Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: How much do wronchos cost?? Brushless 2-speed wroncho build (AR60 2.2)
Old 01-28-2021, 09:11 AM   #1
Default How much do wronchos cost?? Brushless 2-speed wroncho build (AR60 2.2)
Hey there, this is my in-progress build of a wraith-based wroncho.
$180 - Donor custom crawler with AR60 axles. I thought this was wraith-based but the skid, links, and tranny were from an SCX10.
$50 - Pro-Line 1966 Ford F-100 Crawler Body (Trail Honcho)
$50 - BP Custom Wraith Skid Gen5 Chassis Rail Conversion
$29 - Vanquish Axial Wraith Panhard KIT VPS03250
$14 - TGH/HH Chassis Panhard Mount
$55 - Incision Wraith 1/4 Stainless Steel Link Set (10)
$118 - Pro-Line Pro-Spec Scaler Shocks (105mm-110mm)
$188 - Gear Head RC 2.2" Five Star EZ-Loc Beadlock Wheels (5)
$21 - Crawler Innovations Double Deuce 6.0" 2.2 Crawler Foam w/Comp Cut Inner (2) (Soft Outer)
$21 - Crawler Innovations Double Deuce 6.0" 2.2 Crawler Foam w/Comp Cut Inner (2) (Medium Outer)
$99 - Pro-Line Interco TSL SX Super Swamper XL 2.2" G8 Rock Terrain Truck Tires (6)
$194 - Castle Creations Mamba X Waterproof Sensored Brushless Combo w/2280kV Slate
$65 - CNC 2 Speed Transmission Case Gearbox for 1/10 RC Axial Wraith
$84 - Savox SW1210SG - Waterproof High Voltage Digital Servo
$33 - Dumbo RC X6FG 6-channel receiver/transmitter with gyro
$285 - Custom welded rear cage, sliders, and bumpers
$1,486 spent so far
Mletchworth is offline   Reply With Quote
Old 01-28-2021, 10:28 AM   #2
Default Re: How much do wronchos cost?? AR60 2.2 wroncho build (in progress)
Looking forward to this build. I love Wronchos. I just finished my build a month ago using the same chassis rails with a wraith skid.
Sent from my LM-G710VM using Tapatalk
MaX-D is offline   Reply With Quote
Old 01-28-2021, 10:32 AM   #3
Looks good. As far as the title I'm pretty sure you could do it on the cheap, I've seen Youtubers just bend up some links and run them on the OG 10 skid/frame. Depends on how nice/awesome/clean you want it to be. Some of the bends I've seen are sketchy lol.
I looked into doing this on my Deadbolt 10ii but decided it would be cheaper to buy a RTR wraith and slap a truck body on it haha. It adds up...but you are going to have a badass rig for sure.
Phildirt is offline   Reply With Quote
Old 01-28-2021, 10:58 AM   #4
You got me curious as to what my build cost, so here's the break down of my Cherokee Wroncho build
SCX10ii Cherokee RTR- $389
Vader Flat Skid - $20
Intheworks RC wraith high clearance brass link with extended rear links - $37.50
Scaler fab universal brackets - $15
Vanquish Axial Wraith Panhard Kit - $29
Vanquish ar60 dual shock/link mounts - $25
Beef tubes front/rear - $70
Beef tube Brass diff covers front/rear - $60
SSD metal trans gears - $28
Incision UD gears - $30
SSD knuckles - $25
Axial 8 hole 2.2 beadlock wheels - $20 off ebay
BP Custom RC beadlock rings - $30
Proline dual stage foam - $40
Proline 2.2 TSL Super swampers - $66
Holmes Hobbies 550 27t - $20
Amazon 110mm shocks - $22
Aluminum shock towers $20 off RCC
RC4WD Tough Armor Sliders - $33
Total is $979.50 …. well that escalated quickly! I was thinking $600 total, which I guess would be right since I already had the RTR around. This doesn't included the extra clear Cherokee body and paint.
xtreme4x2 is offline   Reply With Quote
Old 01-28-2021, 11:09 AM   #5
A lot of those upgrades are not wroncho specific though. I guess I was thinking "to build a wroncho" shopping list when I read the title. Axles, skid, panhard, links would get er done right? And bigger tires of course.
Old 01-28-2021, 11:36 AM   #6
With just the truck you're right. Add to you list, scaler fab brackets and use the stock scx10ii skid. you'll save $5 then put that towards a 550 can motor.
Old 01-31-2021, 05:10 PM   #7
Just got these bad boys in the mail!
Sent from my GM1917 using Tapatalk
Old 02-05-2021, 07:15 PM   #8
Part of the cage is built along with the sliders. Builder working on setting the spare tire now.
Old 02-05-2021, 09:36 PM   #9
Progress
Old 02-05-2021, 09:37 PM   #10
More progress
Old 02-05-2021, 09:49 PM   #11
Nearly done!!
Old 02-13-2021, 01:19 PM   #12
New front bumper with light bar
Old 02-23-2021, 11:30 AM   #13
She's finally done!
Old 02-23-2021, 11:36 AM   #14
Kind of looks like an Arrma Outcast
Old 02-23-2021, 03:48 PM   #15
This looks great! What's the final wheelbase?
Old 02-23-2021, 05:22 PM   #16
14 inches. Weights 10.4 pounds without a battery
Old 02-26-2021, 03:59 PM   #17
Crawling out in the front yard. Really got this thing dialed in now. 2 speed transmission is awesome, just gotta remember to lower the drag brake so I don't flip over the front end
Old 03-08-2021, 06:06 AM   #18
The truck is now 100% done! I added a rear license plate, rear sway bar, and relocated upper front shock mounts.
Old 03-08-2021, 05:21 PM   #19
Default Re: How much do wronchos cost?? Brushless 2-speed wroncho build (AR60 2.2)
Another kids soccer practice means another hour of sunset crawling!
Old 03-08-2021, 06:30 PM   #20
Man that green really pops. Looks good.
How much do wronchos cost?? Brushless 2-speed wroncho build (AR60 2.2) - Similar Threads
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) Irishchamp 2.2 Scale Rigs 45 10-09-2014 10:26 PM
CF Progress Build ZoSo Axial XR10 26 04-16-2014 05:30 PM
CJ-7 build in progress KeddeX Losi Micro-Rock Crawler 14 01-12-2010 01:46 PM
MY build in progress TXmade HPI Wheely King 1 02-21-2008 05:30 AM
