06-28-2008, 09:12 AM | #21 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
Here ya go they have them. Others have them to, but they are all in the uk. http://www.hobbypeople.net/mfr/axial01.asp It's the axial universals for 31.99 |
06-28-2008, 02:56 PM | #22 |
I joined the Band! Join Date: Oct 2006 Location: RcFanatics.net
Cool. Thanks!
07-05-2008, 12:04 AM | #23 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
Just ordered mine from RCP, but I ordered the last 2 sets they had. http://www.rcpcrawlers.com/product.p...&cat=29&page=1 |
07-05-2008, 11:08 AM | #24 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
07-07-2008, 03:19 PM | #25 |
Rock Crawler Join Date: Jul 2007 Location: central PA
I recieved my Axial CVDs and RCP max-clearance knuckles today. The only thing I dont like about them is the shaft diameter behind the ball is smaller than the MIP by the looks of it. The ring to hold the pin in there is a nice touch though Steering is incredible. These two upgrades eliminated the tire wiggle I had in the RC4WD knuckle/stock axle setup also |
07-07-2008, 10:46 PM | #26 |
RCC Addict Join Date: Aug 2007 Location: Rohnert Park
JPH Racing has the Axial parts in stock, $24.99. Mip's also, $39.99. RCP products as well.
07-15-2008, 12:46 AM | #27 |
RCC Addict Join Date: Jan 2005 Location: Germany north
07-15-2008, 06:38 AM | #28 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I found that the pin and barrell was a bit loose...maybe I'm just used to my race vehicles CVD's, but mine aren't as tight as I would have fully preferred.
07-15-2008, 07:04 AM | #29 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
My Axial CVD's are tight. I'm also using RCP high clearance knuckles, and the steering is incredible, and the quality is second too none. |
07-17-2008, 10:54 PM | #30 |
Rock Crawler Join Date: Sep 2006 Location: The Nation of Aiea....
I'm not sure if I'm the only one who had this problem with the MIP CVD's. It seemed to me that the first shanked portion after the cross pin needed to be machined down a little more. After installing the MIP's and tightening down the wheels, there was an incredible amount of binding going on. First I thought about leaving the wheel nuts a little loose, but I really didn't want to. I ended up grinding down the rear portion of the wheel hex (the pin side). Then I just ordered and installed the Axial CVD's and changed the hexes and I am very glad to not have any binding. I'm sure the MIP CVD's are great but I think Axial won this contest......at least for me.
07-18-2008, 07:34 AM | #31 | |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
Whoodie said MIP informed him they are reworking the stubs to fix this. Hopefully we'll be able to get replacements at a reasonable price. Last edited by Locked Up; 07-18-2008 at 11:16 AM. | |
07-18-2008, 09:43 AM | #32 |
Quarry Creeper Join Date: Aug 2007 Location: Amarillo, TX
If you are having issues from the manufacturing process w/ stock parts then the the replacements should be free... Now if you are having issues utilizing after market products w/ MIP that is a different story... Last edited by WVB; 07-18-2008 at 03:04 PM. |
07-18-2008, 10:38 AM | #33 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
Love my Axial CVDs.....what a slick design, I love the captured pins Last edited by Trugg; 07-24-2008 at 06:28 PM. |
07-22-2008, 12:39 AM | #34 |
Quarry Creeper Join Date: Mar 2008 Location: Huntington Beach
Sounds like the Axial ones r the way to go then.
07-22-2008, 05:38 AM | #35 |
| outside diameter of the ball end is 7.8mm inside diameter of the cup is 8.8mm not what i wanted :-( but i like the surface |
07-22-2008, 08:59 AM | #36 |
| 47* and 51* better than stock MIPīs |
07-24-2008, 04:26 PM | #37 |
I just ordered a set of these Axial's from TCS... I was recommended these over the MIP's so we shall see..!
12-30-2008, 01:13 AM | #38 |
Rock Crawler Join Date: Nov 2007 Location: North Crawlolina
I have had my Axial CVD's for a while now and I have only had one failure of a pin , to date I ordered a rebuild kit and readjusted my endpoints a little and have not had any trouble.
12-30-2008, 08:29 AM | #39 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Although this is an old thread I want to add another point. All you people who assume that the high clearance knuckles and CVD's are gonna give you crazy amounts of steering you are right - to a point. You cannot have them at full throw as they will indeed break. You need to limit it still as they can only take too much. I have never had a problem with a Cobalt puller and mine. 5 comps and many other outings later still no breakage. Just limit them a little.
