Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Introducing The UCFab PRT(pure race truck)U4RC build
Old 05-18-2015, 09:59 PM   #1
ULTRA CUSTOM FABRICATION
Default Introducing The UCFab PRT(pure race truck)U4RC build
So with Axialfest coming up I wanted to build me a new car to race. I will still be running my regular ultra car in the Endurance race. This one is being built for some track racing. After seeing Delmontes car with the leading and trailing arms I knew if I was to ever build a U4RC car That was how I would do it.(thanks for the inspiration Jake).
The main goal for the build was to build a car of this nature and still have it look scale. And by that I mean a traditional two seater That actually has frame rails that span the wheelbase of the car. Mission complete!
The chassis will be very light so weight can be added in desired locations to meet the 8 lb rule for U4RC Trophy class racing. Also has multiple places where the battery can be placed for further tuning.
Parts list:
UCFab PRT chassis
UCFab 7075 leading and trailing arms
UCFab Yeti sway bars front and rear
Dlux 1808 axles front and rear
Dlux Ti upper links
Dlux Ti steering links
Ottsix Voodoo U4 tires
CI 6 bolt wheels
TLR shocks
Hitech 7950 servo
Tekin Roc 412
Wraith trans
MIP drive shafts
How the car sits now.
And some pics of the build process.
LOW ride height
Wheels7 is offline   Reply With Quote
Old 05-18-2015, 11:33 PM   #2
Default Re: Introducing The UCFab PRT(pure race truck)U4RC build
That's a beautiful chassis. Looking forward to seeing this come together.
forty2 is offline   Reply With Quote
Old 05-19-2015, 08:30 AM   #3
~THE SCALE SHOP~
beautiful
STANG KILLA SS is offline   Reply With Quote
Old 05-19-2015, 07:41 PM   #4
5th D Owner/Driver
cboggs's Avatar
I can't wait to see some video of this beast!
cboggs is offline   Reply With Quote
Old 05-20-2015, 03:59 PM   #5
So where did you get those sway bar arms ?? What brand are they ?
Rodamis is offline   Reply With Quote
Old 05-20-2015, 06:41 PM   #6
Those are made by my company UCFab. Can be purchased at Dluxfab.com
Old 05-20-2015, 08:23 PM   #7
Damn, it doesn't get any cleaner than that.
Highmark is offline   Reply With Quote
Old 05-21-2015, 03:14 AM   #8
One word; MINT!!
Hammer! is offline   Reply With Quote
Old 05-22-2015, 10:53 AM   #9
Y-Town Crawlers
Del Monte's Avatar
Beautiful work! I hope I can see it (drive it) at Axialfest this year
How are the spring rates for the big 12mm bore shocks? I wouldn't mind trying them, but I was afraid that the spring selection would be too stiff for a U4 truck/crawler.
Del Monte is offline   Reply With Quote
Old 05-22-2015, 11:00 AM   #10
Ww that's awesome
tacocat is offline   Reply With Quote
Old 05-22-2015, 09:25 PM   #11
Originally Posted by STANG KILLA SS View Post
beautiful
Originally Posted by Hammer! View Post
One word; MINT!!
Originally Posted by tacocat View Post
Ww that's awesome
Thanks Guys!! I am dying to drive this thing. Gonna be fun
Old 05-22-2015, 09:40 PM   #12
Thanks Jake. I planned on handing over the radio to you to get your opinion on setups. You are way ahead of me on testing a car like this. Would love to hear your feed back on How its driving.
The big shocks feel amazing. I was dropping it from 8 feet up to a flat landing and it just soaks it up, with no crazy rebound. These shocks I have been running on my ultra car for a couple years now. I run the softest one in the rear and the same spring in the front that I ground out the inside of the spring to adjust spring tension to my liking. I just test the spring rates on a scale. I usully leave the motor side spring about 4 grams heavier.
We need to get you one of these to run next season at the U4RC races
Old 05-23-2015, 07:08 AM   #13
Sweet build..so when can I get some front trailing arms ?
bronc4now is offline   Reply With Quote
Old 05-23-2015, 12:35 PM   #14
Thanks! The leading arms are just my Yeti arms with .250" taken off the front. you can have Dlux shorten a set for you. I beleive its $20 to modify the arms.
Old 06-08-2015, 10:32 PM   #15
Before I finish the chassis all the way I wanted to drive it a little. To make sure there wasn't any issues. After running a few packs through it I am very pleased with how it drives. It was getting around the track better than my Yeti!!(part of that due to the stock rear shocks on the Yeti really suck
No changes will be made as far as suspension. for now!
Here is a few shots I got ripping around the back yard.
Old 08-30-2015, 12:57 AM   #16
5th D Owner/Driver
cboggs's Avatar
I think we need an update...
Old 08-30-2015, 06:10 PM   #17
I think so as well! I have seen alot of news on this via FB. Thinking this should be the next rig in my stable as well!
2003EDGE is offline   Reply With Quote
Old 08-31-2015, 11:31 PM   #18
Update way over due. The PRT has turned out to be my favorite car by a long way!! With a little shock tuning it works way better than I ever expected out of a solid axle car. Ended up moving the battery behind the Transmission. really helps the car fly level. there is now 3 of these out there and another 5 on the build list.
Here is how mine is looking now.
This one is UCFab team driver Brian Jones in So Cal
And this one is UCFab team driver Tony Mazza's in Nor Cal
Old 09-01-2015, 06:48 PM   #19
I really like the looks of this setup. The front / rear trailing arms and sway bars make it look like a true performer. Might have to save up and shoot you a PM about building me one.
Sevastra is offline   Reply With Quote
Old 09-06-2015, 07:35 PM   #20
These are absolutely beautiful works of machinery. What does one of these bad boys weigh in running trim?
MonkeyFist is offline   Reply With Quote
Introducing The UCFab PRT(pure race truck)U4RC build - Similar Threads
Rolandrockshop's U4RC race build ROLANDROCKSHOP 2.2 Scale Rigs 135 07-24-2015 07:42 PM
PhatDads, Ultra Customs Fabrication U4RC Race Build. PhatDad 2.2 Scale Rigs 90 12-24-2014 09:45 PM
U4RC Race Teams jerry2575 U4RC 9 09-19-2014 09:05 AM
U4RC.com Balloon Race ZoSo Scale Videos! 4 02-26-2014 04:54 PM
King of the Farm race truck build jetboat HPI Wheely King 21 06-06-2010 08:18 PM
