04-30-2008, 06:47 PM | #1 |
Newbie Join Date: Feb 2008 Location: westminster
| turning radius
Anyone have any tips for improving the turning radius. I know, go DIG and you can turn on a dime. Until that time I am looking to improve my ability to turn. Thanks, Tim |
04-30-2008, 07:17 PM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
i set my EPA's at 125% and the tires rub a little on the chassis so i set it to 120% and it has OK turning
04-30-2008, 07:26 PM | #3 |
Newbie Join Date: Apr 2008 Location: pinole ca
Look about 1/2 way down the page http://www.rccrawler.com/axialcompbuild.html replacing the 2 front screws with countersunk head screws seemed to help quite a bit in tightening up my turning radius. HTH Steve |
04-30-2008, 07:44 PM | #4 |
Quarry Creeper Join Date: Oct 2006 Location: kansas city
Also because of the steering arms on the front, it makes for crappy ackerman. If you will give a little toe out it will help with the ackerman and turn a little better. Randy |
04-30-2008, 07:45 PM | #5 |
Newbie Join Date: Nov 2007 Location: Aberdeen
Theres a couple things you can do. Each require some fab skills and know how. First stimple one is to take your tires off and set the EPA's. I say take the tires off because just running them 125% crams the stub into the drive axle and causes things to wobble around, and eventually break the stock C, in my case anyways. I found with the stock steering setup, you turn sharper one way than the other. The servo arm should not point straight down, it needs to be set longer just a tad. I spaced mine with washers to get a final dimension. This is from the knuckle and when it pushaway it take more throw in the arc to produce the same amount as bringing the knuckle close to the axle. You can build a BTA, which produces correct akerman (inside tire needs to turn sharper than the outside tire, stock front style steering has this a$$ backwards) Or you can weld on some HPI CVD's and run BTA and get about 15 more degrees of steering over the stock setup......I am very pleased with this. Nathan |
