12-23-2006, 02:57 PM | #261 |
Rock Stacker Join Date: Oct 2006 Location: Honolulu
Nope, but now I have a good reason to get a drill press and scroll saw.
12-23-2006, 05:11 PM | #262 |
RCC Addict Join Date: Apr 2005 Location: Seattle
I got it today, sweet! Thanks! I keep a stock of all sizes of 3mm screws, washers, nuts, lock nuts, etc. I don't use ANYTHING else, so I am all set in that department. |
12-23-2006, 06:48 PM | #263 |
Newbie Join Date: Jun 2005 Location: clinton twp
unfortunately I dont have a good stock of 3mm but even if I did I dont have a 3mm tap, so I'll probabaly use 4-40 on holes I have to make.
12-23-2006, 09:53 PM | #264 |
You should look in your area to see if you can find a fastener store. There is a place here called Tacoma Screw, and thy sell the 3mm hex heads in all lengths for dirt cheap.
12-26-2006, 03:35 PM | #265 |
Trying to have Fun Again Join Date: Apr 2006 Location: In your fridge stealing a beer
Mine showed up today. Going to get screw's today.
12-27-2006, 10:03 AM | #266 |
I joined the Band! Join Date: Mar 2006 Location: Gardena,Ca.
ok everyone that purchased the first go around of the hi lift. i've been readingthat some of you have concerns or minor problems. when i built mine i tried to use some of the stocks parts but not all. as you all know stock sucks if you guys have any input on things that should be added or changed please feel free to say so. i'm always open for suggestions. i try and make the chassis as simple to make as possible. so let me know what you guys think
12-27-2006, 10:25 AM | #267 |
Rock Stacker Join Date: Nov 2005 Location: under the bridge
do you still have any left?
12-27-2006, 04:14 PM | #268 |
Quarry Creeper Join Date: Sep 2006 Location: Jackson
I haven't had time to work on mine yet, but I realize that not everything is stock as you said in one of your post. I enjoy fabbing parts so that no one has exactly the same as I do.
12-27-2006, 10:00 PM | #269 | |
Rock Stacker Join Date: Feb 2004 Location: Jerzey
What He Said Alfy | |
12-28-2006, 08:41 AM | #270 |
here's another little twist to the frame.
12-28-2006, 01:15 PM | #271 |
Rock Stacker Join Date: Dec 2005 Location: Norway
Sweet, that pic just make me want one |
12-28-2006, 07:25 PM | #272 | |
Quarry Creeper Join Date: Oct 2006 Location: Simi Valley, CA
12-28-2006, 07:37 PM | #273 | |
Rock Crawler Join Date: Mar 2006 Location: Benson,NC
12-28-2006, 07:48 PM | #274 |
this chassis is not for $70.00 i just made 2 of them just see how they look
12-28-2006, 07:50 PM | #275 | |
I love that CF chassis (if that's what it is, looks like it!) | |
12-28-2006, 07:53 PM | #276 |
the last chassis is not carbon fiber, it is alum. the way i hatch the alum uit makes it looks like c.f. looks look up close
12-29-2006, 12:07 AM | #277 |
To ammend my last post, the pivot holes ARE there, I just didn't recognize them! I fabbed up some quick bracktry and the body is mounted. I am going to have to cut off the forward-most of the rear shock mounts or my tube bed won't fit, but I only run one shock per corner anyway. The only thing I need to figure out now is the servos, might prove trickier... One thing I noticed that I haven't seen mentioned is that you need to reverse the spacer on the shackles away from the rails, and remove the black plastic spacer from the spring mount. Doing that brings the springs in line just right. |
12-29-2006, 12:46 AM | #278 |
Nice, got any pics from the side? I think I'd still like to raise the tranny. Will wait til I get a drill press before starting so I can tap the holes for the steering/shift servo's.
12-29-2006, 02:14 AM | #279 |
You'll have to redrill tranny holes as well, don't forget. You'll have to decide whether to move the tranny up and slightly forward or up and slightly rearward. The distance between the rails will not allow the use of the stock servo rails, nor will it allow the rails to be in the same location. Something completely new will have to be worked out. I am considering switching to a micro servo for shifting and a standard for steering, but mounting them directly to the rails on each side. Adaptor plates will be needed. |
12-29-2006, 04:24 AM | #280 |
I'm thinking of using the plates that I have on it now. You could get something like this to mount the servos to the rails. http://rc4wdstore.com/product_info.php?products_id=168 I think I'll cut strips of alum and bend them in a c shape to have it like the stock mounting |
