09-10-2008, 05:58 PM | #21 |
Pebble Pounder Join Date: Jul 2008 Location: Windsor
This a pic of my DNA with a hitec 645 on the slingshot http://i331.photobucket.com/albums/l...0/DSC02892.jpg |
09-19-2008, 10:50 PM | #22 |
Newbie Join Date: Mar 2008 Location: Redding
I own a VF dig and it has worked great. I run the hitec 225mg on it. I did burn up one servo but it was my fault. Setup on it is critical to not burn up your servo and also make sure the dig enguages and disenguages correctly. Make sure you check all you end point adjustments on your radio before you attach the linkage to the dig(thats if you have them) . If you don't have proper throughs on it you will burn up your servo or it won't enguage or disenguage correctly . I also found that my dig is working better now than when I first set it up. I have never used any other of the digs mentioned but I really believe they will all work correctly if you take your time with setting up the linkage and servo throughs. Check then recheck
09-20-2008, 03:58 AM | #23 |
Quarry Creeper Join Date: Apr 2008 Location: sanford
thankz for all the info got a dna yeterday |
09-20-2008, 08:23 PM | #24 | |
Rock Stacker Join Date: Dec 2007 Location: Atlanta
What is your 645 mounted to ? Did you make a bracket ? | |
09-20-2008, 08:29 PM | #25 | |
The servo arm has to pull the dig arm straight or it bind right ? | |
09-20-2008, 09:46 PM | #26 |
| got dna dig done
well i went with dna dig just got done putting it in here are some pics love it works good no probs with it the only thing i had to do was cut cass. to fit it in and make new skid plate and servo plate |
09-20-2008, 09:56 PM | #27 |
Rock Crawler Join Date: Aug 2007 Location: Orlando
nice, is that the same chassis, looks different.
09-20-2008, 10:04 PM | #28 |
09-20-2008, 10:09 PM | #29 |
your chassis work is great, i think some people are going tomorrow, but i was hoping next weekend people would want to gtg at sanford...but it up in the air
09-20-2008, 10:13 PM | #30 |
next weekend will be ban for my to manny thigs to do sanford still locked off
09-20-2008, 10:19 PM | #31 |
it sucks, but hopefully they'll reopen soon
09-20-2008, 10:21 PM | #32 |
hopeso i'm driving the old lady crazy
09-20-2008, 11:38 PM | #33 | |
RCC Addict Join Date: Jan 2007 Location: San Jose
Thank you for the input. I am researching digs for ax 10 and trying to figure out through experience which is reliable. Seems the dig now is the dna one over others...., Are the mods you made with the dna to 4mm, easy? thanks for the help. | |
09-21-2008, 12:04 PM | #34 |
ididn't have to do any mods to mine the only thing i did was cut the cass. some and make new skid |
09-21-2008, 12:22 PM | #35 | |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
I still say that one design is not the best. In the age of buy it now crawler parts, one size does not fit all no matter how hard any vendor may try. I also had to mod my case for clearance and make my own servo mount for the Hitec 645MG. | |
09-21-2008, 09:40 PM | #36 |
Where do most mount a std size servo on the DNA setup ? I can't see how mounting it on rear axle works because it moves up/down. But I hear of people doing it ....... |
09-23-2008, 03:11 PM | #37 |
CKRC Dig......? what are some opinions about this dig setup? seems more aligned with ax010 tranny.... |
09-23-2008, 04:33 PM | #38 |
Quarry Creeper Join Date: Apr 2008 Location: Alexandria
I run DNA digs on my rigs. The R2 is a decent setup, I just like the DNA setup better. When I was researching them a lot a few months ago, I found nothing but problems from people that bought the CKRC dig when it first came out. They may have corrected the flaws since then, I haven't checked into it any further. Most of the people that had bought them when they first came out to save money, ended up chunking them and buying either the DNA or R2D options.
09-23-2008, 10:48 PM | #39 | |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
IS there a dig setup for the spur side ? | |
09-24-2008, 02:36 AM | #40 |
Thanks guys for the input. Glad i waited, almost bought the ckrc. Think i am going with the dna one. |
