Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Custom 2.2 Scaler Build
Old 07-14-2012, 09:25 PM   #1
Default Custom 2.2 Scaler Build
So im going to be starting a Custom 2.2 Scale Chassis Build soon, got a basic idea of what I want it to look like, and have most of the measurements worked out, Ill post pictures as the build moves along, Ill be using everything off my my ax-10 for running gear/ suspension etc.
Kinda looks like a Humvee
Being in the army I like the idea
Got 3/16 steel rod for the chassis
Some basic Sheet metal to use for panels
Will be getting some 1/4 SS tube for custom links to go with it
Using a wraith skid plate as a base to work off of
Having a friend do all the welding, bending for me because I dont have the tools or know how in that department
Jgraser1 is offline   Reply With Quote
Old 07-15-2012, 09:46 AM   #2
Default Re: Custom 2.2 Scaler Build
So i reworked the design a little bit, going to try and make it look as close to a hmmwv as possible, found a website with a calculator to do all the length conversions I needed.
Back to lowes I go, I need 7ft more rod before I have everything I need
Heres a Picture of the new design
Any comments or Suggestions would be greatly appreciated and taken into consideration as my build goes along
Old 07-15-2012, 10:43 AM   #3
Just ordered my yokohoma geolander tires for it and some revo rod ends for the links, hopefully will get the rest of the metal today. And maybe get started this week, next weekend I'm moving so won't be doing much work on it until the move is over
Old 07-15-2012, 05:03 PM   #4
Like the H1 hummers, will be checking to see what you come up with.
Geolanders are realistic, but not very good for crawling.
If it's just for trails they will be OK, just a heads up.
Modbug is offline   Reply With Quote
Old 07-15-2012, 06:08 PM   #5
thats what my buddy told me today, ill see how they work out, he said theyre a little short, so i may go a different route anyway, hopefully I can get started on it this week but probably wont until the weekend after next, I redid the design again, trying to get it as close to the model hmmwv as I can, got the rest of the rod for the chassis and finaly found the SS tube for the links so we will see what happens
Old 07-15-2012, 06:19 PM   #6
Subscribed, what scale are you going? Independant suspension all around?
Military info if needed, http://en.m.wikipedia.org/wiki/Humvee.
lonleycreeper is offline   Reply With Quote
Old 07-15-2012, 06:37 PM   #7
It will be 1/10 got the info already, thanks though, I'll post the new rough design shortly, I'm sure it will change again soon haha, my head is full of crazy ideas, if I wasn't so set on crawling it I would throw a gun mount up top
Old 07-15-2012, 06:48 PM   #8
Ok here it is, Ive decided this is the final design for the build
Over time I want the doors to open as well as the hood
And plan on making a Hatch in the back but for now this is it
[IMG]Photobucket[/IMG]
I got rid of some of the bracing because there was going to be so much tubing that the rig would have been god awful heavy, and I figured with sheet metal body panels its going to have plenty of structural strength
Comments/ Suggestions are always welcomed, This is my first build so I want it to turn out awesome
Old 07-24-2012, 06:31 PM   #9
Ok so I still havent gotten started, moving took alot of time this weekend, Found the wheels and tire I want, im pretty sure they will be perfect
Humvee 2.2 Internal Beadlock Wheel
MIL-SPEC ZXL 2.2 Tires
Looks like about as close as im going to get, any suggestions?
Old 07-24-2012, 07:16 PM   #10
If you put some creases in the sheet metal it is incredibly rigid. What thickness are you thinking of?
Old 07-24-2012, 07:54 PM   #11
I honestly dont remember what thickness i got, im thinking its reasonably thick though because it doesnt bend very easily, i dropped the piece i bought and one corner folded a little bit but not very much, if that makes sense
Old 07-28-2012, 09:15 AM   #12
Well I'm putting the build on hold a bit longer, getting some trex60 axles for it before I start fabbing, should have them on Monday or Tuesday, might buy wheels n tires first too, and the sheet metal is 1/16
Old 07-28-2012, 12:28 PM   #13
Wow! That is some thick metal. IIRC that is 16 ga sheet metal, it is going to weigh as much as a 1:1. Hehe.
Old 07-28-2012, 04:20 PM   #14
I think that's what it is I kinda just guessed at it, I'll see how it goes
Old 08-06-2012, 12:17 PM   #15
Ok Here it is, Started the Build Finaly!! This post will go all the way up to the base of the chassis and all links minus steering complete
TREX 60 ARB Axles Mounted to some wood with holes drilled to keep everything straight
Wraith Skid Plate with CKRC Wraith Steel DriveShafts
Set it up on a wheel to get some what of an idea for ride height
Used the 3/16 steel rod and hand bent up a base for the chassis
Added in some cross braces for the shock mounts
Shocks Mounted up
Threw some random wheels and tires my buddy had laying around on there to see how it sits
Rear links made from 1/4 SS tube, 8/32 all thread, and revo rod ends
All the links done
Started The outer/ lower section of the body
Added some bracing and called it a night, I know it doesnt look perfect but I hand bent everything and havent welded in years, so its coming along very nicely, Huge thanks to Chris Russell, He gave me all the know how to do the bends, and helped alot with the welding/ cutting
Last edited by Jgraser1; 08-06-2012 at 12:25 PM. Reason: wanted to add more, no need for another post
Old 08-06-2012, 12:28 PM   #16
Its 22ga im slightly retarded sometimes, i figured if i looked at the sticker on the sheet it would tell me what size it is
Old 08-06-2012, 07:11 PM   #17
Looking good.
Old 08-07-2012, 08:09 AM   #18
Looking good.
Thanks! As always comments/ suggestions are always welcome
Old 08-11-2012, 10:36 AM   #19
Alright got to working on it some more last night, Im really liking how its turning out so far!
Start of the back half of the body framing
Threw in some bracing for the windshield and roof
Back fenders Framework done
And door framework done, thats it for last night
Should be doing some more on it today/ tonight
Old 08-11-2012, 10:50 AM   #20
Looks really good so far starting to really show what its going to look like
89lxmorepower is offline   Reply With Quote
Custom 2.2 Scaler Build - Similar Threads
Jeep scaler build and comp micro crawler build droopmodmrc Losi Micro-Rock Crawler 1 12-25-2012 12:34 PM
cr-01 custom scaler bonesaw 2.2 Scale Rigs 1 05-30-2010 12:18 PM
My first custom 2.2 scaler Ax-10Canadian 2.2 Scale Rigs 31 03-15-2008 12:07 PM
