05-05-2014, 01:00 PM | #1 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| NCD SuDu FL Build for a friend
Here is a sporty build that I am doing for a friend of mine... Parts list... Front Axle AX10 Axle RCBros Burly Tubes Dlux Brass knuckles Axial Plastic XR C-Hubs Gripfab V1 Aluminum Spool Axial Uni's Axial OD Gears NCD #2 Front 4-Link Plate w/electronics plate Rear Axle AX10 Axle Axial AX10 Plastic Lockouts Gripfab V1 Aluminum Spool Axial UD Gears CreeperBob Ti Rear Shafts NCD #2 Rear 4-Link plate Chassis/Links/Shocks NCD SuDu FL Chassis NCD CF Tranny NCD Ti Lower Links RC4WD R2 Gears CF Upper links RCBros Eggressor Shocks (Ti shafts, Machined Pistons, etc.) S.D.I. Driveshafts with Ti Inserts DLux Sway Bars Wheels/Tires DLux D-Cut White G10 Wheels E.Y. Designs Narrowed VooDoo's C.I. Custom Foams Shift Hubs Electronics Brood 30t Conflux HH BR Mini Protek 170t CC 10amp BEC Futaba 4PL Onto some pics of where it's at right now.. Last edited by EverettY; 05-08-2014 at 10:12 PM. |
05-05-2014, 02:24 PM | #2 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
| Re: NCD SuDu FL Build for a friend
Nice start, Everett |
05-06-2014, 05:15 AM | #3 |
Pebble Pounder Join Date: Dec 2011 Location: françe
very beautiful piece |
05-08-2014, 02:52 PM | #4 |
| Re: NCD SuDu FL Build for a friend |
05-09-2014, 01:54 AM | #5 |
Must be a good friend!
05-09-2014, 05:45 PM | #6 |
05-09-2014, 08:24 PM | #7 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
Friggen awesomeness.
05-10-2014, 01:25 AM | #8 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Ohhh is this what those gears were for ... lookin good! |
05-12-2014, 07:34 PM | #9 |
05-13-2014, 06:30 PM | #10 |
Quarry Creeper Join Date: Feb 2012 Location: MARTINIQUE
05-13-2014, 07:08 PM | #11 |
05-15-2014, 03:03 PM | #12 | |
| Re: NCD SuDu FL Build for a friend Quote:
Got a few things to show... Got the gear lightened by Calvin thanks man awesome work! Got the motor mounted up on the transmission just need to get a pinion for it... I'm thinking I'll start off with a 16t pinion and go from there Working on getting the steering figured out... With the DLux knuckles the servo won't fit underneath the servo plate... So I have it sitting on top facing towards the back.. It should be good like this Also got some of these cool servo mount tabs from Calvin (CW Crawlers) They are nice and small and work really well Last edited by EverettY; 05-15-2014 at 03:05 PM. | |
05-15-2014, 04:31 PM | #13 |
I thought the pics erik added show how they go together quite well. Got those servo bushings too. Perfect fit |
05-16-2014, 12:51 PM | #14 |
Thanks guys. I think you got the sloppy mill batch of bushings but as long as they fit . Glad to see they fit more than just the servos I had to check on Those gears were beyond easy to drill honestly... which was nice for me since I was worried I would be eating drills left and right Minor comment... any way to make a mounting plate where the servo is elevated... or to much work. I can do a drawing later if your interested. |
05-27-2014, 04:00 PM | #15 | |
Got some sweet Shift hubs from BC-Brian. I'm running slims in the rear with the wheels flipped and the front I'm running the regular with a few spacers. They were really easy to tap and are a perfect fit Been working on the wheels and tires for the truck too. Been working on narrowed and reduced Gold VooDoo's for it. The front tires are done and mounted on the wheels with CI 5.5" CC foams with Soft outers. | |
05-28-2014, 10:11 AM | #16 |
Man those hubs need a hit with a countersink Sweet lookin wheels and any updates |
06-30-2014, 01:55 PM | #17 |
Got the Magic Wands from Dravtech the other day these are amazing little pieces... Nice and strong for sure thanks Tobias! Sorry for the bad pics I'll get better ones when I get them mounted up Sent from my iPod touch using Tapatalk Last edited by EverettY; 06-30-2014 at 01:58 PM. |
07-10-2014, 12:30 AM | #18 |
| Re: NCD SuDu FL Build for a friend Ohhh aluminum and CF... now were talking |
07-14-2014, 10:54 PM | #19 |
Got the DLux Loaded Dice Knuckle weights a while back but they didn't work with the 8* CHubs so I sent the knuckles and holders to Erik and he fitted them up for me... I still gotta take a dremel to the inside of the weight holders to fit the shift hubs... It'll be pretty heavy but should stay really planted on the ground Also got the Magic Wands installed and man they look amazing! I threw some shocks and upper links on it for now to get the stance how I want it... It looks really good right now Just need the actual upper links which will be here later this week and than gonna have to build some shocks and get a draglink for it... Than just some soldering and a body for it and it'll be about done |
07-20-2014, 06:55 PM | #20 |
It's getting a lot closer Got the sway bars all mounted up and got it all nice and smooth... They are really nice and I'm looking forward to seeing how they perform on this truck Got all of the wheels and tires finished up now too... Running the wheels in the rear flipped so I had Erik make these white Rings for the wheels so it all works better Cut the star pattern pin cut in the front and the rear will stay uncut for now... Got a few poser pics of how it's sitting right now Last edited by EverettY; 07-20-2014 at 07:04 PM. |
NCD SuDu FL Build for a friend - Similar Threads | ||||
Everett's NCD SuDu "Pro"totype | EverettY | Axial XR10 | 111 | 11-30-2015 08:07 PM |
LaaLaa's NCD SuDu Pro-totype | laalaa | Axial XR10 | 124 | 06-12-2014 02:59 PM |
NCD SuDu Pro Down Under... OB New Pro Build. | Oz Bruiser | Axial XR10 | 142 | 10-02-2013 03:50 AM |
Some runs of my NCD SuDu one at purmerend | douwe | Videos! | 0 | 01-29-2013 03:38 AM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
