03-03-2008, 09:55 PM | #1 |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
| Straight axle carnage
To my knowledge no one has posted anything like this. This is with my Ti locker and RCP SS straight axles. Was testing and got her bound up pretty hard and the jato driveline snapped so hard it sounded like a 22 caliber went off. Put a new jato driveline on her and rolled it in the shop and low and behold the RR tire was wobbling bad. Pulled the rim/tire off and the stub of the axle was bent so bad I couldnt get the hex off. After straightening it with a large pair of channel locks got the hex off. Pulled the axle apart to make sure the internals were ok. Couldnt get the outer bearing off either, had to file the crap out of the axle to get the bearing off. The hole the cross pin goes in was so skewed and twisted I couldnt believe it. When I pulled teh axle out of the locker saw this. The axle flat is twisted almost a full 90* and not a scratch on the locker........ |
03-03-2008, 09:58 PM | #2 |
OK, I'm sold on the lockers Dennis(like I wasn't already)
03-03-2008, 10:03 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
I've got a axle that looks identical. I bent and twisted mine during a 4-5ft fall at a comp, only minimal damage to the stock locker. |
03-03-2008, 11:18 PM | #4 |
Rock Stacker Join Date: Oct 2007 Location: Yakima
That is very impressive. I know what is on my list to buy now. Cheers! |
03-03-2008, 11:23 PM | #5 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
So the weak point now are the axle shafts? Thats pretty good.
03-03-2008, 11:39 PM | #6 |
RCC Addict Join Date: Nov 2007 Location: BV
I don't know about the RCP axles, but one of their competitors makes their axles out of 303 stainless, which is very corrosion resistant, but is also very soft and cannot be hardened . 303 is popular because it's easy to stamp, but it just isn't adequate for axles. I wish someone would make them out of a chrome moly with a zinc or black oxide coating. I'd gladly give up some corrosion resistance to have them not break (hint hint) Titanium is strong, but I think you'd want a little bit more ductility for axleshafts.
03-03-2008, 11:45 PM | #7 |
| Actually my jato driveshafy gave up before this did, but I would say this is a very close second. Thats funny, I have some 4130 on the way here now............. |
03-04-2008, 12:25 AM | #8 | |
03-04-2008, 08:23 AM | #9 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
I've wondered if this would be a problem with the straight axle conversions. The good thing about the stock setup is that there is some flex in the axle and plastic axle carriers if you bowling ball your truck down a hill.
03-04-2008, 08:43 AM | #10 |
Nor-CalRCRC Join Date: Dec 2006 Location: Monterey Peninsula
I think the ti lockers will be great. I am with the others on going to something stronger than SS for the straight axles. The problem I have seen with them is also an issue with the TLT versions. If your crawler takes a good tumble and lands on a rear wheel the axle can bend quite easily. I have witnessed it several times with people I have crawled with. |
03-04-2008, 08:47 AM | #11 | |
Quarry Creeper Join Date: Dec 2007 Location: Monterey, CA
Seriously though, the rcp shafts are way too easy to bend. I've killed 2 of them. The stock axial axle shaft material is good. anyhow, back to bending axles... Last edited by rdtshaw; 03-04-2008 at 09:37 AM. | |
03-04-2008, 08:56 AM | #12 |
Gotta ask, what motor and battery were you using?
03-05-2008, 01:23 AM | #13 |
Quarry Creeper Join Date: Sep 2005 Location: on the rocks
My friend destroyed 2 SS rear shafts his first run out with them. Both bent badly with no hard falls and 1 was twisted and ready to break at the pin. I dont know which ones had though.
03-05-2008, 06:40 AM | #14 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
From the pic it doesn't look like the axle shaft was all they way into the locker.I thought you said the shaft goes all the way into the Ti lockers.
03-05-2008, 10:49 AM | #15 |
| Your gonna be proud JRH, I was using your Crawlmaster sport and a 8c 1500mah 2/3a saddle pack with a 9t in the R2D. Really like that motor. But Im gonna swap out the 9t for 10t, need a bit more wheelspeed. When the driveline snapped I thought that was the only thing that broke. I guess Im gonna have to be a lil more carefull. I made a couple Ti axles yesterday and doing some testing on those now, after I went to the LHS and bought all the Jato drivelines they had! We will see how it goes, lot of testing to do, lot of parts to try and break. I love my job! |
03-05-2008, 10:59 AM | #16 | |
Stay tuned......... | |
03-05-2008, 11:18 AM | #17 |
Rock Crawler Join Date: Dec 2005 Location: North Vancouver
Hmmm crappy deal...I just ordered a set of the stainless and before I did was wondering if they were proven yet. I dont see many posts of broken stock shafts do you think a stocker would have blown too?
03-05-2008, 12:11 PM | #18 |
| The SS shafts from RCP are awesome shafts, dont get me wrong. I got it bound hard and anyone else would have backed out. I am torture testing my stuff to see the break and wear points. My Ti lockers are just bombproof and they are now snapping other components. I havent seen anything like this posted. Yea if it falls off of a 6' rock on a wheel she is gonna bend. Under normal use the SS RCP shafts are a great product and will last a long time. |
03-05-2008, 12:14 PM | #19 |
While you're testing can you throw a set of stockers in and break em :-P ....just so we know how they hold up.
03-05-2008, 12:20 PM | #20 |
Pebble Pounder Join Date: Jan 2008 Location: winston-salem
has anyone thought about getting the shafts cryo'd just like the 1:1's?
