06-08-2013, 12:24 AM | #1 |
Rock Crawler Join Date: Aug 2012 Location: Los Angeles, CA
| Trump's Pro-Line Jeep Wrangler Rubicon build.
I powder coated a base coat on the frame rails and Vanquish shock mounts: Here is the finish coat. Metallic Candy Pearl Red: |
06-08-2013, 12:32 AM | #2 |
| Re: Trump's Pro-Line Jeep Wrangler Rubicon build.
Trimmed the XR10 universal so I could install XR10 steering. I also installed XR10 C Hubs, knuckles, and Beef Tubes. I didn't post photos because it's been done before. Hard left: Hard right: Last edited by Trump1; 06-09-2013 at 02:39 PM. |
06-08-2013, 12:36 AM | #3 |
Mounted the body so I could get an idea of how the bumpers would sit: |
06-09-2013, 01:33 AM | #4 |
Here is a short video testing the XR10 steering: |
06-09-2013, 04:21 PM | #5 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
dang ima have to do that xr mod nice build so far
06-09-2013, 07:27 PM | #6 |
| Re: Trump's Pro-Line Jeep Wrangler Rubicon build. Thank you. You could also improve your steering by adding Axial AX10 CVDs or Vanquish VVDs. They are suppose to go right in without any mods.
06-09-2013, 07:43 PM | #7 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
looking good man,,
06-09-2013, 10:29 PM | #8 |
| Re: Trump's Pro-Line Jeep Wrangler Rubicon build. |
06-09-2013, 10:36 PM | #9 |
what color are you painting the body??
06-09-2013, 10:41 PM | #10 |
Front Bumper: I started my front bumper. I started with this ... The bumper looked a little to high, so I trimmed it down a bit. Here it is trimmed down a bit. Made some mounting brackets. I had to re-design the brackets so I can integrate the winch into front bumper. Building the front bumper was very time consuming. Here is what I have so far. I just need to add some light tabs and it will be ready for the base coat: Rear Bumper: I wanted a simple rear bumper that would maximize ground clearance. It took me only one night to get most of the rear bumper built: The base coat is on! |
06-09-2013, 11:39 PM | #11 |
Quarry Creeper Join Date: Feb 2011 Location: USA
nice rims |
06-10-2013, 10:10 AM | #12 |
06-10-2013, 10:13 AM | #13 |
| Re: Trump's Pro-Line Jeep Wrangler Rubicon build. Thank you. I like them Dick Cepeck Gun Metal 7 wheels too.
06-11-2013, 10:29 AM | #14 |
The front and rear bumpers are done. Here is the finish coat. I spend extra time recessing the lights inside the bumper: A tight squeeze. I have about 2mm of clearance between the winch and servo horn. And here is the way it looks with the spare tire and jerry cans: Rock sliders are next. |
06-11-2013, 12:00 PM | #15 |
Quarry Creeper Join Date: Jul 2010 Location: PNW
Very nice! great job on the bumpers!! What savox servo are you using?
06-11-2013, 02:38 PM | #16 |
06-11-2013, 02:44 PM | #17 |
06-11-2013, 08:03 PM | #18 |
I joined the Band! Join Date: Feb 2009 Location: https://t.me/pump_upp
Truck looks really nice! I must ask, what is the benefit of silver powder coated base coat? Is the red spray painted or powdered?
06-11-2013, 08:27 PM | #19 |
Rock Stacker Join Date: Feb 2013 Location: NW
Correct me if I am wrong but I believe you have to use a base coat because he is using candy/translucent top coat. So the base coat has the ability to change the final color. Silver is a pretty standard base coat when using candy top coats.
06-11-2013, 08:28 PM | #20 |
I'm assuming the red is spray paint then, because when I powder coat metal twice the second coat never comes out well. Trump, did you scuff the PC finish first?
Trump's Pro-Line Jeep Wrangler Rubicon build. - Similar Threads | ||||
NorCal's Axial SCX10 2012 Jeep Wrangler Unlimited Rubicon Kit Build | NorCal 2500HD | Axial SCX-10 | 29 | 06-20-2014 09:59 AM |
My first build thread, Pro-Line Wrangler JK. | JimDaBomb | 1.9 Scale Rigs | 4 | 09-05-2012 03:18 AM |
