09-05-2008, 08:31 AM | #21 | |||
What tranny? A 12t pinion in an R2 tranny is geared pretty dang low. That'll help some...but not that much. In my super (6 pounds) I'm running an Axial tranny,10t puller geared 18/81 running a 3 cell 2100 mah and get around 30 minutes just playing. While running the comps,I do good to get 2 courses out of it. The 10t will net longer run times over the 7t providing the gearing and weights are the same. Just like a regular 540 can,higher wind counts net longer run time. Your lower gearing might help a touch,but not 2 hours worth. Quote:
With a regular ol' lathe motor and no drag brake...doubtfull. Put it on about a 65 degree slope,you'll have to chase it. | |||
09-05-2008, 10:50 AM | #22 |
Rock Stacker Join Date: Aug 2008 Location: BC Canada
So in an apples to apples comparison the Novak BL (goat) and a 7t puller (with a CC MM) will have similar performance -- low speed torque and control as well as wheel speed (assuming identical battery pack and gearing) but the run time of the BL will be vastly superior? Cost is pretty much a wash because really they aren't really that far off if you need to buy both an ESC and a motor. The difference is truly in the ability to significantly volt up the puller? So can anyone definitively say that a Goat system (2s lipo) vs. CC MM or Sidewinder (3s lipo) with a 7T puller -- The puller will do the same on the low end but exceed the goat in top end power/speed at the cost of run time (Not considering 2p arrangements for sake of simplicity)? I've driven a goat set-up but have not driven a puller so some guidance from those that have done both would be awesome. |
09-05-2008, 12:20 PM | #23 |
Rock Crawler Join Date: Jan 2008 Location: Knoxville
in this video http://www.youtube.com/watch?v=W3WpH8C9qnM the lighter blue truck in the race is running a 7t on 3s with a pede tranny, the darker blue jconcepts truck is running a sensored brushless setup, can't remember if it was the novak or not, but it was supposed to be a 27t equivalent. the pass in the air was pretty impressive. |
09-05-2008, 08:54 PM | #24 | |
Personally,I'll deal with shorter run times for more options and better performance. Pretty easy to carry a battery in your pocket,and just swap out if you wanna run a while without stopping to charge. | |
09-05-2008, 09:19 PM | #25 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
| Well maybe a well oiled/new lathe, I havent opened mine up since I bought it several years back, when 55t was just a lathe motor and cost 14 bucks, now they are relabeled as crawler motors and cost 30 bucks. The wheels do not turn at all without power input, I can climb up a wall and leave it there, I cant even physically turn the wheels. Probably time to cut the comm and a few comm drops I would guess, but it works just fine. I may go brushless soon though, I would like more wheel speed.
