03-26-2008, 01:12 PM | #1 |
Newbie Join Date: Mar 2008 Location: Edmonton
| AX 10 Modifications?
I am new to the RC crawling world and am wondering if you guys would be able to give me an idea of what I should put on my stock AX 10 Scorpian to make it so it will be able to do some mild crawling on the trail thanks alot.
03-26-2008, 01:20 PM | #2 | |
Rock Stacker Join Date: Mar 2008 Location: Arvada
start off by adding bent links to rear axles better tires cus stock ones suck........baddlands, moabs are good some good advice check other threads from other people hope this helps | |
03-26-2008, 01:29 PM | #3 |
Quarry Creeper Join Date: May 2007 Location: Brenham, Tx
new tires and bent lower links for sure. budget?
03-26-2008, 01:52 PM | #4 |
Rock Crawler Join Date: Jan 2008 Location: Jonesboro, Arkansas
New springs for the shocks, stage2 kit is a great ivestment, tires-moabs or losi claws, put the shock bump inside the shock under the piston to get the C.O.G. down. These are a few things, trial and error is a great process as well |
03-26-2008, 02:26 PM | #5 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
03-26-2008, 02:37 PM | #6 |
Pebble Pounder Join Date: Feb 2008 Location: Gonzales
03-26-2008, 03:01 PM | #7 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
Yotachump knows all. You know, like some sort of rockcrawling Jedi master. (note dripping sarcasm ) The stage 2 kit isn't a bad way to go. Assembling it yourself is cheaper, and you'll get better quality parts, but if you've got no idea what you're doing, order it. Read over the CKRC stage 2 article elsewhere on this site and see what you think for yourself. There are some durability problems with the 3 link connecter with higher power and high traction rigs. The TCS 4 link plates are also a great way to go and are a little cheaper. I have yet to find anything that dials out all the torque twist on the stock chassis, but you can get close. Tires make a huge difference. Badlands are great, but maybe hold out to see how the new Hammers work out when they're released in the next few weeks. Using internal limiters and softer springs on the shocks also helps a great deal. The other major change I'd do is to move the battery to the front axle, either with a small lipo or a set of nimh saddle packs.
03-26-2008, 05:07 PM | #8 |
read middle of this link cheap and easy set-up all the guess work done for you already http://www.rccrawler.com/axialcompbuild.html |
03-26-2008, 10:21 PM | #9 |
Rock Crawler Join Date: May 2007 Location: lacey
The best thing to do Is to drive it and see for your self what needs to be changed. modifications are only as good as the driver behind the wheel feels about them, basically some people might have an easier time driving a stock truck than one with 600 dollars in upgrades/mods. the one thing that does seem consistent is to buy the strongest servo you can afford. there is nothing wrong with too much torque. |
03-27-2008, 12:39 AM | #10 | ||
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
sounds like you need a taste of your own medicine Quote:
03-27-2008, 12:40 AM | #11 |
