
At first I was using the top mount to fold around frame (first pic) than wanted to change it and make almost exact bucket on the bronco (subsequent pics).
I used 18 gauge sheet metal, cut a T shape, folded in the top sides than brazed it together. This is just the mock up and it looks good. I will cut it down and shape the top end so it is round.
Old 12-21-2011, 07:46 PM   #3
Default Re: 1974 Early Bronco Build
Can you post a pic of your 1:1 Bronco?
Modbug is offline   Reply With Quote
Old 12-22-2011, 09:47 PM   #4
Here is the 1:1 Bronco.
Old 12-24-2011, 11:49 PM   #5
I have finished the buckets. These will be the mock ups for now. I will work on setting the rear leafs than building the links.
Any feed back, opinions or suggestions are always welcomed.
Enjoy!
Old 01-04-2012, 02:26 AM   #6
Just made some front links out of aluminum tube using Rc4wd heims.
Installed drive shafts and R2 Tranny.
Thanks for looking.
Old 01-19-2012, 11:21 PM   #7
are you going to 4 link your front suspention, or do a 3 link like the 1:1 bronco??
ponderj50 is offline   Reply With Quote
Old 01-19-2012, 11:26 PM   #8
Nice start i'll be watching this one
jfergz is offline   Reply With Quote
Old 01-20-2012, 12:28 AM   #9
Nice build so far, I like the 1:1 too!
yellowranger1 is offline   Reply With Quote
Old 01-20-2012, 10:09 AM   #10
Nice build and nice 1:1. Got to love the early bronco
rc's suck is offline   Reply With Quote
Old 01-20-2012, 10:58 PM   #11
Thanks guys for all the comments. I am open to any suggestions or feedback.
Trying to stick with my 1:1 setup now. So, 2 links up front with panhard bar and leafs in the rear with shocks/shocks up front.
I might after this build is put coils in rear with 4 link and than 3 link the front as I would if I put 60's in the bronco which is my future build.
I just finished mount the rear leafs now. Will get pics up soon. Now making the servo plate for the front and drop track bar for the front panhard than make the drag link and steering rod.
Old 01-21-2012, 07:39 AM   #12
Nice 1.1!!!
Your builds coming ago nice too, curious to see how ya gonna mount the shocks now..
skinner is offline   Reply With Quote
Old 01-28-2012, 09:25 PM   #13
Thanks Skinner.
I am going to do a shock hoop or mount on the inner part of the bucket.
Here is front steering rod. Going to make tabs for the servo than make drag link and pan hard next.
Old 02-18-2012, 09:12 PM   #14
Built tabs for the servo and the last tab is for the shock mount.
Old 02-21-2012, 01:57 AM   #15
Buckets sanded, cut to fit frame and ready. Shock bracket mounted.
Enjoy! Thanks!
Rear shock hoops are next.
Old 02-22-2012, 08:52 PM   #16
Question Which shock hoop style?
Need your opinion: Which shock hoop looks better?
TOP? Or BOTTOM?
Thanks!
Old 02-22-2012, 09:08 PM   #17
I'd go with the bottom but that's me. Every thing looks really good so far!
highroller89 is offline   Reply With Quote
Old 02-22-2012, 09:30 PM   #18
Bottom definitely looks better.
GaBronco is offline   Reply With Quote
Old 02-24-2012, 04:09 PM   #19
Default Re: Shock hoops.
I liked the bottom as well. Thanks for the feedback. Here you go.
Enjoy!
1974 Early Bronco Build - Similar Threads
1.5 Early Bronco AkFordfan 1.5 Scale Rigs 261 02-05-2021 08:19 PM
Early Bronco RAM2500 Paint and Body 5 09-05-2011 05:47 PM
Early bronco build 1st run.. ROLANDROCKSHOP Scale Videos! 0 05-30-2011 08:14 PM
Early Bronco Build 5150bronco 1.9 Scale Rigs 21 03-25-2010 06:06 AM
Early Bronco Build Coming Dogbreath Losi Micro-Rock Crawler 12 02-15-2010 04:41 PM
