Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Homebrew chassis help
Old 12-05-2008, 08:01 PM   #1
Question Homebrew chassis help
Hi there, I was in the process of building a chassis and before i start punching holes in this baby just wanted some idea's, thaught's or coment's(good or bad!). Should be able to use stock axial shocks in partial or full droop or 4'' shocks sprung or partial droop. Gonna have to use 95mm upper links and stock lowers for a 12 1/2'' wheel base. Chassis measures 2 7/16'' x 7 7/16'' and should give me about 2 1/2'' - 3'' ground clearance. Should only end up being 2 1/2'' wide...
bighitbomber1 is offline   Reply With Quote
Old 12-05-2008, 08:07 PM   #2
Looks prettygood so far. Round off the lower edge of the chassis to prevent hangups. I would also plan on making a strut for your shock mounts. Run between your shocks. I use 1/4 dia aluminum and screw thru your shock directly into it. Therfore you will eliminate the flex that you encounter.
TK-twister is offline   Reply With Quote
Old 12-05-2008, 08:24 PM   #3
Thanks, I wouldn't have thaught of rounding the bottom edges...makes sense! As for the struts i plan on re-using the old stuts off the ax chassis. I'll probably end up using two on the shocks and two in the middle of the chassis....should be solid!!
Old 12-05-2008, 08:27 PM   #4
I have my current chassis at 2 3/4 wide inside the plates and it is very tight. The axial tranny actually pokes through on the drive shaft side to get the motor to fit. Be sure to mock up with tranny before wasting some time on the skid plate.
Old 12-05-2008, 08:36 PM   #5
Cool, Thanks for the info!! I was actually gonna wait until I tore down the ax before I made the skid since it only took about 2 hours to make the chassis with a hacksaw and files...What kind of chassis are you runnin? Don't suppose you have any pics just to give me an idea?
Old 12-05-2008, 08:40 PM   #6
Tk Twister Chassis
Tk Twister Chassis
I have 2 styles for sale right now. Here is one of the builds. I am going to do the smaller chassis for my boy this weekend. hope this helps you get rolling sooner
Old 12-05-2008, 09:04 PM   #7
Tk Twister Chassis
Tk Twister Chassis
Wow!! that is a very nice setup! Thank you very much for the help I think I'm still going to try to squeeze it all into a 2 1/2'' wide chassis....we'll see how it goes! might have to cut out the side a little more... I was just outside and we have some freezing rain so I'm gonna have to go and do some ice crawlin!!! I've been waiting to test the new studded tires Thanx again for your help. I sure appreciate it
Old 12-05-2008, 09:06 PM   #8
Any time
Old 12-07-2008, 01:49 PM   #9
Well, here it is!! All done exept for the skid plate...waiting to get my hands on some delrin. Ended up with 3'' ground clearance and 3/4'' shorter than stock. It's still 2 3/4'' wide with the original skid but I think that I can squeeze it down to 2 1/2'' wide. It will be like tryin to squeeze a watermelon through a garden hose but I'll make it happen!! Still have the ax shocks in partial droop on there and it gave me about 55 - 60 degrees of articulation so me thinks I'll be puttin the big bores on there to tone that down a little! Anywho here's some pic's
Old 12-07-2008, 02:06 PM   #10
Nice work
Old 12-08-2008, 02:33 PM   #11
Holy moly.... I found my angle finder today and slapped it on the rig and it's actually getting 82* of articulation Definately need to reduce that some!! That's a far cry from the 55 - 60* I thaught I was getting!
Old 12-08-2008, 02:44 PM   #12
Originally Posted by bighitbomber1 View Post
I see studded rock lizards... show me more .
BuzzKilla is offline   Reply With Quote
Old 12-08-2008, 03:01 PM   #13
Sorry, forgot the articulation pic!!
Old 12-08-2008, 03:10 PM   #14
Yeah' that's the only good thing these tires are good for IMO!! Next time i go out ice crawlin (waiting for the river to pack up) I'll try to remember the camera! FYI it took 212 #6x3/8'' sheet metal screws...and they work awsome!! I think I'll re-name them "The Ice Killa's"
Old 12-08-2008, 03:58 PM   #15
why didnt i think of doing this.... i got piles of snow and ice in my back yard just building up as i type...
and a bucket of screws about that size too
Old 12-08-2008, 04:17 PM   #16
I think it's a must have living in the "Great White North" eh!!
Old 12-08-2008, 10:13 PM   #17
im on toronto... i think the smog and polution keep the snow away:-(
i wish we had what you guys get
Old 12-11-2008, 02:23 PM   #18
Well, installed the big bores in partial droop with shaft extensions and it braught me back down to around 45 degrees...mo betta!
Old 12-11-2008, 03:46 PM   #19
Looks great and great looking studed tires I think I am going to try this on my rock lizards. Good idea on bringing that angle down a bit!!
moabax is offline   Reply With Quote
Old 12-14-2008, 09:19 AM   #20
Nice rig, does the steering work good like that?
Smewhtguy is offline   Reply With Quote
