![]() | #1 |
Quarry Creeper Join Date: Dec 2019 Location: California
Alright, time to start the build thread for this project. Some of you might have seen my excessive question posting from the past few months, and here is where it leads up to. Build: An SCX10ii based Raptor Prerunner, somewhat inspired by the Deberti Designs Raptor, with and Element Ifs Kit. Heres the car it's based off of. As a warning, I am starting this thread fairly early, as I don't plan on purchasing the marjority of parts for this build until Black Friday, but I figured I could get some suggestions from the beginning of this forum before I go full out. I'm going with a 10.2 Raw builders kit, like mentioned above, element ifs kit, and Proline raptor body. Some basic specs: -Traxxas GTS 110mm long arm shocks, to be drooped extremely. -Unfilled cheap Amazon shocks for looks only, if it hampers performance ill probably just ditch them -Rear sway bars from a Slash -Ssd Diamond axle because the VP curries are just too dang expensive Nothing too much in terms of performance upgrades....but the raptor body is going to get chopped so its only the cab, a Proline cage is going to be mounted on the rear, with fenders/rear from a Jconcepts Illusionz Raptor SCT body mounted on the sides, for that wide bodied look. wheels will be run off of hex extenders. I'm planning to spray the body a gunmetal grey, which may or may not change, but every piece of lexan is going to be wrapped in a 3M shadow black wrap, which is %#*@*$# expensive, but worth the looks imo. Yes, it's probably going to end up as a shelf queen, but I figure if it does end up being scratched and beat up, I could rewrap t. I've wrapped a body once with some cheap wrap before, turned out pretty nice, but it was a basher so..self explanitory as to its current condition. It started out as "it would be cool to have one of these" RCs, but I've decided to give the build the green light and go. |
![]() | #2 |
RCC Addict ![]() Join Date: Jun 2006 Location: Here
P8ctures, or it didn't happen!
![]() | #3 |
One thing of note. The proline cage is Narrow! Like really narrow. Honcho width is only 6.5" wide at its widest. That might or might not be a problem for your build. I love the prerunner style and cannot wait to see more. |
![]() | #4 | |
| ![]() Quote:
This guy on insta did the same thing https://www.instagram.com/p/CBD16F1jKl4/ | |
![]() | #5 |
![]() | #6 |
So I am contemplating between getting an Axe system or Mamba X, I own both, but can't decide which one to use for this build, Axe is cheaper, but Mamba offers more power, which I probably won't need, but it also offers more fine-tuning and adjustment. But I also have been wanting to replace the axe system in my main rig(I've stripped 2 screws on it so I can't give it any maintenance and the bearings are starting to make funny sounds at high throttle) , give the new system to it , and give the old one to my current build because it requires less low speed control. |
![]() | #7 |
Sorry for the long wait, but this build isn't dead yet! ![]() Just ordered the 10.2 RBK, ssd Trailing arms, Proline cage, raptor body, and 60ft of 1/4in nylon rods to be safe. Doesn't arrive until 28th though :( My plan is to start with the cage (obviously build the kit first), and build it off of the proline cage, which will be chassis mounted. I'll get some pictures in soon. |
![]() | #8 |
RCC Addict Join Date: Jun 2020 Location: Big Island
Sweet man! looking forward to seeing progress! Sorry if I missed it, but what body will you be using? I ask because I've only seen ext. cab Raptor bodies and the DD is crew cab. |
![]() | #9 | |||
Sketchiness abounds... ![]() Join Date: Jun 2016 Location: Austin
| ![]() Quote:
![]() | #10 | |
| ![]() Quote:
Thanks for proving my point ![]() I asked because the DD is 4 door, not ext. cab. Maybe you should’ve read my post all the way through? Sent from my iPad using Tapatalk | |
![]() | #11 |
Rock Crawler Join Date: Dec 2014 Location: So Cal
60 feet of rod???? It takes roughly 15 feet to build a scratch build TT, so practice will make perfect. As for the electronics, go cheap because you can unless you are bent on Castle or such, because it doesn't matter on a go fast rig. Pics required!!!
![]() | #12 | |
| ![]() Quote:
![]() But I've got some other uses for them too. I recently got the AxeR2 for another rig, so I swapped that out with the axe R1, which will probably power this rig. | |
![]() | #13 |
| ![]() It a Proline 12.3 ext. cab, but I'm not bent on making an exact replica. The whole rear bed is going to get chopped so it won't matter too much.
![]() | #14 |
![]() | #15 | |
| ![]() Quote:
I'm trying to help you use the forum more logically. What you asked was "What body are you using?"... I highlighted the body he is using in friggin' RED. Then I highlighted the mods he mentioned in BOLD. Maybe I should have also added and highlighted his introductory statement like so: "somewhat inspired by the Deberti Designs Raptor" I'll chalk up the snark in your response to an unwillingness to bother with reading forum threads and instead just jump in repeatedly and ask questions that are staring you right in the face literally inches higher up the page - just like the way every time you respond to a post with pictures in it, you ALWAYS repost them in your reply. You can edit those out, for the sake of the flow of the thread. Part of participating in a forum, especially when you're new and (as you've admitted) young, is a willingness to try to follow accepted forum etiquette. I'm out. Have yourself a lovely day, and enjoy your crawlers during the holidays. | |
![]() | #16 | |
| ![]() Quote:
I guess it comes down to my wording. I admit, I didn’t see that he was using the Proline body. It’s easy to skim over it in a long post. I read all the threads I respond to, just sometimes I miss something. We’ve all done it. As for the pictures when quoting, I always forget about that as well. I’ll start doing that. I do apologize for my disrespectful response. like you said, your just trying to help. Merry Christmas! ![]() Sent from my iPad using Tapatalk Last edited by ScaleLifeNewbie; 12-24-2020 at 05:42 PM. | |
![]() | #17 |
![]() | #18 |
So the SCX10ii RBK kit got delivered on the 24th instead of the 28th, so pretty happy about that I build up the kit, but cut the battery tray and reciever box to make way for the 550 motor and future TRX4 transmission swap. Proline cage is mounted directly on to chassis, with a 3d printed attacher that slots through the rear bumper/LED slots. The front cage is built with 1/4in nylon rods. I was going to use screws, but drilling holes in nylon is apparently really hard, so most of it's currently held up by CA glue. I'll probably mold some black JB weld around contact points for some extra impact strength. I've only got the basic tube chassis shape down, still a long way to go. Heres it mocked up with the Proline Raptor body, I cut the rear fenders for the cage. i was going to remount the fenders on the sides of the cage, but made the cuts too early, and when I mocked up the body with the cage in, the fenders sit too low, so I'll still have to go with the SCT fenders. I am still waiting for the SSD trailing arms, when I get those I'll probably take it out for a light test. |
![]() | #19 |
I'm not sure the CA glue will hold up very well, if I put some JB weld for plastic:https://www.amazon.com/J-B-Weld-8237...05054381&psc=1 around the joint, will it hold well? or should I reglue the tubes with JB weld one by one? |
![]() | #20 |
Or would this be better? https://www.amazon.com/J-B-Weld-5013...51&sr=8-2&th=1 |
Start of a new Deadbolt project. Lets call it Project: Cheapbolt | Prime | Axial SCX-10 | 211 | 01-07-2017 10:53 AM |
