01-12-2009, 03:35 PM | #1 |
Pebble Pounder Join Date: May 2008 Location: Philippines
| 3 racing dig http://www.3racing.hk/products.php?products_key=3399 is it okay for the price? does it look ok? check the link |
01-12-2009, 03:49 PM | #2 |
Pebble Pounder Join Date: Dec 2006 Location: San Diego
for that price you'd be better off buying a hot racing dig or a DNA
01-12-2009, 09:10 PM | #3 |
Rock Crawler Join Date: Nov 2008 Location: lakeside
i would second that.
01-23-2009, 04:02 PM | #4 |
Rock Stacker Join Date: Dec 2007 Location: A Mile High
Picked one up today, very solid unit. Nice and open allowing for just a touch more space also, as fit can be an issue. Aluminum driveshaft included, very nice touch. Going to install in a while. It is also cheaper then dna. Very impressed so far.
01-23-2009, 10:15 PM | #5 |
Pebble Pounder Join Date: Oct 2008 Location: Fresno
Do a nice review on it please. I've been curious about it and noone seems to have actually tried it yet and posted up about it's functionality.
01-24-2009, 01:58 AM | #6 |
how much did you get it? does it include the graphite servo plate? |
01-24-2009, 07:35 AM | #7 |
I like the dig collar idea and this looks good. It keeps the cog lower but with the R2D II and the Losi tranny coming out I think it's worth going for front and rear dig. Shaftys got some catching up to do with the MOAs and dig on both ends only makes sense to me.
01-24-2009, 09:46 PM | #8 |
Newbie Join Date: Oct 2008 Location: Australia
Installed mine last night fits sweet easy to use and very well made it came with every thing you need servo plate, servo linkage & alloy drive shaft.:-P The only thing i can say against the kit is its made for a stock height AX10 my AX10 has a lowered ride height and the supplied drive shaft bottoms out if the dig is in the lock position and articulated. No biggy generally your on fairly even ground when the rear is locked. Tried the RC4wd R2 tranny with a dig and its was a pain to set up & kept getting locked in the engaged position this dig is definatly a better design. |
02-12-2009, 03:05 PM | #9 |
nichl: can you post pics and a short review of the dig. pls.
02-12-2009, 11:27 PM | #10 |
Newbie Join Date: Oct 2008 Location: Northbay
Put mine in about a week ago ran it at a comp this past sunday and it ran flawless.
02-13-2009, 03:57 AM | #11 |
Been running mine everyday for the last 5 weeks and have had no issues so far, very well made unit easy to adjust and not to bulky an all in one unit. Will work on a review and pics over the weekend. |
02-20-2009, 04:08 PM | #12 |
okay finally bought one for $43. ill post pics of it later when installed. cant instal it yet cause of the reciever not working. |
02-20-2009, 04:30 PM | #13 |
Rock Stacker Join Date: Dec 2008 Location: Calgary-Canada
I bought 1 of these digs along with quite a few others up here. Installed it correctly and right from the start,there were binding issues.It would not disengage from locked possition!I tried everything and still it wouldn't work properly!Took mine back to lhs and they returned it,along with every other unit they had brought in.I was told 1 out of 85 worked!! Bad design,I believe.I paid 90.00 for it.It looks good and is easy to install,but it didn't work worth a damn. Got me a dna unit,and with a little care when mounting it works sweet. |
02-21-2009, 03:53 PM | #14 |
Xblade: chances are that it was too tight when installed. i tried screwing the two silver post first and then slowly bolted it to the dig
02-22-2009, 05:51 AM | #15 |
Quarry Creeper Join Date: May 2008 Location: Clarkston
Iīm a little disappointed, too. After some sanding an a bunch of grease i almost got it working. What i really donīt like about it is the bearing. Itīs busted already. I think somebody wasnīt to easy on it pressing the bearing with the metalparts together.
02-22-2009, 08:25 AM | #16 |
Newbie Join Date: Jan 2009 Location: Brampton, Ontario
i've had one for about 2 months and it is a solid piece. it does require you to swap the tranny around and even though the dig had options for a micro servo, you need about 44oz of torque. i use a hs-625mg, does a great job. you will need to purchase a smaller servo arm, i had an extra one from a kyosho mini inferno 09 and it worked like a dream. fitting is an issue as i had to relocate esc and rx, but worth it.
02-22-2009, 08:29 AM | #17 | |
02-22-2009, 08:32 AM | #18 |
IRON MAN: nice. i just use a s3003 servo lying around. it fitted inside my chassis which is about 2.75 inches thin. but im still having problems with the servo horn being too long. il try to experiment on it tom. |
02-24-2009, 01:02 PM | #19 |
I'm shopping for a dig now. I'm looking for one that I will not need power tools ard heavy equipment to install and get working right (all of my tools are in storage and the Navy frowns on the use of power tools in the barracks :-(). Of the three digs I have taken a hard look at (DNA, FT, and this one), it sounds like this is the easiest to install and get it to work right. Any thoughts on this? Thanks. |
07-24-2009, 05:41 PM | #20 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
seems pretty good i might get one
