04-26-2015, 11:29 PM | #1 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
| White Knight , my class 1 bronco
i decided a little while back that i wanted to build a class 1 rig , i had some of the parts already in the hobby room (it's always a good time to acquire new parts ) . i wasn't sure what exactly i wanted to build vehicle wise , so i went to the hobby shop and looked through there body selection . i finally decided on a 73 bronco body , next to pick out a color ....... the chassis and driveline in the pic isn't what i used . finally decided on the color scheme insert O.J. jokes here ....... |
04-27-2015, 12:31 AM | #2 |
| Re: White Knight , my class 1 bronco
with the paint now decided i turned my attention to the drive train , most of the chassis was a pretty straightforward choice ( SCX-10) . i opted to use a set of pro-line scaler shocks that i had aquired a couple months prior , at first i was worried that the springs on the shocks were going to be too stiff but after driving it i believe they are perfect . i had a set of axial 1.9 beadlocks sitting on my shelf along with a set of MTHEAD delrin rings plus all the stainless hardware for mounting the rings , just needed a set of tires to pull it all together . looked at the scale comp rules and found the max tire size was 4.19" so i bought a set of the 4.19 baja claws and proceeded to kill my hand and wrist putting in all the little screws |
04-27-2015, 12:45 AM | #3 |
| Re: White Knight , my class 1 bronco |
05-19-2015, 10:59 PM | #4 |
05-19-2015, 11:14 PM | #5 |
05-19-2015, 11:27 PM | #6 |
05-19-2015, 11:34 PM | #7 |
05-20-2015, 03:06 AM | #8 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
Nice to meet you at the Disney event... your little bronco looked good and performed pretty well also !! That place was pretty awesome, it was my first time out there...sooooo much to do and crawl..
05-20-2015, 10:00 AM | #9 |
Quarry Creeper Join Date: Apr 2012 Location: Toronto
How do you like the small Baja Claws? I just started sing them too and was pretty surprised how well they hook up. And this is after using Pitbull Rock Beasts...
05-20-2015, 04:20 PM | #10 |
| Re: White Knight , my class 1 bronco it was nice to meet you as well , Disney is a fantastic tons to explore and crawl . you should try to come out to the event in october Crawlapalooza is all kinds of fun
05-20-2015, 04:23 PM | #11 |
| Re: White Knight , my class 1 bronco i really do like the small baja claws they perform very well with a suprising amount of traction , i am still experimenting with the foams in them ( think i am going to go with a set of crawler innovations foams for them ) i have a set of the pit bull rock beast 2's on my unimog but they were too tall for class 1 .
09-06-2015, 11:52 PM | #12 |
well we went out and explored some trails in my area trying to find places to go have fun with our trucks , it was a decent area ran through some mud and water ( didn't get a chance to clean it up after .......for a while )needless to say i had to repair a few things ....all of the bearings in the front axle were shot , the knuckle bushings were rusting and causing alot of binding and drag . also my original battery/electronics tray was plastic that i built ( it finally broke ) by chance i had just won a battery tray/electronics tray from HOWLER R/C at the goat hill challenge so in it went . i also discovered that the steering link between the knuckles wasn't bent properly so it wasn't allowing the steering to turn to it's potential ( rebent it ..works good now ) |
White Knight , my class 1 bronco - Similar Threads | ||||
LC Custom Crawlers "White Knight" Class 3 JK Hardbody | jtessmer88 | 2.2 Scale Rigs | 2 | 12-29-2014 09:58 PM |
The White Knight Fastback | TOMCAT18T | Axial AX-10 Scorpion | 10 | 08-08-2010 02:51 PM |
Project White Knight | ECAMERON87 | Tamiya TLT Crawlers | 17 | 09-29-2005 07:30 PM |
Project White Knight, Sancho's version | SuperSancho | Tamiya TLT Crawlers | 36 | 08-09-2005 12:45 PM |
