01-21-2015, 06:40 AM | #21 |
Quarry Creeper Join Date: Mar 2014 Location: Rogers, MN
| Re: Slimer, 1.9 Ram aluminum "tuber"
Surprisingly, they brazed out that way. No, I haven't been tinning, but that seems like a good idea, would take a lot longer though. Thanks -Derek |
01-21-2015, 09:32 PM | #22 |
Brazed those front end pieces in. Need to work on the axles now. -Derek |
01-22-2015, 07:12 AM | #23 |
Rock Stacker Join Date: Feb 2014 Location: Elk River
I really like those rim and tires!! Also for a dodge it is looking good.
01-22-2015, 10:26 PM | #24 |
Haha Greg, I bet you do. Started a poster board mockup up of an axle truss which will include link mounts and shock mounts. So far got the main section, and the mounts on one side. other than the servo mount, the rear axle will just be mirrored. I've decided to just make these from some 18ga steel I already have, for strength and some extra weight on the axles. Looking at these pics, I realized I have the shock mount on the wrong side of the link (too high, and to far inboard) I'll fix that tomorrow. This is why I do mockups, haha. -Derek |
01-23-2015, 09:24 AM | #25 |
Rock Crawler Join Date: May 2009 Location: Welderville just south of benchviseland
Posterboard... Can't believe I never thought of using that! That's actually a pretty good idea. Beats wasting steel that's for sure lol.
01-23-2015, 11:14 AM | #26 |
Rock Crawler Join Date: Jul 2011 Location: USA
Looking great man! Awesome job brazing for sure! And i like the Dodge! you dont see to many of them around. I wish a good hard body was available, but the lexan looks good. |
01-23-2015, 11:45 PM | #27 |
Worked on the axle truss mock-up a little. Got both lower link mounts and the shock mounts mocked up, need the servo and upper links now. Set the axle, with the lower links, and the scaler powerstrokes off SuperDrty under the chassis, all kinds of clearance underneath, after the axle gets clocked to move the driveshaft upwards anyway. -Derek Last edited by SuperDrty; 01-23-2015 at 11:49 PM. |
01-24-2015, 04:09 PM | #28 |
Quarry Creeper Join Date: Jun 2008 Location: San Antonio
Nice to see more Dodge builds popping up! Nice job and sick fab work!
01-24-2015, 05:04 PM | #29 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
SLIMER lives!!!!! great build cant wait to see it in person!
01-24-2015, 05:16 PM | #30 |
Rock Crawler Join Date: Dec 2007 Location: Maple Grove, MN
Great looking build! Going to have to keep an eye on this one for sure!
01-24-2015, 05:31 PM | #31 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
Nice wheel choice!
01-24-2015, 05:42 PM | #32 | ||
| Re: Slimer, 1.9 Ram aluminum "tuber" Quote:
Just got back from picking up some hardware, and more MAPP gas, as my current tank is just about done. I'm going through a lot more of it on the aluminum than I did with the brake line on the last build. I'll be doing some reworking on the truss mockup, as when I clock the axle more, it raises the links higher than I like, and the shocks too far forward for what I want. I also want to get my lower link mounts on the chassis. I'll have more pics later -Derek | ||
01-24-2015, 11:06 PM | #33 |
Didn't get as much done tonight as I had hoped, moved where I was working after a quick cleanup, and then got distracted by the Supercross race. Got the lower link mounts on the chassis side made, but not brazed in yet. -Derek |
01-25-2015, 02:31 PM | #34 |
Tabs are brazed in, but I got a lottle too much heat in the one, and it started to deform, the hole locations are still good though, so I'm rolling with it. at this point, the thinner tabs are becoming a royal pita, haha The wire was wrapped tight around another screw, and served as a coupler for the screws on both sides to hold the spacing somewhat square. -Derek |
01-25-2015, 05:58 PM | #35 |
Mocked up the lower links -Derek |
01-25-2015, 08:36 PM | #36 |
Set a set of upper links in the general area they'll be. With how I want to mount the servo though, I may need to use a bent link on the one to the left in the pic, I'll have to wait until I mock that in place to find out for sure though -Derek |
01-26-2015, 05:55 AM | #37 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
I'm digging this build. Really cool that you're able to braze this outta aluminum.
01-26-2015, 08:50 PM | #38 |
Took the truss mock-up off the front axle and traced it onto the 18ga steel twice, since the truss for the rear will just be a mirror of the front. Once these are made and mounted, I'll mock-up the servo mount on the front. The upper link mounts will just be a thick tab centered on the top of the truss, so there wasn't much need to mock it up, I'll braze it in, and that will allow me to set the upper link mounts on the chassis. -Derek |
01-27-2015, 07:44 PM | #39 |
Well, got the rear truss cut out, folded, and tacked together, the Front I have about 75% cut out. It took me about an hour to get that rear truss as far as it is, I'll braze it together soon though. I threw the rear axle under the truck, and threw the rear shocks up there too. I just used some zip ties to hold the shocks and upper links on the chassis, and the rear half is a semi roller. -Derek |
01-27-2015, 09:20 PM | #40 |
How did you get such clean lines on the sheet metal?
Slimer, 1.9 Ram aluminum "tuber" - Similar Threads | ||||
Scale "hydraulic ram" steering linkage by Carter Fab | SlowGrynd | Axial SCX-10 | 0 | 05-06-2012 01:46 PM |
