12-08-2012, 03:50 PM | #1 |
Quarry Creeper Join Date: Nov 2012 Location: spanish fork
| Hacking a new bright body question
Went for a fun run to our new favorite place before the snow covers it up, and decided the new bright body I got is to heavy and tippy.so I had an idea pop in to my head to hack it up. I got started cutting it out, my question is... What's the best way to re stick the plastic back to its self, and to fill in the holes shoe goo and dry wall tape , and just bondo for the holes? My idea Sent from my XT907 using Tapatalk 2 |
12-08-2012, 04:17 PM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: Kyle TX
| Re: Hacking a new bright body question
YES! Drywall tape can fix it. But I would not recommend it for this application.
12-08-2012, 05:06 PM | #3 |
Thanks drywallguy Sent from my XT907 using Tapatalk 2 |
12-09-2012, 01:39 AM | #4 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Spend some time searching the forum. Drywall anything will not be appropriate here. Superglue for the plastic, and yes, bondo for the holes. But there's a lot more you'll need to learn to make this turn out. Search, read and learn from the many builds on here to do the body work. It's all in here. Best of luck. |
12-09-2012, 07:19 AM | #5 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
I use CA glue and ABS pipe cement since the body is made from ABS. Also, the ABS cement can be used as a filler since it is sandable once cured. It fuses to the body to make a strong bond. And for the finer filling areas, I use Bondo automotive spot putty. ABS cement http://www.rccrawler.com/forum/1-9-s...jk-brute*.html |
12-09-2012, 12:30 PM | #6 |
Nice man, thanks fit the input that's what I wanted to know Sent from my XT907 using Tapatalk 2 |
Hacking a new bright body question - Similar Threads | ||||
New Bright body question. | Tourettic1 | Axial SCX-10 | 2 | 11-27-2012 01:43 PM |
AX10 body hacking | darkstar | Paint and Body | 25 | 05-05-2008 09:09 PM |
