03-05-2008, 12:10 AM | #1 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| smaller pinion quest
Is a 12T the smallest pinion available in 48pitch? I'm at 12/90 with no room for a bigger spur. Any other way to gear down more? outrunner if it matters 1025kv AXI 2217/16
03-05-2008, 12:24 AM | #2 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
| http://cgi.ebay.com/Axial-Scorpion-H...QQcmdZViewItem If you need to drop it more, not likely, you could go with a gear reduction unit. |
03-05-2008, 12:26 AM | #3 |
Newbie Join Date: Feb 2007 Location: Simi Valley
I've never seen smaller than that. If Robinson Racing doesn't make it, I doubt it's out there... Rig up a planetary maybe??
03-05-2008, 12:48 AM | #4 |
Quarry Creeper Join Date: Aug 2007 Location: Rocklin, CA
Robinson goes down to 10 tooth in 48 pitch. Thats the first 9 tooth I've seen.
03-05-2008, 05:56 AM | #5 |
Newbie Join Date: Aug 2007 Location: EDINBURGH,SCOTLAND
| Hot Racing 9t Pinion On The Ax10 check this out, its the HOT RACING 9T, GET EM ON EBAY FROM BIZARREHOBBIES. You will need a spacer, moves the motor forward a bit too, . |
