05-28-2013, 01:09 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: Flat Hills of Florida
| Bondo's JK, Lots of steel work and pic heavy
I bought this thing a couple months ago (NIB Axial Rubicon) and finally have made some progress on it. First was the usage of a RC4WD AX2 2sp trans, this is a powder coated alum case with servo mount and linkage included, also has a 32pitch delrin gear and HD dual slipper pad assembly. The internal gears are wide heat treated steel and should more than up to the task of handling some power. With some Dremel work to the motor plate and to the inside top of the center skid plate I'm able to use this monster 770 27T brushed motor and plan to power it via 3s 2200mah 40C packs WOOT ! Some poser shots and comparison of the 770 to a Epic 27T 540 motor Links I'm making with 5/16 All-thread and Revo rod ends with Stainless Steel tubing for a cover. Last edited by BONDONUTZ; 05-28-2013 at 01:14 PM. |
05-28-2013, 01:28 PM | #2 |
| Re: Bondo's JK, Lots of steel work and pic heavy |
05-28-2013, 01:35 PM | #3 |
05-28-2013, 02:12 PM | #4 |
I'm HUGE in Japan! Join Date: Dec 2011 Location: Clearwater - home of the endless summer
| Re: Bondo's JK, Lots of steel work and pic heavy Fffffff yeah
05-28-2013, 02:16 PM | #5 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
I have a feeling this will be ultra epic! Definitely subbing this one! Still on brass and styrene but should be graduating to steel soon!
05-28-2013, 02:25 PM | #6 |
I think I enjoy the Styrene and plastic work the best, reminds me so much of working on 1:1 in the bodyshop before I retired.
05-29-2013, 07:28 AM | #7 |
I wanna be Dave Join Date: Nov 2005 Location: Here
Looking good Jeff... That motor will be "interesting" What epoxy do you use for waterproofing? |
05-29-2013, 08:06 AM | #8 |
Hey thanks John ! The motor should be a monster for sure, it weighs a lot and sits extra low in the skid plate so COG should be better than average as well ? I used 15min epoxy I bought from HobbyKing, it was 6-7bucks for 2-6oz bottles |
06-12-2013, 01:23 PM | #9 |
Newbie Join Date: Oct 2012 Location: Clearwater
Looking good!
06-12-2013, 01:26 PM | #10 |
killer idea on the epoxy box. i sprayed mine with rattle can rubber plasti-dip.
06-13-2013, 09:42 AM | #11 | |
| Hey thx Jason, progress has ben slow but going. I hope to be feeling better to do some more welding this weekend and get the shock mounts done and some cross braces. I sent a PM inquiring about that NB body Quote:
FYI; All typos are the phones fault. | |
06-13-2013, 10:59 AM | #12 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
I like the epoxy job on the sv2. However I am wondering what epoxy you used? Sent from my GT-I9100M using Tapatalk 4 Beta |
06-14-2013, 05:11 PM | #13 |
Bondo's JK, Lots of steel work and pic heavy - Similar Threads | ||||
I might as well have one too (pic heavy!) | CAPCbass | Axial Wraith | 23 | 08-16-2013 01:04 AM |
