Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: TImely - 2.2 Dual Trailing Arm, Titanium rod Ultra 4
Old 04-18-2016, 09:14 AM   #1
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Default TImely - 2.2 Dual Trailing Arm, Titanium rod Ultra 4
This is TImely, CI's latest Ultra 4 test vehicle. Gavin has put this car through its paces and it is currently apart for repairs. Casey Childs designed and built the chassis. The chassis is all titanium rod & TIG welded.
..Uploaded from the lab @ the C.I. Compound...
Nova's Ark is offline   Reply With Quote
Old 04-18-2016, 09:21 AM   #2
Nova's Ark's Avatar
Default Re: TImely - 2.2 Dual Trailing Arm, Titanium rod Ultra 4
The drive train consists of:
VP Rock Jock Currie Axles in silver
VP trans case
BWD motor plate
Super Shafty Lockers
Super Shafty top shaft
RRP spur assembly
Axial HD gears in trans and axles
Hitec servo
Castle Creation MMP 1cell
CC BEC
Tekin 3500kv pro4hd
MIP drive shafts
Futaba RX & TX
Old 04-18-2016, 09:28 AM   #3
Nova's Ark's Avatar
Due to time constraints, CI assembled the axles and trans, programmed the ESC, BEC, servo, & bound the RX and then sent it off to Casey. Casey did the final assembly and brought TImely to KOH 2016 for delivery. CI met up with Casey and ran TImely on the Outlaw U4 track and at the Axial track / display. I don't have any pics or video from it. I do have a few pics of TImely a couple days later;
Old 04-18-2016, 09:33 AM   #4
Loving that rig l, nice jobs guys Looks like a winner!!!
Later,
Farmer
Farmer is offline   Reply With Quote
Old 04-18-2016, 09:33 AM   #5
Nova's Ark's Avatar
More pics;
Compared to the RC Fabs Works 2.2 Beast Chassis, CI's Beastly Beauty;
Old 04-18-2016, 09:35 AM   #6
Nova's Ark's Avatar
Later,
Farmer
Thank you Farmer! I sure miss seeing all the colorful Michigan crawlers at the regional crawling events like years ago. I'm glad to see you still in the hobby.
Old 04-18-2016, 09:44 AM   #7
Nova's Ark's Avatar
It didn't take long to really test TImely once returning to Texas and the compound. Gavin currently has three tracks in the back for testing and tuning. TImely did not hold up well. Pics of the damage:
Same damage, just assembled:
This Delrin brace was always temporary, time constraints kept the machined version out of the assembly, but it also broke;
Old 04-18-2016, 09:48 AM   #8
Nova's Ark's Avatar
More info on TImely; it uses VP Twin Hammers trailing arms in front and VP Yeti trailing arms in rear. Since it is currently apart for repairs, it will also be receiving some scale upgrades; Vanquish Products light bars and axial radiator for starts.
Old 04-18-2016, 10:09 AM   #9
Awesome.
How does this chassis setup compare, on the track, to the RC Fab Works Beastly setup?
Szczerba is offline   Reply With Quote
Old 04-18-2016, 10:24 AM   #10
Whats the wheelbase with those trailing arm setup?
Nice looking rig for sure. Be interested to see the beefing up and what the final weight ends up at.
Wes
WesTX is offline   Reply With Quote
Old 04-18-2016, 07:45 PM   #11
Nova's Ark's Avatar
Originally Posted by Szczerba View Post
Awesome.
Different. Gavin can drive both TImely and the Beastly Beauty very well and each design has pros and cons.
Wes
I do not remember the WB measurement, and the car currently isn't assembled or in CI possession. My guess is roughly 15 1/4"
It is longer than the beastly beauty.
Old 04-19-2016, 07:05 PM   #12
Was the purpose for the titanium weight savings? If so why not run plastic AR60 housings with aluminum beef tubes to save on weight? Just curious. I know there are benefits to the VP axles, but since these are just the RJ axles they won't have the upgraded pinion bearing so didn't see any other benefits if weight savings was the purpose of this build.
