Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Wroncho build attempt
Old 08-05-2018, 12:24 PM   #1
Default Wroncho build attempt
I have been reading the forums on wroncho builds and decided to try and build one myself. I went with an aftermarket skid and transfer case to eliminate the driveshaft rub issues. I also used brake line tubing to make custom length links. So far everything seems to be coming together quite nicely. On the way from online shopping is a honcho body, light kit, from cms from vanquish, a driveshaft to link the transmission to the transfer case and some wheels and tires. I will be doing a 3 link setup with panhard once the cms is installed. Please tell me what yall think so far and if you see any major issues with it so far.
stinger113 is offline   Reply With Quote
Old 08-06-2018, 04:53 AM   #2
Default Re: Wroncho build attempt
should be a good build, what skid and tranny did you use?
rs10man is offline   Reply With Quote
Old 08-07-2018, 07:24 PM   #3
Not sure of the name brand. I found it on ebay. Bought it to see if it would work for this build or not. I am thinking it's going to get hung up when crawling over stuff.
Old 08-08-2018, 08:13 PM   #4
Looks like a good build going, I’m currently trying to do the same but am having difficulties with the link length,if you don’t mind me asking what are the link lengths you used??
Crawlguy87 is offline   Reply With Quote
Old 08-09-2018, 03:15 AM   #5
see how it looks once you've got the tyres mounted up anyways, might not look like as much of a problem, unless you've done so already
Old 08-09-2018, 06:54 PM   #6
I have the wheels but not the tires yet. They are in shipping from ebay along with drive shafts. So far I think it might be okay. Will post pics with wheels mounted once the tires arrive.
Old 08-09-2018, 08:41 PM   #7
Are you making your own links ? Mine are made from 1/4" brake line tubing and 8/32 all thread. I cut the brake line tubing to 3 3/4". Then 8/32 all thread was cut long enough to go through the tube and attach rod ends. I didn't want to bend any links so I opted for the center drop down chassis plate and transfer case. With this setup I literally have no binding or rubbing on the drive shafts when flexed. Brake line tubing was bought from an auto parts store in 4' pieces and the 8/32 all thread was a home depot purchase. I used revo rod ends. Hope this helps.
Old 08-17-2018, 06:37 PM   #8
Finally got the tires in today. In the process of waiting for the tires I installed a panhard mount, body, lights (not complete yet) and front mount servo. Here are some pics with the new tires.
Wroncho build attempt - Similar Threads
Wroncho Possible Build Help malickie Axial SCX-10 4 01-09-2018 11:26 AM
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) Irishchamp 2.2 Scale Rigs 45 10-09-2014 10:26 PM
VP`s JK Wroncho build zonkerd Axial SCX-10 58 04-03-2014 08:38 AM
My build attempt nolan533 Redcat Crawlers 8 02-16-2013 06:21 AM
The First Attempt!! YJ Build chester623 1.9 Scale Rigs 0 12-04-2012 06:19 PM
