Thread: Hustler's Sudu Build
Old 05-28-2014, 06:28 PM   #1
Lightbulb Kulas's Sudu Build
Afterrunning a Losi for 1 1/2 years I tried builda pro light version however found that it was difficult to achieve the wheelspeed that is needed . So I decided to builder an ax10 based crawler with somelosi inspired thought? watching many ax10 it seemed as if they would release tensionon the rock or holding power if throttle was released and I think this was dueto soft drag brake, slop in drive train, and in transmission, and this would betop priority in building the beast.
here aresome of the stats, and the rest are in the pictures:
NCD Sudu withTransmission
RCBROS ALFront Brass Rear Tubes
Over andunder drive gears
HolmesHobbies 500 30t puller
Holmes Esc
HulkstarFront plate
Dlux Brass KnucklesAnd Ofna Drive shafts
TitaniumLinks by myself Hustler
stankulas is offline   Reply With Quote
Old 05-28-2014, 06:42 PM   #2
Cool Re: Hustler's Sudu Build
Hear is me making and treading links notice that I am bending 2 at a time and that the slab has holes for multiple positions its a $60.00 bender and $380.00 Harbor Freight lathe working on grade 5 titanium I even made hex pins from some small scrap pieces
Old 05-30-2014, 02:30 PM   #3
RcBros Hobbies
RcBro's Avatar
Default Re: Hustler's Sudu Build
Sent you a pm about your lathe setup. Any info on the bender?
RcBro is offline   Reply With Quote
Old 05-31-2014, 05:20 PM   #4
I,ll get back on the bender but i drilled and tapped extra holes for more precession and i also drilled a hole in the bigger wheels to keep them from turning and moving the links
Old 06-03-2014, 08:31 AM   #5
more pics
Old 06-21-2014, 04:53 AM   #6
just more photo's
Old 06-21-2014, 04:10 PM   #7
here is link it is aBAC Jumbo Rod Bender
http://www.amazon.com/BAC-Industries...rds=rod+bender
Old 06-21-2014, 06:38 PM   #8
Now that it is up and running I have started to tune. the first thing I noticed was that the rig turned more to the left. when turned to the right the link would be stretched all the way, as seen in this picture
Old 06-21-2014, 06:44 PM   #9
So I made another link out of titanium and used a 1/4 inch flute on my drill press and made two flat spots on the rod and drilled a hole and tapped it flipping the link around problem solved
Old 06-21-2014, 06:51 PM   #10
another issue was using plastic drive shafts so I purchased this drive shaft found here
PROPELLER SHAFT (5mm to 5mm) - Scale Designs International
Old 06-21-2014, 06:52 PM   #11
If you look to the left you will see the package
Old 05-08-2015, 04:30 PM   #12
Been a while since and update but with the new drive shafts they have held up nice
Old 05-09-2015, 01:04 PM   #13
not in stock
crawlinghulls is offline   Reply With Quote
Old 05-09-2015, 07:11 PM   #14
Default Re: Kulas's Sudu Build
The SDI propellers are really good stuff.
I pimped mine up with ti shafts:
Sent from iPhone6 with tapatalk
markusgabl is offline   Reply With Quote
Hustler's Sudu Build - Similar Threads
NCD SuDu FL Build for a friend EverettY Axial AX-10 Scorpion 26 09-28-2014 01:49 PM
SuDu Pro Slow build thread douwe Axial XR10 81 06-23-2013 07:57 AM
Obe's sportsman build SuDu style obebaldone1 Axial AX-10 Scorpion 49 04-17-2013 06:15 PM
Hustler's..... Drail General Crawlers 1 10-16-2009 11:18 AM
