04-14-2014, 10:44 PM | #1 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
| Another yota build.....
Well I didn't want to go through the entire build process as we've all seen that one many times over so I'll start after the mods began. This will be a long build as I'm tearing it down between every mod to do the body work and interior etc. As it's my only fully operational rig at this time I want to try to keep it that way. It started life as a base tf2 with some bolt on body parts, rubber fender flares, rubber mirrors, a spare tire carrier, also installed Lesu side markers, taillight lenses and some Yota emblems to top it off. Then I swapped out the leafs for the 3 link front and 4 link rear as well as shocks I went with 90mm EMU shocks for a better ride height and drive, I also flipped the stock rims for a different look, that only lasted for a bit until I got my new wheel tire combo. One just for fun: Then I decided to swap out the rims/ tires for better performance and overall appearance, I went with 1.9 locked up 8bolt trail ready wheels with mthead bead-lock rings, installed with all scale hardware and acorn lug nuts along w REC hubs, sitting on cepek fun country tires. I like the looks of these, they are not too large or wide for the rig and still tuck under the flakes for a nice look. here's the mandatory flex shot: It's still a work in progress, I'm working on the interior and scale touches to make it better, more to come later as I load up the pics to PB. All thoughts and comments are welcome. Thanks for looking. --Dan |
04-14-2014, 10:46 PM | #2 |
| Re: Another yota build.....
Here's some of the changes I'm making to better the scale looks of it. I'm going with a full inner fender-well and engine bay design. Eventually I will be installing a styrene engine as well to cover the motor up. These are just the beginning designs but with some inspiration and a few tricks from "Noobs" tf2 build it will be a fully concealed engine bay From the front With inner fender-well installed and body sitting on chassis This portion will be sprayed black and I still have a few more support pieces to put in. But it's coming along. I have more pics coming of the rear as well. Thanks for looking --Dan |
04-15-2014, 05:39 PM | #3 |
Pebble Pounder Join Date: Jan 2014 Location: Archdale
Looks like your on the way to having a nice yota , like your work man, looks great |
04-15-2014, 06:51 PM | #4 |
| Re: Another yota build..... |
04-21-2014, 04:43 PM | #5 |
Just a small teaser update. And now we let the detail work begin. |
04-21-2014, 04:56 PM | #6 |
Ooo got the sick interior. Should look great.
04-21-2014, 05:36 PM | #7 |
| Another yota build..... Yeah, I've had my hands on them before but not for any of my builds and they were super nice and detailed so I figd why not splurge on one... It saves me the headache and will look way better than what I could do.... And one more from the front just for a better visual --Dan Last edited by sickcivic95; 04-21-2014 at 05:39 PM. |
04-21-2014, 05:44 PM | #8 |
Since they are so expensive once I get my hilux I'll probably use a bruiser interior until I can afford it.
04-22-2014, 01:39 PM | #9 |
Rock Crawler Join Date: Jun 2013 Location: Cincinnati
Im liking the engine! Did you do that?
04-22-2014, 08:44 PM | #10 |
Sorry can't take credit for the engine, I've modified it to work for me but the manifold setup and water pump was worked up by someone else and has a real fan in it to help cool the motor. It's a pretty slick setup. I've got plenty more parts I've made to add to it you'll see coming up sometime soon, although I'm still not sold on using it on this rig.... The v8 part just kills it for me, I was originally planning on using it I'm my suburban build where the v8 works... --Dan |
04-25-2014, 12:07 AM | #11 |
No major updates just some prep work and paint on the interior parts Sprayed some primer yesterday, im planning a two tone black and gray or possibly white to match the exterior although I may be repainting it a different color anyway as the white can be a bit boring. Anyway on to some pics Primed: Although I'm horrible at painting I figured I'd still give it a shot just strip it,if it comes out horrible. Here's first coat of the flat gray, decided again the cow colors for now but I can easily change it to match. Its enamel paint so it looks worse than it is because its still wet and hasn't leveled out fully. I'm not sure on the two tone now but after the time it takes for just primer and 1st coat paint I may keep it.. I still have the metal strips to put in the doors and all the dash trim which will separate it a bit better. LMK your thoughts Also some flat aluminum color on the shifters which I also relocated to better match the 1:1 they were offset to start so I just hand drilled small 3mm holes to center them on the trans tunnel. Original location to left New location for shifter in center. This shows how ill mod the seat to match the 1:1 as well. Probably shouldn't have handled it with tacky paint but I'm like a kid in a candy store and just can't keep my hands off.....lol Thanks for looking more updates coming soon. --Dan Last edited by sickcivic95; 04-25-2014 at 12:13 AM. |
04-27-2014, 10:13 PM | #12 |
Just a small update more work completed on the interior details. I added color behind some of the trim for more authenticity I also finished up the standard trim install Now here's one, I made a lexan cover for the gauges should I keep it or no More to come later --Dan Last edited by sickcivic95; 04-27-2014 at 11:31 PM. |
04-28-2014, 08:59 AM | #13 |
Pebble Pounder Join Date: Nov 2006 Location: Tennessee
Keep the lexan gauge cluster for sure its a nice touch that gives it that little extra scale look. Sent from my Phoneamathingy |
04-28-2014, 09:19 AM | #14 |
I did keep the cover in, here's a quick shot with it just sitting in place. |
04-28-2014, 12:25 PM | #15 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
Looks great Dan. The lexan cover on the gauges looks spot on too. Opening hood?
04-28-2014, 12:52 PM | #16 |
Another yota build..... - Similar Threads | ||||
jeeper_05's Vuckin Yota build...Now Hotwheels000's Vuckin Yota! | jeeper_05 | 1.9 Scale Rigs | 264 | 09-28-2015 12:17 AM |
my 1.9 yota build | buster22 | 1.9 Scale Rigs | 89 | 06-02-2009 05:02 PM |
1:1 'Yota Build | HDMM | 1.9 Scale Rigs | 14 | 12-28-2008 07:32 PM |
Yota build...... | TattooKenny | Losi Mini-Rock Crawler | 3 | 09-06-2008 07:02 AM |
Yota build | twisted77 | 1.9 Scale Rigs | 2 | 05-01-2008 07:11 PM |
