04-06-2012, 01:09 AM | #21 |
Newbie Join Date: Jan 2010 Location: toledo
| Re: RC4WD Gelande Defender build
Love the paint scheme the attention to detail is great
04-06-2012, 01:32 AM | #22 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
nice, i like the universal you made from the tranny to the tcase..should make for a smoother ride..will do to mine make sure you set your endpoints just right on your steering or you will snap your axle case and ya the shocks are poop very nice build |
04-06-2012, 03:52 AM | #23 | |
Rock Stacker Join Date: Nov 2011 Location: Santa Cruz, Ca.
| Re: RC4WD Gelande Defender build Quote:
Cheers, Skottoman | |
04-06-2012, 11:43 AM | #24 |
Finally a running chassis. Even with a 21T motor, this thing is pretty slow... but quite scale I'd say. Got the front bumper assembled. What a pain it was to mount that winch!!!! So hard to drill the holes in the proper place, and get the screws in there. Plus the location of the screws for the lights was a real pain as well! Bumper done, but will need to fabricate something to attach it to the Gelande chassis rails. Last edited by skottoman; 04-06-2012 at 03:37 PM. |
04-06-2012, 05:48 PM | #25 |
RCC Addict Join Date: Feb 2011 Location: York
What bumper is that?
04-06-2012, 06:19 PM | #26 |
| Re: RC4WD Gelande Defender build |
04-06-2012, 06:24 PM | #27 |
Entire inside of body painted flat black. Will make the light colored seats pop! Now need to wetsand and clearcoat! Last edited by skottoman; 04-06-2012 at 08:43 PM. |
04-07-2012, 09:20 AM | #28 |
Pebble Pounder Join Date: Jan 2009 Location: South Africa,JHB
Coming along nicely there. Keep it up. 21T motor, bit warm ain't it? Cheers T |
04-07-2012, 10:59 AM | #29 | |
Pretty easy to change motors though, so I may try the 35T when it comes in. Cheers, Skottoman | |
04-07-2012, 01:10 PM | #30 |
Ok I see, was thinking that is pretty warm for a scaler. But if it's geared low then should be good, might help with a bit of wheel speed. Time will tell i guess once you get some miles on it. Cheers T |
04-07-2012, 01:36 PM | #31 |
Yes, I've driven the chassis around, and it crawls pretty well, while still having a semblance of "Top speed". Hahaha... FINALLY got the bumper completed. Between drilling and mounting the winch and lights, to adding mesh, to fabricating steel brackets to bolt to the frame, it's taken me as long to build this bumper as it did to paint the body! AGH! More progress... |
04-07-2012, 02:47 PM | #32 | |
04-07-2012, 02:51 PM | #33 |
4 coats of clear and now the body must sit and cure for a while! Before a wetsand and polish! Last edited by skottoman; 04-07-2012 at 04:17 PM. |
04-08-2012, 05:26 PM | #34 |
More updates, starting to add details to the body. Found out that Tamiya F201 springs fit these shocks perfectly, so I have quite a variety of springs to choose from, as I have an extensive F201 collection. Photos... |
04-08-2012, 05:27 PM | #35 |
04-08-2012, 07:23 PM | #36 |
04-09-2012, 12:20 AM | #37 |
brilliant! love the attention to detail. Your paint work is excellent. Nice job on that grill for the bumper, turned out exactly like a 1:1 with the welding on the edges. fantastic. looking awesome. Whats lefts to do apart from the lighting? cheers T |
04-09-2012, 04:33 AM | #38 |
Newbie Join Date: Apr 2012 Location: Germany
Man that paint job is sick! I really like the motor setup as well, I purchased a d90 body Myself, but cut it into a pickup cab for a flat bed. Nice rig! |
04-09-2012, 08:15 AM | #39 |
| Re: RC4WD Gelande Defender build Still have to add some scale junk, along with some straps/chains, etc. Need to attach the roof rack after I polish the body a little more. Add exhaust pipe, antennas, etc. Then onto the lights, and to attach the interior. Right now most of the stuff is just sitting in place and not attached. Cheers, Skottoman |
04-09-2012, 06:07 PM | #40 |
More progress with the lights. I will have to install 12 lights. I broke the part that goes over the license plate, so I made one that can have a light behind it shining down on the plate. Cage is bolted on, as is the rear spare tire, and snorkle. Only a few little parts left to install, then I have to bolt and wire it all together. It's mega heavy!!! HAhaha... Last edited by skottoman; 04-09-2012 at 08:56 PM. |
RC4WD Gelande Defender build - Similar Threads | ||||
RC4WD Gelande Defender Lots of pics | robertrocha6 | 1.5 Scale Rigs | 21 | 10-02-2013 02:34 PM |
The poor-mans Gelande: Another Defender hardbody begins life. | REVCO | 1.9 Scale Rigs | 35 | 07-01-2012 09:19 AM |
RC4WD Gelande pinion specs? | zBigBadWolf | 1.9 Scale Rigs | 4 | 03-16-2012 06:14 AM |
Class 1 Gelande Defender | Dirty | 1.9 Scale Rigs | 9 | 02-29-2012 06:02 AM |
rc4wd gelande | cossack | 1.9 Scale Rigs | 3 | 04-18-2011 08:01 AM |
