05-30-2012, 06:52 AM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: australia
| Pozman's fj40 buggy
Hi guys. Got the bug for a new build Bought a styrene fj40 body off a local guy with the plan of going full tuber. Building it for our 1.9tt class (pretty much class 2) Running axial axles trans and killer transfer and probably run rc4wd iroks Getting inspiration from a buggy I found on here that kaetwo built from aswell. Just with a bit of my own flare So here's the body I got And the start of my tube work. Just the cab so far Now what I'm not sure about is wheelbase. Thinking longer just like the 1:1 but unsure where I should be? Cheers Paul |
05-30-2012, 12:32 PM | #2 |
RCC Addict Join Date: Sep 2005 Location: Lehi
| Re: Pozman's fj40 buggy
good start!
05-30-2012, 12:35 PM | #3 |
RCC Addict Join Date: Nov 2008 Location: Santa Fe, NM
Wow great looking build so far I really like it.
05-31-2012, 08:11 AM | #4 |
Thanks guys. Hope to get some more done tomorrow. Need the get some diffs under it so I can start cutting the body see where things need to be
05-31-2012, 11:32 AM | #5 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
oohhh, wish i would have been building mine, swap ideas.. thats a sick 1:1.. I thought it was an RC at first, never can tell easy these days. the WB on mine ended up at 12 inches and is STILL too short, I think the FJ's look really good with longer WB. cant wait to see where you go with this one!! nice work so far! thats a nice design for sure |
05-31-2012, 09:29 PM | #6 |
RCC Addict Join Date: Feb 2011 Location: Huntington Beach
Very nice, I love that rig, great start. I'll be watch'n....Have fun.. |
06-01-2012, 07:39 AM | #7 |
Well got a little done today. Made the chop on the body. It was hard thing to do to chop a nice fresh body lol it's just rough for now. Need to get axles under it before I can finalize the guard shape Started on the front chassis. Very tricky to get this right. Really hard to get descent measurements. But suppose its not a real car, and doesn't need to be perfect. Although I still would like it to be fairly close New bundy tube I got is not as strong as the original stuff I had. This stuff is shinny. The old stuff was green. The shinny stuff does braze better as the coating doesn't burn up like the green So since its not as strong I'm thinking it's going to need a bit more bracing Also got the transfer mount in. This is also going to be where the lower links mount from (under the cab) planing to have motor and trans under bonnet. Run the lipo pack under the seat. Aiming to have a full low floor too Thinking of wheelbase around the 12.5-13in mark. My old defender is just shy of 12in Paul |
06-01-2012, 01:27 PM | #8 |
RCC Addict Join Date: Nov 2007 Location: -
Man dude, that is looking awesome! Keep it up!
06-01-2012, 07:16 PM | #9 |
Quarry Creeper Join Date: Mar 2011 Location: Universal City, TX
06-01-2012, 11:57 PM | #10 |
Looking good I love this build already! |
06-02-2012, 12:11 AM | #11 |
Rock Crawler Join Date: Oct 2011 Location: Another place, another time
| Re: Pozman's fj40 buggy |
06-02-2012, 12:45 AM | #12 |
thanks guys, hahah yeah i can see how youd be fooled, if only the dude wasn't in it haha i wish it was, some scale mog 404s would be ace paul |
06-05-2012, 06:09 AM | #13 |
Got a little more done over the week end and tonight. Got the bottom link mounts done and chucked some axial links in to see where I'm at. Actually happy with the lengths This is how I've don't the mounts. Same style as the scx10's just out of metal. Notched the pipe out and then drilled 3mm hole through the other pipe. So one m3 all thread will hold in both links Got the bottom of the buggy rear in. Slopped it up like the 1:1 and made the top of the front of the chassis. Needs be braced yet but need to wait till I get my shocks before I do any of that Top of the rear buggy frame in. Only just passes the 106x106mm rule (as far as I read it anyway :-/ ) That's all for now. Only minor bracing can be done now until I get my order from rc4wd. (still waiting on things to come in stock) Paul |
06-15-2012, 06:49 AM | #14 |
Got a few more things done. Got the side rails all done. Theyll need to be braced back to the center frame tho as there too easily bent. Also done a stinger for the front. Played the bace of the stinger so fair lead can be mounted and for strength and sliding on stuff Bonnet on and trimmed to the side rails. From the top. Don't think I like how far the stinger sits out. Bit it's done now Upper link mounts in. Only one in the front as I'm running three link plus panhard. Motor/trans mount. Still needs to be braced Trans and diffs in Cheers Paul |
06-15-2012, 09:19 AM | #15 |
Quarry Creeper Join Date: Sep 2010 Location: t(._.t)
looks sweet. always liked fj's. |
06-25-2012, 05:43 AM | #16 |
Thanks mate. So got a few things in a mail over the last week. And made a few more bits aswell Made a diff brace for panhard and upper link mount Steering box. Turn buckle style just like my defender for those that have seen it. Running bearings in this one tho. Shaft is an old diff pinion shaft that died Got bored and made a steering wheel. Came out ok And new bits. Axial high steer knuckles and c hubs. The new design seams better than the last. Uses a grub screw to bolt them on. They fit much tighter. Can see the panhard mount on the axle Got my transfer, beef tubes for the front and HD gears Got order coming from rc4wd. Shocks Tyres and ball ends mainly. Sorta stuck until they come now Paul |
06-25-2012, 01:14 PM | #17 |
Quarry Creeper Join Date: Jan 2007 Location: Raaaaaiiiiinnnnniiiieeeerrrr
nice build for sure. I love the 1 to 1 you are doing. how long does an order from the US take to get to you?
06-25-2012, 04:04 PM | #18 |
Thanks mate. Yeah when I first saw it I just had to do one. Normally only about a week or two. Depends on how good the sellers are. Paul |
07-09-2012, 07:41 AM | #19 |
Well got fair bit done over the last week or two Panhard mount done Front shock towers done and bracing the front frame. Put in second bar for the motor plate and also played the outside floor Rear bracing, shock mounts and back stays in And side view of it all Not much tube work to do now (just as well, be over 7 meters of tube there now) Just need to brace the horizontal plane now Will get some photos with diffs under it and the diff braces tomorrow. It's got some pretty good flex Paul |
07-09-2012, 07:57 AM | #20 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Very nice fab work! I really like your axle truss/pan mount. Very clean. |
Pozman's fj40 buggy - Similar Threads | ||||
First 1.9....FJ40 | solomon7 | 1.9 Scale Rigs | 9 | 11-30-2009 08:28 PM |
fj40 | jeepjames87 | 1.9 Scale Rigs | 5 | 08-04-2009 09:45 PM |
Another FJ40 . | 4u2nv | 1.9 Scale Rigs | 24 | 02-06-2008 05:49 PM |
moon buggy turned snow buggy!!! | bastard | Chit Chat | 31 | 12-26-2006 09:21 AM |