Wes
Old 04-20-2016, 08:33 AM   #13
Nova's Ark's Avatar
Wes
No, weight savings was not the goal. Strength and building something unique was. Well built cars are a canvas to the artist. Casey is an artist.
However, having a lighter chassis is nice because you can put the weight where you want it. U4RC rules is 8 pound minimum for 2.2 trophy class.
I would never run plastic AR60 housings or much of anything else plastic. The plastic parts flex way too much and create bent shafts and other problems.
I haven't experienced pinion bearing failures in my VP Currie RJ's. We've run them in two U4 yeti's on CI's four test tracks, as well in TImely, and in a couple crawler specific builds without issue. All on 3S and 4S lipo. My V1 VP AR60 housings were a different story and did have failures. The New V2 VP AR60 housings are incredible and have been holding up well with zero failures to report.
Old 04-20-2016, 09:00 AM   #14
Gotcha, I misunderstood the intention of the Ti.
Looking forward to seeing more
Wes
Old 04-21-2016, 09:45 AM   #15
Wes
No rust, lighter than steel and it looks cool. The only issues so far have been tearing the upper link tabs apart and the cost of buying plate and having the tabs cut.
New beefed up tabs are on the way, I hope to be able to get this car back up and running within a few weeks.
Almighty Malach is offline   Reply With Quote
Old 05-02-2016, 07:59 PM   #16
this rig is beautiful
normally i like rolled cage tubing but this rig flows amazing even with the straight tube
microcrawlers is offline   Reply With Quote
Old 05-02-2016, 08:06 PM   #17
Parts are en route thanks to Superstition Machine Works
Old 05-02-2016, 09:02 PM   #18
Moderator Rule Breaker
eric113's Avatar
Hey buddy...
It looks you got enough to do a few cars.
Ugh, I need to get my tig welder already.
eric113 is online now   Reply With Quote
Old 05-02-2016, 10:03 PM   #19
That's sick! I really could use something like that.
dubAron is offline   Reply With Quote
Old 02-16-2017, 10:08 AM   #20
Nova's Ark's Avatar
It is our nature to look for new trails. One by one they come together to form a line before heading out to the trail. All the while nature carries on, as we unknowingly mimic it in our play.
Crawler Innovations Parts used in the video:
TImely:
CWR-5004 1.50" width 6 Bolt wheels
CWR-3003 Deuce's Wild Standard foams (front and rear)
CWR-3015 Deuce's Wild Tuning Disc Set (one disc, on the outside of the foams in all four tires)
PB9008NK Pitbull Tires 2.2 Growlers with hand cut CI pattern
Beastly Beauty:
CWR-1045 Double Deuce 5.25" Comp Cut w/ Medium Outer foams (front and rear)
The wraith:
PB9002NK Pitbull Tires 2.2 Rock Beast 2
CWR-1082 5.75 Double Deuce Single Stage Medium
TImely Build thread:
Beastly Beauty build thread:
Crawler Innovations "Beastly Beauty" - 2.2 Ultra 4 Rig
A wraith build thread:
--- Crawler Innovations "White Lightning Wraith" ---
webstore:
RC Crawler Foams, Rock Crawler Foams, Tires and More by Crawler Innovations
#1 source for RC Crawler info:
www.rccrawler.com/forum
Tags
better than steel
TImely - 2.2 Dual Trailing Arm, Titanium rod Ultra 4 - Similar Threads
Anyone done a trailing arm rear suspension? 95geo Axial Wraith 26 09-03-2013 11:07 PM
Trailing Arm Suspension for a trailer neillarson General Scale Talk 11 07-03-2011 09:15 PM
Shortcourse 4-link vs. trailing arm desertmaxx Non Crawler RC's 4 09-07-2010 06:40 PM
trailing arm links mookie Redcat Crawlers 6 07-07-2010 06:43 PM
