07-03-2018, 04:15 PM | #21 |
Quarry Creeper Join Date: Jun 2012 Location: Washougal
| Re: Crazed Jeep JK Skeleton
Soo.. I am going to post this on each of the vehicles involved, But I got a big set of Axial trail markers.... I also happened to have 7 trucks running....Tamiya Prerunner, SCX10 Toyzuki, SCX10II, TRX4 Bronco, SCX10II Deadbolt, GCM Skeleton JK, and the SCX10 BFD Deadbolt. Lined up and ready to play.... (Tamiya was an afterthought) So, there are 7 Videos, each one is a stage, I totaled the time after each stage. This was a no practice run it how you brung it type. If I rolled over I started over. Hope you like it, I found it to be interesting. Stage 1 https://www.youtube.com/watch?v=JU8fciEh5eA Stage 2 https://www.youtube.com/watch?v=is3HfpxEpZU Stage 3 https://www.youtube.com/watch?v=C51HLRLKiSo Stage 4 https://www.youtube.com/watch?v=R94yAs2dtp8 Stage 5 https://www.youtube.com/watch?v=VV9u_pQgGJo Stage 6 https://www.youtube.com/watch?v=WEroQK8otdo Stage 7 https://www.youtube.com/watch?v=Dp9cG9Dfmeg&t=6s Bloopers.. https://www.youtube.com/watch?v=Fs7x4nBwNeA So things I figured out.. the scx10II has a bad ESC, the JK struggles, and the SCX10II Deadbolt is pretty good right out of the box. After Pics... Fun stuff, thanks for watching. |
07-26-2018, 12:04 PM | #22 |
| Re: Crazed Jeep JK Skeleton |
11-20-2018, 09:41 AM | #23 |
Picked up some BeefTube knuckles for Ascender as the axles in these use those components. This thing is pretty light in the nose even with the motor up front like it is. Before.. Off.. Comparison.. Beef tubes uses a larger inner bearing... Back together.. Other side.. And done.. Videos... https://youtu.be/yzkngbbLilE https://youtu.be/u2Lp0WIMzD8 |
11-30-2018, 12:36 PM | #24 |
Finally decided to do a little trimming on the Jeep. First to go was the little flat area under the doors.. Next, This bumper hits everything so its time to go. And a cut... Bumper from an Axial Deadbolt will work... Lots more room up in front.. Body bolted back down, bumper fits better now.. And went for a ride with the scx10II Deadbolt... https://youtu.be/An8p_MFbkYs |
12-01-2018, 09:57 AM | #25 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Nicely detailed build Crazed. Where’d you get the drive shafts sir? TFL??? The GCM chassis is very well done IMHO....I have one...they could have included instructions but pictures sure do help...you have a ton And items I never heard of before (body mounts and the shapeway stuff) Damnit....time for more shopping Nice job! |
12-01-2018, 02:14 PM | #26 |
Thanks man! this is a really cool rig to work on. Now for the back, you can see where the bumper catches everything! UUUGly without the bumper.. Set a Deadbolt II front bumper in place to see what it looks like.. Yeah...needs a trim. Just for fun, a OG Deadbolt front bumper with the spare tire crammed into it... Ok, now time to get a little more serious... This is how I laid out my proposed cut lines.. I did a horizontal line across the wheel well then drew an angled line down to the body tub...You can see from all the gouges in the body, this is what seems to hit the rocks on the trail. Should stop a lot of the rubbing that I have even with the 4.19's Next post...Cutting!!! |
12-01-2018, 03:11 PM | #27 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
LOVE the JK bodies. Just bought another 1 from eBay
12-02-2018, 03:59 PM | #28 |
Ok, here we go, First cut... Then same cut in the front, then grind around with a sanding drum.. Same for the front, cut...cut.. Grind. Like so.... The 4 corners of tape measure flex... With 4.55 Pitbulls... 4 corners again... Up front , back with the 4.19s All the debris... I think it turned out well, should be better wheeling with less rubbage and rock catching on the fenders. |
12-03-2018, 02:36 PM | #29 | |
| Re: Crazed Jeep JK Skeleton Quote:
12-03-2018, 04:11 PM | #30 |
Thanks... And nice job on the cuts, you are braver than I am. I’ll try a 1.5 wheel/tire combo and hopefully won’t have to cut |
Crazed Jeep JK Skeleton - Similar Threads | ||||
GCM's Skeleton J2 Chassis Combo Kits for Jeep JK 2dr | Generis | Chassis and Suspension | 41 | 01-31-2017 01:32 PM |
Jimbo_wa's 1/9th GCM J2 Skeleton Jeep | jimbo_wa | 1.9 Scale Rigs | 26 | 06-21-2016 09:12 PM |
Brads Jeep Skeleton | MaxxPain | 1.9 Scale Rigs | 21 | 04-16-2015 08:42 PM |
GCM Skeleton J2 Chassis w/Jeep 2dr body | BKcrawler | Scale Videos! | 0 | 04-08-2015 10:39 PM |
