09-14-2014, 09:30 PM | #1 |
RCC Addict Join Date: Nov 2008 Location: Central, WA
| ToyZukis early Bronco Gutted my class 3 to try out my prototype chassis. Goal for this chassis was to angle the skid like a sporty, move the skid forward for longer rear links and shorter up front (personal preference. Extra holes for stock location for those that don't like to build links), added tabs for upper link adjustment, raised the front of the rails to make more room for panhard and drag links under compression, had a few requests to add shock hoops so I did, added my servo mount from my cms kit just to do it. Also made the holes in the rear line up so you can run the stock frame cross member fit behind the axle rather than above it so it doesn't limit compression when the axle hits it. All at the same time as making it compatible with all stock parts, so any aftermarket bolt on should still work. So here's the goods Wide xr mod axles with rear steer and over/unders All metal trans used as tcase with my motor mount up front Toyzuki cms with the winch mount (soon to be released) VP wheels, narrowed pitbull xor MIP shafts Tekin fxr Brood 35t Hitec 7954s f/r Castle bec Kms winch Heyok 4amp Dynamic customs early bronco pulled in styrene (Thanx Devlin) 3/16 brake line cage And more stuff lol! |
09-14-2014, 09:45 PM | #2 |
| Re: ToyZukis early Bronco |
09-14-2014, 11:12 PM | #3 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
About time you started a build thread |
09-14-2014, 11:14 PM | #4 |
More of a built thread!! Still needs interior and trinket points but gonna make a few changes to the toyzuki t case before I do interior!
09-15-2014, 06:52 PM | #5 |
Rock Crawler Join Date: Mar 2014 Location: Yorkville
this is cool, howd i miss this?
09-15-2014, 08:25 PM | #6 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
The roof line and stance is awesome, well done!
09-15-2014, 08:27 PM | #7 |
Thanx guys. I plan to do a little more to the cage but I had a few comps to hit so I threw some paint on it!
09-16-2014, 08:51 AM | #8 |
Don't forget the mount for the FPV when you are modifying the cage. |
09-16-2014, 10:40 AM | #9 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
09-16-2014, 10:48 AM | #10 |
Check mate! This is version 1, spreaders are in the mail, still trying to find 5x6 mm shims to make up for the different thicknesses of bearings and out drives but, that's stock input and output axial gears. This will give stock gear ratio behind the motor mount, less weight, and more interior space!! I win! |
09-17-2014, 08:26 AM | #11 |
Nice job Ben. |
09-17-2014, 08:53 AM | #12 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
Very nice Ben! Watching this one..... |
09-17-2014, 09:52 AM | #13 |
nice! are you using flanged bearings?
09-17-2014, 09:57 AM | #14 |
Thanx guys! The original plan was to use flanged bearings but I just tapped a hole and used a button head with a washer as a stop to keep them flush to the outside! I like to reuse stock parts anywhere I can to keep the cost down and repair parts the same as all the other rigs.I'll post more pics when the spreaders show up. Last edited by ToyZuki; 09-17-2014 at 10:43 AM. |
09-20-2014, 06:26 PM | #15 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
When can we pick up one of these chassis? I'm ready |
09-20-2014, 10:38 PM | #16 |
Still working out little details! I mounted it up to a box stock rig yesterday and found that the skid as just a little to far forward and the servo on the axle runs into a front xmember. It'll be ready soon!
01-12-2015, 10:48 PM | #17 |
01-12-2015, 11:37 PM | #18 |
Pebble Pounder Join Date: Apr 2011 Location: wenatchee
Looking good!
03-03-2015, 11:29 PM | #19 |
03-04-2015, 06:17 AM | #20 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
Looks great. Can't wait till nats! Get to compete with all these cool builds. That tranny looks interesting. Are you selling these?
ToyZukis early Bronco - Similar Threads | ||||
1.5 Early Bronco | AkFordfan | 1.5 Scale Rigs | 261 | 02-05-2021 08:19 PM |
Early Bronco (oh yes it is!) | Metal Masher | 1.9 Scale Rigs | 64 | 10-28-2013 08:20 PM |
Early Bronco | RAM2500 | Paint and Body | 5 | 09-05-2011 05:47 PM |
