01-27-2015, 04:18 PM | #1 |
Quarry Creeper Join Date: Nov 2009 Location: Australia
| Defender 110 Single Cab
Hello again Gents (and possibly girls!) Sam has started another project. Some of you will have seen this on Facebook already. I recently purchased a Gelande II D90 kit at roughly the same time that the 110 kit was released. I prefer the 110 of any configuration, but couldn't spring for the pricetag of the 110 kit (especially with the exchange rate of our dollar at the moment too). So figured I'd start with the 90 and modify it from there. I have the 110 frame on it's way instead of the kit issued 90. Like many members here, i wanted to build something that is typical to what you'd see on the roads around my local area. From my experience, 110's are more popular here than 90's and as you've seen already from build's such as Delux's flatbed, Ute's of any make are an Australian icon! So here's my project. i started kinda backwards, doing what work i could while waiting for parts to arrive. Started with part of the tray accessory, based entirely on measurements. A lot of reading, re-reading, checking my 90 body, checking with other owners. A hint here, RC4WD quote the length of the D110 body on their website as 570mm......wrong!! After getting H2Micro to measure his, it's more like 510mm!! Good thing I checked before starting that! So Sam started with the cage that will sit on top of the tray. Mesh from a magazine holder from my local office supplies warehouse. The top like that is unfinished. The four corner parts that stick up too far will be trimmed and there will be diamond plate added to the top, and possibly a roof rack. |
01-27-2015, 04:19 PM | #2 |
| Re: Defender 110 Single Cab |
01-27-2015, 04:19 PM | #3 |
Sadly, the body arrived with a gaping hole in the roof. But luckily, they provided a template to use to fill it in. More finishing work has been done, I just haven't photographed it properly! Now we get to the more interesting part and bringing this build up to the current point, so it will be in "real time" from here. I'm using the rear window kit from Thescalerstore.com in Italy to do the conversion to the single cab. Offically my first experience with 3D printed parts and I must say, I am extremely impressed with the quality and fit. They've really done their homework in designing these parts to fit perfectly to the body. Here we go, it's now or never Sam! After some filing and sanding, the roof section was fitted. A pretty close match up even before I did any finishing. |
01-27-2015, 04:20 PM | #4 |
01-27-2015, 04:59 PM | #5 |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
I just gotta know ........... what are the 10 reasons I love you are ?? . Styrene work is passable ..... but I think we are more interested in the 10 reasons !! |
01-28-2015, 05:18 AM | #6 |
01-28-2015, 06:13 AM | #7 |
I wanna be Dave Join Date: Apr 2007 Location: clarksburg
Very cool! I like the safari look it has.
01-28-2015, 08:50 AM | #8 |
Looking real good . what's the wheelbase on the 110 kit ??
01-28-2015, 11:28 AM | #9 |
RCC Addict Join Date: Jun 2009 Location: Australia
Looks great mate. Top work as always and following.
01-28-2015, 01:06 PM | #10 |
Quarry Creeper Join Date: Jan 2012 Location: Mooresville, NC
Shaping up to be a very sharp looking build. I recently purchased the rear cab section for my next build, so I was wondering what glue you are using to bond the 3D part to the styrene?
01-29-2015, 04:28 AM | #11 | |
| Re: Defender 110 Single Cab Thanks. Thanks. I believe its about 330mm. Thanks mate. Quote:
Got the tray mounted up tonight. It uses the upper shock mounts and some bracketry I made up from alu angle and styrene. Countersunk screws on the top as these will be covered by the diamond plate. Those big chunks of styrene will be mostly covered up by everything else going on, so won't looks so clunky in the end! And a nice little hidden away yet easily accessible spot for the battery. Last edited by shannwah; 01-29-2015 at 04:38 AM. | |
01-30-2015, 03:46 AM | #12 |
Some more progress on the cage. It will be removable, so I can change the cargo or whatever whenever I like. Had to work out a way to secure it though and still have accessible screws or mounts or whatever. I cut 2 holes in the roof to fit a screwdriver, then used magnets to hold on the diamond plate. Here you can see magnets holding the inner magnets in place while the glue dries. And slowly getting there with the roof. |
02-01-2015, 02:52 AM | #13 |
The roof is coming along. It's at a point that looks fairly good to me (to my dodgey eyes anyway!). This is my first serious work using putty so i'm still feeling my way as I go. The 3D printed parts needed a lot of finishing and being a harder plastic, I was getting nowhere trying to sand the lines out, so thought it best to fill the surface. I think it took about 5 applications of Tamiya putty with sanding in between each to get to this point. I guess it's when I apply primer that will be the true test right? Still a hole to fill in this pic! |
02-01-2015, 06:42 AM | #14 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
Nice lines!
02-01-2015, 09:51 AM | #15 |
Quarry Creeper Join Date: Nov 2007 Location: Sacramento
Amazing work! I love the creativity in your build thread. I look forward to some updates.
02-05-2015, 10:25 PM | #16 |
Thanks guys! Fitting of the back wall of the cab and window. The window is clear plastic saved from some packaging of some sort, glued in with CA. For the real wall, first a piece of 2mm styrene sheet was added to fit inside of the body. The bottom of the rear window piece has a lip that this fits into. Angle was added to the inside for strength. Then 2 more layers of 0.5mm sheets were added to cover the joins on the sides and overlap the edges. These were then trimmed off. Some finishing touches were added to fill in some gaps at the bottom of the window section at the corners and some strips were added to the rear wall just to add a bit of texture, these will mostly be covered, but anyway! I believe this signifies the end of the body construction phase. Maybe some more finishing of the roof join will be done after primer is applied. |
02-11-2015, 03:31 AM | #17 |
02-11-2015, 03:55 AM | #18 |
NICE.......and more NICE!
02-16-2015, 03:27 AM | #19 |
Thanks. Have started doing some weathering. I am taking it real easy as i don't want to overdo it against the white. So far I've used an earth wash from Games Workshop called Agrax Earthshade and a purchased pre-mixed blackwash. I totally botched up the windscreen in more ways than one! So will be ordering another one and not much more weathering will be done until I get it. i don't want to get a mismatch! How embarresment! This turned out nice though.... |
02-21-2015, 03:13 AM | #20 |
Defender 110 Single Cab - Similar Threads | ||||
New To RC want to build Defender 110 | mkiii97 | Newbie General | 6 | 01-08-2014 03:33 PM |
defender 110 of rcmodelex and defender 90 of rc4wd on the rails | gionata78 | Scale Videos! | 2 | 04-15-2013 05:00 PM |
Defender 110 project | gegegum | 1.9 Scale Rigs | 112 | 01-16-2010 12:31 PM |
Defender 110 | ScGRaceR | Chit Chat | 2 | 12-31-2006 10:15 AM |
