11-01-2008, 07:19 PM | #1 |
Rock Stacker Join Date: Oct 2008 Location: Oceanside
| Attaching the links inboard?
I did a search and found a photo that showed the bottom links inboard on an AX-10. Unless the full kit AX-10 has a different bottom (skid) plate than my ARTR, it looks like all this person did was cut out the first link mounting hole in the bottom plate and some of the plate itself and move the link inboard with appropriate screw/nut hardware through the first side frame hole. Then they used a small pan head screw to keep the bottom plate attached to the side frame using the 'second' side frame/bottom plate mount hole...Have I got this right? If not, would someone please enlighten me...:-P
11-01-2008, 07:34 PM | #2 | |
Double triangulation is best IMO. | |
11-01-2008, 10:36 PM | #3 | |
I would suggest this though: http://www.tcscrawlers.com/TCS-Crawl...n-p-16695.html It includes all the hardware you need to move the links in at the axles and gives you a new Delrin skid which is much slicker than your stocker. | |
11-02-2008, 01:39 AM | #4 |
Quarry Creeper Join Date: Aug 2007 Location: Morrison Crawlerado
| Is that a dig setup I see on the rear driveshaft? Is it homegrown? Looks interesting.
11-02-2008, 05:51 AM | #5 | |
11-02-2008, 07:19 AM | #6 |
| Yes,I had the coupler built for me a good while back and built the steel drive shaft on the axle side myself. It did work pretty good for a long time. I think something wore out or out of adjustment. I can't seem to get it working smoothly like it used to. I'm designing a new tranny mounted dig right now,so it'll be ditched before to long.
11-02-2008, 07:48 AM | #7 | |
11-02-2008, 08:08 AM | #8 |
11-02-2008, 10:03 AM | #9 |
Pebble Pounder Join Date: Dec 2007 Location: Arvada
i have already moved my link in-board and works well only thing is i seem to have more "axle steering." is there any way to help stop this. it's not bad but i did notice it after i swaped it.
11-02-2008, 10:38 AM | #10 |
Rock Stacker Join Date: Oct 2008 Location: somerset va.
raptorman57 on your rig do you have spacers between the link and side plates?. i like the look of your double triangulation and would like to do that on mine.
11-02-2008, 02:08 PM | #11 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
i did something similar buy cutting the stock trans skid and moving my links inboard ... don't know how to post a pic but have a pic of it on my my space page
11-02-2008, 05:07 PM | #12 | |
On the uppers? No,the rod ends are bolted straight to the plates. Lowers? No,the bolts run through the plate,through the skid and then through the rod end. | |
11-02-2008, 05:21 PM | #13 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
i'm surprised that no one has referred to this thread yet: http://www.rccrawler.com/axialcompbuild.html Narly1 |
11-02-2008, 06:22 PM | #14 |
11-03-2008, 09:52 AM | #15 | |
Quarry Creeper Join Date: Feb 2008 Location: Mount Holly
