11-20-2013, 04:10 PM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: Katy Tx, from Riverside Cali
| Scx Truggy help. Newb sorry guys.
Whats up guys, Im planning on throwing a little truggy together using an scx10 chassis and tamiya f350 body. Ive got the brazing thing down ive done it on a few other rigs. What size tubing do you guys use for the tube chassis? And where do you get it?
11-20-2013, 04:14 PM | #2 |
Quarry Creeper Join Date: Jan 2009 Location: Victoira,BC
| Re: Scx Truggy help. Newb sorry guys.
brake lines and a local auto store is my guess, I want to build my own cage but thats in the distant future
11-20-2013, 08:32 PM | #3 |
When you braze brake line. Don't you have to worry about the toxins that get released?
11-20-2013, 10:04 PM | #4 |
RCC Addict Join Date: Mar 2009 Location: hawaii
I wouldn't really worry too much. Just make sure you sand the coating off wherever your joints will be before you braze it.
11-20-2013, 11:22 PM | #5 |
Quarry Creeper Join Date: May 2012 Location: Portland
You can use brake line if you like, or you can use 3/16 inch tube or you can use 3/16 rod or mix and match from 1/4 to 1/8 tube and or rod just depending on what your doing. brake line is pretty thin walled and considering I can bend the 3/16 4130 chromoly steel tube that I have (which is thicker walled than brake line) with my bare hands I would worry about brake lines strength but a lot of people seem to use it because it can be obtained easily and cheaply. You do have to get rid of the coating, which there are several threads about how to do that. Steel rod is the heaviest of course and is very hard to bend, but very strong.. there are people here that build full interior cages out of it though and its cheap, even cheaper than brake tubing. The last time I bought some it was $5 for 4 feet. easy to cut with an angle grinder with a cut off wheel or hacksaw. Do not buy music wire it is very hard to work with. Hope your build go well. |
11-22-2013, 02:24 PM | #6 | |
| Re: Scx Truggy help. Newb sorry guys. Quote:
Scx Truggy help. Newb sorry guys. - Similar Threads | ||||
Another newb question. Sorry guys | turbotron | RC4WD Trail Finder 2 | 3 | 01-29-2013 06:18 PM |
1/8 buggy/truggy newb question | Bart bender | Non Crawler RC's | 10 | 02-23-2010 10:00 AM |
u guys have got to check out this newb | 93 FORD BRONCO | Florida | 2 | 01-16-2010 10:02 AM |
Hi Guys...Iowa Newb | Drey | Iowa | 13 | 03-14-2009 09:32 PM |
Newb Scout Truggy | IHCrawler | Tamiya TLT Crawlers | 7 | 09-06-2006 07:49 PM |
