Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Brocky - KOH 4500 class replica
Old 03-09-2018, 03:15 AM   #1
Default Brocky - KOH 4500 class replica
This is already over in the twin hammers section, but ita a mess of pre build mods and new stuff.
See here for the inspiration speedhunters.com/2016/12/meet-brocky-vaughn-gittin-jr-s-latest-toy/
To start off, the chassis setup.
Custom long travel front suspension setup.using AE B5m arms, traxxas slash ultimate CV.s and some hacking and.fitting. Gains half an inch of travel but more importantly, way more reliable CVs. Paired with 100mm kings.
Upright shock mount and bellcrank steering
VP rear trailing arms with 110mm kings.
Metal gear trans running the 2 speed.
Electronics wise its a mamba X, Holmes torque master 3500kv and a hacked flysky 3gtb. Spectrum s2640 steering servo and a Jx waterproof shift servo.
Lighting is controlled by two HeyOK controllers.
This is my first time ever brazing so learning as I go.
Just got a 3d printer also, so dash and interior is being designed.
Grille was designed and printed by myself.
Really struggling now with the front end cage construction.
Sent from my Pixel using Tapatalk
nedmo is offline   Reply With Quote
Old 03-09-2018, 03:37 AM   #2
Default Re: KOH Vaugn Gitten Jnr "Brocky" build
Have also designed up all the decals I will need.
Have ordered scale hardware from lockeduprc to finish the wheel build and also added a commando winch upgrade kit. Adds a free spool to the 3racing winch.
For the rear lights will be using a Maddog RC KOH light bar plus some eBay special angel eyes to replicate the tailights setup.
Old 03-12-2018, 12:33 AM   #3
Default Re: KOH Vaugn Gitten Jnr Brocky build
Light bar done.
RPM light buckets on 3d printed bracket.
Also, working on a rear cab panel, with integrated rear brake light bar mount and Axial radiator mount.
Just needs a bit more tweaking.
Old 04-07-2018, 05:47 PM   #4
Basically all major components bolted on. Now just a bit more bracing and panel mounting. Then onto hours of die grinding all of my heinous brazes!!!
Old 06-04-2018, 07:26 PM   #5
Default Re: Brocky - KOH 4500 class replica
Bit of progress.
Sandblasted and primed!
Old 06-06-2018, 05:10 PM   #6
And painted!
Now just waiting on a package from Amazon with some VP front end goodies and also got to design and print some last minute parts
Old 06-07-2018, 05:56 PM   #7
Big day in the workshop! Fitting time.
First up was final pre paint panel fitting. Few little niggles and not 100% alignment but even the 1:1 has misaligned panels.
1 side done.
Old 08-25-2018, 08:45 PM   #8
Fresh out of the paint booth!
Old 08-26-2018, 06:42 AM   #9
Looking great with the color on it.
OSRC is offline   Reply With Quote
Old 08-28-2018, 07:35 PM   #10
Started running the wiring looms onto the chassis!
This thing has a rediculous amount of electrics
- Mamba X utilising AUX, internal BEC running the shift and steering servo @ 6v
- Two speed shift servo, using a servo reverse on AUX to turn crawler mode on in low, rock racer for high gear.
- Custom HeyOK light controller running the roof lights, park lights, MaddogRC KOH bar, tails, brakes, hazards and reverse lights.
- Second HeyOK single output controller with 3 brightness levels running the front 1w headlights.
- Bluetooth RGB controller for colour changing demon eyes in the 1w headlights
- Bluetooth RGB controller for colour changing rock lights
- 3racing winch controller
- LED voltage readout in the dash.
All controlled with a hacked Flysky g3tb radio with 6ch RX.
Old 08-28-2018, 08:00 PM   #11
that is a lot of wiring, looking forward to seeing this completed. great job!
zohn is offline   Reply With Quote
Old 09-01-2018, 01:35 AM   #12
And all decaled up. Waterslide media is a challenge but great out come.
Old 10-31-2018, 08:55 PM   #13
And it's on the rocks!!!
Brocky - KOH 4500 class replica - Similar Threads
Vaugn Gitten Jnr "Brocky" build nedmo Vaterra Twin Hammers 45 06-09-2018 04:46 PM
1.9 U4/KOH build "SCROTAMUS" the scrap yard racer distinctive pd 1.9 Scale Rigs 17 11-03-2017 01:19 PM
Mighty's IFS KOH/Ultra build. "Outcast" Mighty1 1.9 Scale Rigs 27 06-28-2014 07:06 PM
BGR KOH Style Build "Bodi-Size" BodiBuilt Axial Wraith 33 10-27-2013 07:07 PM
