10-03-2008, 08:47 AM | #21 | |
Quarry Creeper Join Date: May 2008 Location: Federal Way/Tacoma
10-03-2008, 08:49 AM | #22 |
If you're using a "standard" sized shock body, you could also use Mini-T springs. The outer coil springs on the Mini-T shocks fit inside many of the shock bodies. This gives you all the spring rate options available for the Mini-T shocks without having to guess what the rate of a spring is from a hardware store. This makes it easier to play with the setup and make adjustments easier.
10-04-2008, 05:11 AM | #23 |
RCC Addict Join Date: Jan 2007 Location: San Jose
m&m...., pull the shaft out than put the spring in and put the piston in..... thanks off for the suggestion. i am going to go ahead and search for those mini-t's instead of going to ace/depot. Last edited by 5150bronco; 10-04-2008 at 05:13 AM. Reason: add. |
10-04-2008, 09:23 AM | #24 | |
How does the shock extend once on the rig...? The shock is fully compressed..right? Is it the weight of the wheels...? SORRY help :-))) | |
10-04-2008, 01:32 PM | #25 |
Newbie Join Date: Aug 2007 Location: Irvine
mini t springs from team losi work great. I used the rear springs form it and had good luck running it that way. |
10-05-2008, 08:14 PM | #26 |
Quarry Creeper Join Date: Jul 2008 Location: Stuck in Missouri for now.
Alright, so I'm a smart guy, a genius if you will, ;) but this does boggle the mind. Compressed while at rest, how/why does that work better than regular shocks? Do they decompress when they come off the ground? How does that work? Thanks for the clarity so that I can get ahead of the game plan. |
10-05-2008, 10:29 PM | #27 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
M&M I was the Judge on course 1 today and think you'd be better suited to run some short shocks. What i've found with droop is the uncontrolled down travel makes the rig less stable. I run MINI LST shocks, but some buggy front shocks may work out better for you. Try some HPI's They have a ball joint at both ends and usually don't leak much. Give it a try and have some patience, setting up a comp level rig can take some time. Just enjoy the learning process. Hope this helps. Let me know if you have any more questions. |
10-06-2008, 01:05 PM | #28 | |
I am totally up in the air about keepng this edge chassis..Do you think the HotBodies 4" shocks I have now should stay....? | |
10-06-2008, 06:53 PM | #29 | |
RCC Addict Join Date: Jun 2008 Location: Fresno
and like i said the idea of a droop suspension sounds really weird but it's somehitng you have to try, to understand. kinda like sky diving: *why the F**k would somone jump out of a perfectly good airplane?" imo the main reason for using droop is for a lower cg and more stable rig in off camber situations. | |
10-06-2008, 07:56 PM | #30 |
Pebble Pounder Join Date: Feb 2008 Location: here
I would like to add to the confusion. Perhaps droop may be for you or not. It depends on your preference as everyone has said. If you would like a lower CG you might just replace the shock oil with a heavier weight. Axial gives you 30wt. maybe try 60wt. On top of that try a softer spring and shorter spring. Instead of the longer Axial O.E.M. spring try an HPI MT spring or maybe even an E-Maxx spring. On my rig I changed the oil to a thicker weight and replaced the springs with a lighter shorter spring. The CG lowered and when the truck wheel hit a particular deep hole the articulation wasn't affected. On the Edge chassis though you are probably going to run into the problem of high CG no matter what. It is rather heavy. Another setup you might try is to remove the spring totally from the front and use a shorter lighter spring in the rear. That way when you are up an incline the spring is actually pushing the rear of the truck away from the rock while the front is pulling the weight in. This works well for climbing but when descending it works against you. Also you need to remember to weight your tires. This will help to compensate for the extra weight of the chassis. Maybe go 8oz. in each front tire and 3oz. in each rear. Oh, there are so many things you could do. Be inventive and don't be afraid to try different setups. You will come across one that works for you and your style of driving. |
10-06-2008, 09:54 PM | #31 | |
