10-19-2010, 08:54 PM | #1 |
Rock Stacker Join Date: Sep 2010 Location: Tomball
| TC5's High Lift (Suggestions Needed)
Well Hello everyone I just signed up on here about a month ago and I have to say this place is awesome!!!! With that outta the way. I got my first crawler about the same time I signed up and it's an AX10 but that's for another thread. So on to the Scaler. I just picked this from a friend and got a smoking deal ($150) it started as a Toyota Hi-lux and since then he added the frame rails for the F-350. He also got some 2.2 Rock Crushers on what looks like Revolvers installed, drove it a couple of times took it back apart to where you see it now. It also came with a 4 channel Futaba stick radio probably not gonna use it though. Does anyone know who made these Frame rails? Just wanted to post up some pics get some feedback as to what works and what doesn't work. I would like to get some more articulation but still keep the leafs if it's possible. Some of the things I was thinking about doing was.... Delrin springs (any good or do they fall apart?) RC4wd Mud Slingers Beadlock Wheels New Scale shocks Axle upgrades??? (How do I get rid of the rear steering set-up?) What else do I need to make this perform OK guys give me your input!!! Last edited by -TC5racer-; 10-21-2010 at 08:40 AM. |
10-19-2010, 10:10 PM | #2 |
Newbie Join Date: Nov 2007 Location: Springfield MA
| Sweet
Sweet deal. Chassis is a Junfac http://www.junfac.com/shop/index.php...2559c4415dcf21 |
10-19-2010, 10:24 PM | #3 |
Quarry Creeper Join Date: Sep 2010 Location: Big hands, Little tools.......GRRRRR
| Cool........
That truck looks like a solid place to start. Try checking the newb section for answers to all of those questions. I am a newb to this site too and have found a TON of great info there and by just reading build threads. The "Search" tool is also VERY helpful. Just my opinion, but I would start with losing that huge bull bar out front. Where to go from there? Pick something and go for it! Can't wait to see some progress on your build! Good luck! |
10-20-2010, 02:26 AM | #4 |
Quarry Creeper Join Date: Aug 2010 Location: Tupelo
Looks great so far!
10-21-2010, 12:32 AM | #5 |
Pebble Pounder Join Date: May 2009 Location: Sooke
Make the lights working... nice touch on any scaler
10-21-2010, 08:39 AM | #6 |
Thanks Guys!!! As for the leafs any suggestions? |
10-21-2010, 09:12 AM | #7 |
Rock Stacker Join Date: May 2009 Location: allentown
My opion says swap them for a four link.
10-29-2010, 10:03 PM | #8 |
Newbie Join Date: May 2010 Location: houston
| scale wheet
cool we need our scale course now. get those lights canyans next weekend
10-31-2010, 01:44 PM | #9 | |
I think I'm gonna go for the four link in the front and stick with the leafs in the rear and see what happens. | |
10-31-2010, 02:44 PM | #10 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
g-made sells a fourlink set up for that truck and it works really good .
10-31-2010, 04:25 PM | #11 |
Thanks Warrior I'll check it out!!
10-31-2010, 06:25 PM | #12 |
Rock Crawler Join Date: May 2007 Location: floriduh
10-31-2010, 09:05 PM | #13 |
11-07-2010, 05:10 PM | #14 |
11-09-2010, 09:27 AM | #15 |
now, maybe some mini rock crawler shocks.
11-09-2010, 12:39 PM | #16 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
My friend have the same junfac chassis on one of his 3 high lifts,that would be the one witch allso have all the bells and wistles attached I better mail him a link to this, in case he what to do somthing simmilar |
11-09-2010, 06:51 PM | #17 |
RCC Addict Join Date: Mar 2010 Location: Yelm
Are both mounting points for your lower links temporary?? They sure don't look like they will be able to handle the load/leverage otherwise. Maybe the angle of the pictures? |
11-10-2010, 08:44 AM | #18 |
They weren't going to be temporary until I got them installed and noticed that since I cut them so small I could twist them with pliers...But they work for now and will give me a template for some heavier duty mounts later.
11-11-2010, 06:22 AM | #19 |
I'm a retard Join Date: May 2010 Location: bellingham, Wa.
THE WAY TO GO WOULD be to keep the leaf up front and 4 link the rear and make all the links as long as possible to keep your WB the same, your upper links are too short. all you need are some 80mm shocks from like RC4WD or RPP and use those with the leafs up front with no springs and in the rear with a semi droop setup, then go with 1.9 wheels and tires man, it will be way more scale and look a lot better too, what you could do if money is an issue, get the Axial 1.9 bedlok wheels and some new ProLine TSL SX's 1.9!!! great setup and the tires arent much smaller than Mudslingers really. and if you can, get rid of that whole tranny setup and toss in an Axial or RC4WD R2 trans and some nice driveshafts but for sure a better way to go would be leafed front 4 link rear, BUT you have a great 4 link truss to use if you need it . and the links are GREAT, cant go wrong with revo ends and all thread tubed! please dont get mud slingers tho, they arent a good tire in 2.2, they are OK but there are way better tires, go to RC4WD.com and look at the new TSL BOGGER 1.9's they have, they would look killer!! or the PL Swampers!! hope this helps! oh and try to get your pinion angle pointed up more front and rear!! |
11-11-2010, 10:53 AM | #20 |
Thank You for the advice. Seeing how this is my first scale build I needed all the help I can get. On the 4 link in the rear I had thought that might be the case but I hadn't got any feedback on it and the stuff I found was with it in the front so I went with it. What are the reasons it would work better? You talk like you have done this and if so how did it work? I think I'm gonna go ahead and switch it around because in my head it just makes more sense, but I would still like to hear you reasoning. As for the wheels YES I am changing those out to 1.9's because like you said 2.2's just don't look right on this truck. I guess I'll have to change to the 1.9 section soon. Tranny wise..... I finally drove the truck for the first time yesterday and the tranny was already having issues but that might have been from the assembly by the first guy because after I took it apart and reassembled it's shifting great. But I know a new one is going in real soon. For the shocks I was just wondering what size to order and what set-up to use in them. And it looks like you pointed me in the right direction. Thanks Again and I guess I'll get out to the shop and start working!!!! |
