05-28-2014, 06:28 PM | #1 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
| Kulas's Sudu Build Afterrunning a Losi for 1 1/2 years I tried builda pro light version however found that it was difficult to achieve the wheelspeed that is needed . So I decided to builder an ax10 based crawler with somelosi inspired thought? watching many ax10 it seemed as if they would release tensionon the rock or holding power if throttle was released and I think this was dueto soft drag brake, slop in drive train, and in transmission, and this would betop priority in building the beast. here aresome of the stats, and the rest are in the pictures: NCD Sudu withTransmission RCBROS ALFront Brass Rear Tubes Over andunder drive gears HolmesHobbies 500 30t puller Holmes Esc HulkstarFront plate Dlux Brass KnucklesAnd Ofna Drive shafts TitaniumLinks by myself Hustler Last edited by stankulas; 05-08-2015 at 04:35 PM. |
05-28-2014, 06:42 PM | #2 |
| Re: Hustler's Sudu Build
Hear is me making and treading links notice that I am bending 2 at a time and that the slab has holes for multiple positions its a $60.00 bender and $380.00 Harbor Freight lathe working on grade 5 titanium I even made hex pins from some small scrap pieces |
05-30-2014, 02:30 PM | #3 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Sent you a pm about your lathe setup. Any info on the bender?
05-31-2014, 05:20 PM | #4 |
I,ll get back on the bender but i drilled and tapped extra holes for more precession and i also drilled a hole in the bigger wheels to keep them from turning and moving the links |
06-03-2014, 08:31 AM | #5 |
more pics |
06-21-2014, 04:53 AM | #6 |
just more photo's
06-21-2014, 04:10 PM | #7 |
| Re: Hustler's Sudu Build here is link it is aBAC Jumbo Rod Bender http://www.amazon.com/BAC-Industries...rds=rod+bender |
06-21-2014, 06:38 PM | #8 |
Now that it is up and running I have started to tune. the first thing I noticed was that the rig turned more to the left. when turned to the right the link would be stretched all the way, as seen in this picture
06-21-2014, 06:44 PM | #9 |
So I made another link out of titanium and used a 1/4 inch flute on my drill press and made two flat spots on the rod and drilled a hole and tapped it flipping the link around problem solved |
06-21-2014, 06:51 PM | #10 |
another issue was using plastic drive shafts so I purchased this drive shaft found here PROPELLER SHAFT (5mm to 5mm) - Scale Designs International |
06-21-2014, 06:52 PM | #11 | |
| Re: Hustler's Sudu Build Quote:
If you look to the left you will see the package | |
05-08-2015, 04:30 PM | #12 |
Been a while since and update but with the new drive shafts they have held up nice |
05-09-2015, 01:04 PM | #13 | |
Rock Crawler Join Date: May 2007 Location: Norwich
not in stock Quote:
05-09-2015, 07:11 PM | #14 |
Rock Stacker Join Date: Sep 2013 Location: Austria
| Re: Kulas's Sudu Build
The SDI propellers are really good stuff. I pimped mine up with ti shafts: Sent from iPhone6 with tapatalk |
Hustler's Sudu Build - Similar Threads | ||||
NCD SuDu FL Build for a friend | EverettY | Axial AX-10 Scorpion | 26 | 09-28-2014 01:49 PM |
SuDu Pro Slow build thread | douwe | Axial XR10 | 81 | 06-23-2013 07:57 AM |
Obe's sportsman build SuDu style | obebaldone1 | Axial AX-10 Scorpion | 49 | 04-17-2013 06:15 PM |
Hustler's..... | Drail | General Crawlers | 1 | 10-16-2009 11:18 AM |