What's your center clearence currently? How long are your shocks, eye to eye with the suspension at rest? Are your lower links level with the ground, at rest? | |
10-07-2008, 02:05 AM | #32 |
i agree with dkur about the weight. that is what i did and it seems to work. so the spacer inside the shock.....? What about using the axial shock damper..? How big is the space and it just slides on the shaft inside the shock..., similar to running spring for droop, right? thanks. |
10-07-2008, 09:12 AM | #33 | |
Think of it this way. When on flat ground the CG is normally just above & a tad behind your lower link mount. When climbing a hill the CG moves back a bit, because the vertical distance between both front & rear axles is getting shorter. When running a droop set up & climbing a hill it moves back and up because you have the front axle moving down and away from the chassis in effect raising the CG. As the front axle droops the chassis gets higher. Then depending on your rear link geometry & your anti-squat # it could effectively raise the front end more causing a roll-over. When running a droop set up you want anti-squat. During acceleration you want the rear end to rise up a tad putting more force on the front axle. If it's set up with no anti-squat it's going reduce the load on the front axle when accelerating. Set your rig on a bench or the counter, somewhere you can get down to its level and watch the rig under acceleration. Give it gas and watch the suspension. If running a droop set up and you have proper geometry the rear end of the chassis will rise(increasng front end force). If not set up correctly the front end will rise(decreasing it). Anti-squat can affect normal suspension set up just as much and help with torque roll too. To find your anti-squat # do a search for "anti-squat calculator" either on google or on pirate4x4.com There is tons of info on Pirate4x4 that can help if you read up. Hopefully this didn't confuse anyone. I had to re-read it twice before posting. | |
10-08-2008, 02:11 AM | #34 | |
Hey, yes it is like a tube. Okay. I will use it. "When on flat ground the CG is normally just above & a tad behind your lower link mount"..........Is this vertical? I want anti-squat then??!! k. Thanks so much!! That actually made a lot of sense compared to others explanations. Okay....so I will search on pirate. Thanks for the illustration now i can visually see and know what to look for. Really appreciate your help! | |
10-08-2008, 09:17 AM | #35 | |
Not sure what you mean in regards to "Is this vertical". Think of CG as a ball of mass floating in a box on the chassis. As the rig moves around the course the ball rolls around in the box. Moving back when climbing moving to the side when sidehilling and so on. Oh and your welcome | |
10-09-2008, 01:12 AM | #36 | |
thanks. | |
10-09-2008, 02:45 AM | #37 |
Pebble Pounder Join Date: May 2008 Location: In Hendertucky
when i bought my edge chassis from TCS, I also got the edge hardware kit which comes with internal shock springs to convert your stock axial shocks into internal spring shocks (Droop set up) but it still needs addition springs to go into top part of the shock body just under the shock cap. home depot also sells a bag of assorted springs... try doing a search, I once saw someone posted up pics on how to assemble your shocks for droop set up.... |
10-09-2008, 09:19 AM | #38 | |
It moves in 3 planes, Up & down, side to side & for & aft. I am really suprised that this hasn't gotten more replies. With the amount of rigs running droop here on RCC & the high # of them that I've seen not working for sh!t, it's suprising. Last edited by rckjeep; 10-09-2008 at 09:22 AM. | |
11-03-2008, 02:04 PM | #39 |
Quarry Creeper Join Date: Oct 2008 Location: A little town called Dallas
Just got an AX10 and trying out the droop suspension. Should the shocks be bottomed out while resting? Im running them with 30w oil in the stock Axial shocks now.
11-03-2008, 02:23 PM | #40 |
Quarry Creeper Join Date: Apr 2008 Location: Racine
My advice would be to head to your hardware store and buy a few different types of compression springs. I got about a dozen of them for just a little over $5 and was able to play with different lengths and stiffnesses. I settled on a slightly longer and stiffer (dirty) spring in the rear and shorter and softer in the front. Works awesome!
