01-03-2009, 11:43 AM | #1 |
Newbie Join Date: Nov 2008 Location: Marysville
| CKRC FT Dig help.
Just wondering if anybody else has had the headache of installing the CKRC's FT Dig? Better instructions would have helped a lot! I'm new to crawlers, but I've been doing RC stuff since I was 8 (I'm 35 now) and I've never had a tougher build. After making several "mistakes" (where instructions would have helped), my out drive is now completely rounded off. I'm not running brushless, just a 55 turn. I had to do more mods then they described on the web instructions. I even had to grind down one side of the servo mount because they didn't supply a longer screw. Just venting and bitching, but I would like to know if I'm alone here or have others had a similar experience? Thanks. |
01-03-2009, 03:02 PM | #2 |
01-03-2009, 03:14 PM | #3 |
Harvo's thread has some great info in it. it can be fustrating but with a little time and some adjusting this is a very durable Dig unit. If your having problems with the outdrives, they will wear because its a hollow soft aluminum, then I would recommend these. http://www.ckrccrawlers.com/shop/ind...oducts_id=1590 |
01-03-2009, 05:07 PM | #4 |
Pebble Pounder Join Date: Mar 2008 Location: yes
Don't complain. I didn't recieve ANY hardware or a servo mount.
01-03-2009, 05:12 PM | #5 |
Quarry Creeper Join Date: Nov 2008 Location: Roswell
i finally got mine all figured out, but it isnt an easy install. i guess the only way the CKRC dig would be called easy is if you decided to purchase another and install it. my servo mount required some brute force and persuasion to install, but after it all it works fine. but i did upgrade to the cromoly outdrives, which i thought were advertised as a direct fit, but i had to file the outdrive down to 3mm to get it to work also
01-03-2009, 06:22 PM | #6 |
Quarry Creeper Join Date: Dec 2008 Location: fairfield
talk about mission impossible. that was the hardest thing to figure out on my crawler. took me about a half hour just to figure out how damn thing went together "properly"
01-04-2009, 11:15 AM | #7 |
Thanks everyone for making me feel a little less stupid. I'm still trying to decide if I should buy the chromemolly outputs from CKRC, or if I should just buy the RC4WD one from TCS that already has a new outdrive and looks like better bushings. Decisions, decisions.
01-04-2009, 11:26 AM | #8 |
Once you get everything sorted out the dig works great, but it requires much elbow grease and a little cursing beneath one's breath to get it installed
01-04-2009, 11:36 AM | #9 |
Rock Crawler Join Date: Nov 2008 Location: Roseville,Ca
I didnt get the servo mount or linkage kit with mine I had to call the shop repeatedly until I got hold of someone to get it sorted out after that I did have to shim the 2 plates to keep it from binding but it does work very well now.
01-04-2009, 05:57 PM | #10 |
Just get the chromoly out drives and you won't need to bother with it anymore. |
01-04-2009, 06:46 PM | #11 |
Newbie Join Date: Apr 2007 Location: Boston
i just finished building my Ax10 and was thinking of doing this Dig kit but now im having second thoughts. Is it going to be more trouble than its worth? Does anyone have more pics of the install and the dig?
01-24-2009, 09:36 PM | #12 | |
Pebble Pounder Join Date: Nov 2008 Location: Marysville, WA
01-24-2009, 11:05 PM | #13 | |
Newbie Join Date: Jan 2008 Location: Lemoore
I need a new out drive as well. Don't buy CKRC's. You see, CDW (see bottom link) used to make them for CKRC. But they found a cheaper maker. Cheaper maker uses cheaper materials. CKRC is unfortunately still using CDW's photo. RPP sells for CDW as well http://www.rccrawler.com/forum/showthread.php?t=128092 | |
01-25-2009, 12:13 AM | #14 | ||
Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
| Quote: Quote:
Nice write ups. So without those green spacers, is the lock plate not tight enough? Are the allen screws too long or something? Also, is loctite recommended at all for any parts of the dig? | ||
01-25-2009, 12:17 AM | #15 |
locktite anything that isnt supposed to move
01-25-2009, 12:57 AM | #16 |
Right on. I figured as much. I didn't see it mentioned but I might have missed it.
01-25-2009, 03:29 AM | #17 |
Yes the screws are too long and they will dig into the plastic tranny housing. The little green washers help with that. |
01-25-2009, 07:23 AM | #18 | |
Quarry Creeper Join Date: Dec 2008 Location: Route One
:-Pmaybe a little late now but my friend bought the FT dig and with the screwed up maching from factory etc, no instructions and no hardened steel output = more greif than its worth. Get the HR dig for $44 Install and run it! No phone calls or emails nessesary The cromo outputs you will need with the FT dig are like $30. $14 more dollars and you get a kit with everything you need minus the instructions, and thats what this forum is for! right? | |
01-25-2009, 10:07 AM | #19 |
01-25-2009, 08:04 PM | #20 |
| I think they are just grabbing screws from a central parts bin at the factory, because I have not seen one FT dig that has the same screws in CKRC's pictures! I put my post up on there product review. But they won't post it. They don't even post positive remarks. I hate to say it, but CKRC is gettin' shaddy. |
