08-14-2008, 08:45 PM | #21 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
Lapeer, just north of lake orion, right??
08-14-2008, 09:41 PM | #22 |
Quarry Creeper Join Date: Jan 2008 Location: fair oaks nor-cal
how much torque you gonna have? since theres no gru seems like not a whole lot?
08-15-2008, 01:42 AM | #23 | |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
08-15-2008, 11:32 AM | #24 |
Quarry Creeper Join Date: Jul 2008 Location: Ventura, Ca
looks like it starting to come along, goodluck with the rest of the build
08-15-2008, 11:58 AM | #25 |
Quarry Creeper Join Date: Oct 2007 Location: Toronto, ON. Canada
| hey braceysdad when did u get those axl;es made, ive been folowing your thread but there was no update on it :-( willing to give out some info on them. how they run and what-not.... and Chris, keep those gears in your head turning. i love the build it yourself rigs. too many people have the same setup when it comes to the AX-10, good to see some still like to think out of the box Last edited by BuzzKilla; 08-15-2008 at 12:01 PM. |
08-17-2008, 01:38 PM | #26 |
More Progress!! She sits on her own. Got a better front wire support built, belly, and the rear all done. Not pretty but it's going to have to do until I validate it works well. And might I add I LOVE TRAXXAS!!! Thanks again to Mitch, I spent like 7 bucks and had everything for my carrier bering. It was a VXL rear carrier, VXL rear stub shaft and x2 5x11 bearings. They may not be high end stuff, but they always have what I need and make great bashing parts/cars. This is it thus far. But I am going to post more soon... Hopefully should have her done all except the dig in a couple hours |
08-17-2008, 01:41 PM | #27 |
Why not just do the same to the rear as you did to the front? Clock the rear up and get rid of the damn driveshafts, give it a real shot at beating the Berg |
08-17-2008, 04:25 PM | #28 |
More... Cant remember what it's called, but the angle of the knuckles dont allow the inside tire to turn as tight as the outside tire. So by making this bracket and lining the mount up with the pivot point of the knuckle that helped eliminate most of it. Thanks to Jim Hand for showing me that;) I also made a little skid and rounded off the edges of the pinion to keep it from shaving down the worm.... Then I got all the electronics in, drove her around the parking lot, and when there is any force put on the wheels and tires, it stalls. Pushes the pinion away from the work. Aparently my idea'r of the ghetto U bolt failed. I can tighten the u-bolt and it helps, but makes the mesh too tight and the worm has a hard time spinning. So Back to the drawing board.... |
08-18-2008, 08:21 PM | #29 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
You got me thinking for my Girlfriends AX10 build |
08-18-2008, 08:51 PM | #30 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| Loads / Speed / Mounts
Interesting idea. I'm watching. Are you running dual motors, or connecting the drive shaft straight to the rear axle? The axle will need to run through a carrier with a bearing. Upon wheel lockup, the worm gear is going to be still lifting up on the shaft gear, sideloading the diff pinion bearings. Fab a beefy center carrier with a bearing around the shaft. 13:1 x 3:1(axial??) = 39:1 Won't she be fast with 6+cells?? Could run 4 sub-C's to start, maybe jump to a 75 or 85 turn motor. Wheel lock could lift up or pull down and around that whole motor and mount. Where's the BEEF? Sorry, it's easy for us up here in the 'nose bleed', 'cheap seats' to point out the weakness. I'll stop. Interesting idea, run with it!! |
08-19-2008, 01:30 AM | #31 | |
Single motor. I am still wanting to see a shafty win That and I only had 1 worm lol. As far as speed goes... Were from the pacific northwest and love our wheel speed. The final out put at the drive shaft with the tranny was about 11.7:1 and I thought the axial reduction was 2.2ish to 1... | |
08-19-2008, 11:42 AM | #32 |
08-19-2008, 12:57 PM | #33 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
So let me get this straight. Your spending how much to beat a Berg?
08-19-2008, 02:26 PM | #34 |
I only have about 40 bucks into this build... Mainly I am using what I have laying around. So I am not spending hundreds... Plus I think if it works, it will be cooler than a berg. Although they're cool, I am not huge on off the shelf built crawlers...
08-19-2008, 02:28 PM | #35 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
At first this was not something I would imagine coming to fruition. Now though I am wanting to see it tear the crap outta something. I implore you on your tenacity.
09-10-2008, 11:06 AM | #36 |
Rock Stacker Join Date: Sep 2007 Location: !!!
did you manage to resolve your problems with the mesh and worm parting as i would like to do something similar with a tlt axel but dont whant to waist time on something that aint possble thanx jase |
09-10-2008, 12:01 PM | #37 |
That's pretty darn ingenious Chris, a torsion MOA with a drive shaft. |
09-10-2008, 04:09 PM | #38 |
Quarry Creeper Join Date: May 2008 Location: Clarkston
I really like your simple but effective knuckle mod. This steering is kickin´some serious butt. |
09-10-2008, 07:00 PM | #39 |
Newbie Join Date: Feb 2006 Location: Kingman
The fact that the worm gear effectively locks the axel when not spinning will give you insane brakes. I do wonder if it will dig better with the axle locked. Keep up the good work!
09-10-2008, 07:03 PM | #40 |
Good luck with that!
