03-11-2009, 03:12 PM | #21 |
I would also like to add that putting some bent lower links on will help if you haven't already... that and a 4-link front and back will help out your suspension alot! How does the suspension react over the rocks... too slow for you? to fast? I found that the springs that come with the truck are too hard. I would suggest leaving the stock hard springs out back to fight the torque twist, and put some softer ones up front. Mounting your lower links inboard on the skid helps alot too. |
03-11-2009, 03:13 PM | #22 |
Rock Stacker Join Date: Dec 2008 Location: Memphis, TN
I got the kit and been running it stock since december. I ordered the 4 link plates and waiting for the swx chassis to come in stock on tcs.
03-11-2009, 03:18 PM | #23 | |
Do you plan on getting some new tires? Let me know if you need anything that is used... I have a bunch of stuff! | |
03-11-2009, 03:41 PM | #24 |
i will probably keep messing around with the stock tires until I go to a comp or something. where would I get the lower bent links?
03-11-2009, 03:46 PM | #25 | |
Chris at the Chop Shop has them. I have some that I would just give you, but they are for a chassis that is longer than the stock chassis. The cheapest way to do it would be to find a pic of how the bent links come, then get a hold of a brake line bender and try to get yours to look like that. axials other brands will bend them in the middle, but the majority of people use the ones like above. | |
03-18-2009, 01:35 PM | #26 |
I just put together my swx chassis with front and rear 4-links. I still have the stock shocks but will probably get the losi shocks sometime. Do I have to get new driveshafts because the stock ones are pinched over the skid plate or do I have to do something else to fix that? |
03-18-2009, 01:59 PM | #27 | |
search through this and see what you find... http://www.rccrawler.com/forum/searc...earchid=326768 | |
03-18-2009, 02:12 PM | #28 |
03-18-2009, 02:24 PM | #29 |
I would try to mount your uppers differently (maybe on top of the servo plate, or on the bottom of it) or maybe even try some longer rod ends? I'm thinking if you were to tilt your axles away from the chassis a bit, and maybe even limiting your shocks would fix the clearance issue. Does the shaft clear your skid when you compress the shocks? If so, I would limit your shocks by putting some hard fuel tubing or some spacers to get it low enough. By the way... what kind of clearance (with the wheels mounted) do you have underneath that skid? I would also look around to see if anyone else has had this issue.. I think this may be due to your long shocks though. YOu may want to ask a SWX driver. I'm a CDW driver |
03-18-2009, 02:30 PM | #30 |
i have to compress it about 1/4 inch to clear the driveshaft.
03-18-2009, 02:38 PM | #31 |
03-19-2009, 03:29 AM | #32 |
Quarry Creeper Join Date: Jan 2009 Location: Langley, BC, Canada
Just wanted to add my 2 cents. I picked up a Tekin FX-R and 55 turn motor combo, and I'd say that was one of the best big ticket upgrades I've done. Having smooth acceleration, one touch reverse, and a perfect brake are wayyyy to good.
03-25-2009, 07:47 PM | #33 | |
Rock Crawler Join Date: Jan 2009 Location: east bay
bingo!!! i first upgrades were shocks, got softers for the front and mediums for the rear but then one week later i went droop...go figure. | |
04-16-2009, 02:42 PM | #34 |
so.. what's next for this thing? Did you get those shocks in yet?
04-16-2009, 06:52 PM | #35 |
Pebble Pounder Join Date: Jan 2009 Location: Colorado Springs
i went to drop shocks and did 4 link on mine. i have had mine a week and loving it the next thing will be tires. also add some weight to the tires. i used the stick on wheel weights.
04-16-2009, 06:53 PM | #36 |
