01-15-2017, 07:38 PM | #1 |
Rock Stacker Join Date: May 2015 Location: foresthill
| Mattzilla Unimog build
Always loved the Unimog builds on here so once I got the chance to buy a Mattzilla chassis I jumped on it. I'm building two trucks now so this might be a slow build. Thanks for looking... Parts...listed below Mattzilla chassis SSD links SSD Panhard SSD axles SSD winch Savox servo HH 35t motor Vanquish leds Gmade wheels Rc4wd military tires Vanquish Trans w/steel gears Scale hardware Sent from my SM-G935V using Tapatalk Last edited by kingofparad1se; 01-31-2017 at 09:20 PM. |
01-29-2017, 02:37 PM | #2 |
| Re: Mattzilla Unimog build
Removed the vinyl added some scale items and deadbolt interior. Sent from my SM-G935V using Tapatalk Last edited by kingofparad1se; 01-29-2017 at 02:40 PM. |
01-31-2017, 12:16 PM | #3 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
So you own this rig now? I use to have it and traded it. Have you ran it yet?
01-31-2017, 09:19 PM | #4 |
Just ran it around the house..do you have any pics of it when you had it??? Post if you do...thanks! Sent from my SM-G935V using Tapatalk |
02-03-2017, 01:47 PM | #5 |
I ran it once on the trail and it worked well. I have it on Currie F9 with Voodoo KLR tires. This pic is after that Sent from my iPhone using Tapatalk |
03-23-2017, 08:30 AM | #6 |
Changed the shocks up for less travel and added 250lb line to the winch...ive been running it alot to dial it in. Last edited by kingofparad1se; 03-23-2017 at 08:36 AM. |
04-25-2017, 09:17 PM | #7 |
Update...I swapped the motor for a HH 2700kv brushless set up with a castle MMP. Added new ottosix two stage foam. Sent from my SM-G935V using Tapatalk Just dialing in the shocks and esc settings... Last edited by kingofparad1se; 04-25-2017 at 09:20 PM. |
06-16-2017, 08:59 PM | #8 |
Well got home after my first local comp with the truck..it didn't perform as well as I wanted it to so time for some adjustments.. 1.9 assassin wheels with C.I foam and KLR tires Changed the rear shock mounts Also wanted 1.9's on it so I adjusted the front..made some clearance I also added a high clearance skid Also got O.D and under drive HD gears with new spools. That's all for now..lol Sent from my SM-G935V using Tapatalk Last edited by kingofparad1se; 06-16-2017 at 09:08 PM. |
Mattzilla Unimog build - Similar Threads | ||||
My REDNECK CLOD build via Mattzilla | I.D.10.T | 1.9 Scale Rigs | 80 | 06-10-2015 10:11 AM |
****my mattzilla tundra build!!**** | jhop1 | 2.2 Scale Rigs | 9 | 05-13-2013 02:20 AM |
