04-13-2011, 03:23 PM | #1 |
Quarry Creeper Join Date: Jul 2009 Location: Missoula
| True 2.2 scale?
How is it possible to have a true scale 2.2 RC? Are you using 1/10 bodies or something bigger? At 1/10 scale a 5.5" tire would be 55" on a real vehicle, which is absurd. I don't understand how it can be true scale with those size tires. I am looking to build a 2.2 scaler in a few months and just curious as to the trueness of the scale tires and wheels.
04-13-2011, 03:35 PM | #2 |
If the tires/wheels look proportional to the body/chassis being used then who cares how it scales out to 1:1. Check out the 2.2 scale sections and see what everybody is running and see how you like the looks. You might even want to run 1.55 wheels/tires to get a better scale look. I like a mix of form and function on scalers. Some that will crawl great and looks pretty close to a 1:1. |
04-13-2011, 03:35 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: akron
Why is a 55" tire "absurd"???? OK this one may be absurd but it looks pretty fun and Yes many bodies are larger then 1/10 scale and some are smaller then 1/10 scale.. |
04-13-2011, 03:42 PM | #4 |
[QUOTE=sloppy;3041682]Why is a 55" tire "absurd"???? It's only absurd for a "Scale" real life crawler. Technically you could build a comp crawler modeled after a full size crawler and call it scale. I am meaning the scale Toyota's, Bronco's, Jeeps, etc. Trucks that in real life are lifted and running 35" or 37" tires and can go out doing trail crawling, but are still street legal. Which is mostly what "Scale" crawlers are about. Modeling after real life 4x4 vehicles that go offroading and are street legal. Cool pics though. |
04-13-2011, 03:46 PM | #5 |
I think you're right about a lot of the 1:10 "truck" bodies. Tuber's tend to look right. I started out my proline bug/scx 10 on 1.9's and they looked to small. When I took a profile pic of a real bug in photoshop and counted how many "wheels tall" it was... the 2.2's fit much better. |
04-13-2011, 04:00 PM | #6 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
I think most of the bodies are more 1/8 scale, like the new bright JK and such. So my tires are only 42"s. |
04-13-2011, 04:06 PM | #7 |
Chassis & Tubework Vendor Join Date: May 2006 Location: Portland, OR
There are so many manufactures of 10th scale bodies and each one makes them a bit different, like all the broncos (there must be 5 or 6 available). Most of us try the best with the parts we have at our disposal to make a scale looking rig.
04-13-2011, 04:11 PM | #8 |
Thanks for all the input, guess the general rule of thumb then is if it looks ok then run it.
04-13-2011, 04:57 PM | #9 | |
04-13-2011, 05:01 PM | #10 | |
04-13-2011, 05:10 PM | #11 | |
04-13-2011, 05:53 PM | #12 |
You won't know the true scale of a body until you scale it out against the 1:1. Even then, some dimensions will be off. HPI Bronco body 1/8.5 scale 19" wheels 47" tires 113" wheelbase It all scales out pretty good with the HPI Bronco body, but if you start with a Tamiya Bronco body you will find it is smaller and closer to 1/10 scale. You do have to build an extreme rig to make 2.2's scale, unless you build a 1/7 scale street rig. Last edited by Grizzly4x4; 04-13-2011 at 05:58 PM. |
04-13-2011, 05:58 PM | #13 |
RCC Addict Join Date: May 2008 Location: Green Bay
Ok so you want a scale 2.2 equiped truck. Go bigger....1/6th scale then. 2.2 Rok Lox scale out to be 32" tires in 1/6th scale.....then you rin into the issue with the wheels being out of scale 2.2 scale out to be 13" rims. Never going to be perfect but sometimes close is good enough. Looks pretty good I think. |
04-13-2011, 06:16 PM | #14 |
RCC Addict Join Date: Oct 2007 Location: gervais
My thoughts have always been, if you want to use 2.2 then build bigger than 1/10 because yes the 2.2 can work for 1/10 scale tire height but not for wheel size, even in toptruck challenges where they have 52" tires, the rims are only 20" in 1/10 scale you would have 22" wheels..... Heck 1.9 comes closer to scale than that if you multiply it by 10. so if you want to go true scale and work with 1/10, don't use the hilux because it's 1/9 scale and for tires and wheels, your gonna have to do some cutting and shutting, that's what im planning on doing one I get a certain 2.2 tire
04-13-2011, 07:21 PM | #15 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
The HPI Bronco body is the perfect scale for a 5.5" tire crawler. I don't think this looks out of scale at all. |
04-13-2011, 07:21 PM | #16 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
It's all in how "right" it looks in relation to the overall rig than breaking down the numbers... unless you are really that fawking anal, who cares?
04-13-2011, 07:24 PM | #17 |
04-13-2011, 07:39 PM | #18 | |
Edit: this is what I think is true scale or atleast what I find as "what looks right" 5.4" tall 1.9 TSL's Sayy what?! Last edited by demonoid369; 04-13-2011 at 07:44 PM. | |
04-13-2011, 07:57 PM | #19 |
What do you guys think? The bug body seems 1:8. I like the 2.2 wheels but think I'll go down a half inch on the tires, I think the Dune X/T's will look really good. 1.9 2.2 |
04-13-2011, 09:05 PM | #20 | |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
