03-09-2009, 06:43 PM | #1 |
Rock Stacker Join Date: Dec 2008 Location: Memphis, TN
| stock ax-10, now what?
I built a stock ax10 kit and I been having a good time with it so far. Now I might want to upgrade it a little. What is a good upgrade with the chassis or suspension. I'm looking for something inexpensive, I don't want to pay hundreds of dollars for a major upgrade. Any tips or suggestions will help. Thanks |
03-09-2009, 07:02 PM | #2 |
Yep, the kit is fun to biuld (and the only option when I got mine ) Cheap Mods: 4-Link: I'd recommend converting to 4-link, you can get 4-link servo mounts for around $10 each. Shocks/springs: recommend running about 10-15mm of fuel tubing in the shocks, you'll also want to get softer spings, around $10. Tires: If you are going to compete, get new tires (not so cheap though at $40). Here are a few things to start with. You might also want to look at getting shaft rings. Hit the rocks, have fun! |
03-09-2009, 07:23 PM | #3 |
Ok thanks, I'm looking around on the CKRC website for the ckrc ax10 parts they have. I don't understand the difference from 3 to 4 link setups yet or what it does. Anything to make my ax10 more competition ready I am up for it.
03-09-2009, 07:43 PM | #4 |
Quarry Creeper Join Date: Dec 2008 Location: Route One
| take it out and beat the snot out of it; in the process take mental notes of all the behavior you like and dislike then read the treads to fix each thing. you have a star or GET A STAR so check the classified section and vendor section. IMO your first mechanical upgrade should be your frame. Then shocks. For now I would limit the shock travel with fuel line like Greatscott said. Most importantly, learn from others mistakes....most of them are posted here so read on, but first you have to beat it up your rig!
03-09-2009, 08:01 PM | #5 |
Rock Stacker Join Date: Feb 2009 Location: wichita
def 4 link and shocks springs..
03-09-2009, 08:05 PM | #6 |
Quarry Creeper Join Date: Oct 2007 Location: Toronto, ON. Canada
03-09-2009, 08:23 PM | #7 |
Pebble Pounder Join Date: Dec 2008 Location: uhh,,, i forgot
i know this may be out of your reach but i would recommend a swx chassis, big difference in performance , and limit your stock shocks with fuel tubing for now
03-09-2009, 09:18 PM | #8 |
anything under $125 is reasonable, is the swx chassis a good competitve upgrade and do I have to change anything else to install it?
03-09-2009, 09:21 PM | #9 |
Quarry Creeper Join Date: Aug 2008 Location: back where I belong
for your money the best bang for your buck is tires. or a good steering servo.
03-09-2009, 09:30 PM | #10 |
Newbie Join Date: Mar 2009 Location: st louis
Hey go to ckrc crawlers and get the stage 2 kit. Its $29.99 or $39.99 w/bent rear links.
03-09-2009, 09:40 PM | #11 |
everyone thanks for the advice, I really appreciate it. I might go with that CKRC stage 2 upgrade kit with bent links and the swx chassis kit if that sounds good.
03-09-2009, 09:57 PM | #12 |
That will be awesome. |
03-09-2009, 10:03 PM | #13 |
dont think the ckrc thing will work with the swx...
03-09-2009, 10:04 PM | #14 |
I have a axial ax10 scorpion, If I want to make my machine sit lower will the droop shocks work, and how do I make them droop.
03-09-2009, 10:21 PM | #15 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
What you really need to do is use the search button, and look at the build threads to determine what you want to do. There are many things you can do now with your AX10 that cost little, or you can spend thousands and have a full blown comp build. Search and learn, then decide.
03-09-2009, 10:27 PM | #16 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
Upgrades I recommend 1. Losi Shocks about $64 at your LHS 2. SWX Chassis 69.99 at TCS 3. HB Rover (White Dot) Soft, Losi Rock Claws or Panthers $14 to $18 a pair 4. Mamba Max ESC look on ebay or the for sale section here 5. New Motor depending on model $17 to $60 6. 4 link. TCS Boomerang is $6.99 at TCS These are not in any particular order. SWX chassis is a nice upgrade also buy some thread lock for the plastic shocks if you want to use them for a while. Tires and weights will make a big difference on how your rig handles on the rocks. 4 link will help alot with Torque twist. Mamba ESC is completely programmable which is a good feature. Losi shocks are a really good investment. a new motor such Banzai, Holmes Hobbies or Integy is a good upgrade later on down the road. Last edited by treday619; 03-09-2009 at 10:34 PM. |
03-11-2009, 02:10 PM | #17 |
Does anyone know when the SWX Chassis will be back in stock at TCS? I contacted them on the website but havent got an email back yet. They sell it for $69.99 which is the best price I found so far.
03-11-2009, 02:51 PM | #18 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
| For questions like that if they don't email you back quick enough make a post under the TCS section of the Vendors section here. All of the ones listed are great vendors, and alot of times will reply to a question in their section even before they answer an email on it. Most of the time from what I've seen if TCS is out of something they don't stay out of it long though.
03-11-2009, 02:56 PM | #19 |
ok thanks
03-11-2009, 03:01 PM | #20 |
Have you done anything to it yet? did you buy the kit or RTR.. or ARTR? The first mod that ANYONE should do is to re-locate the battery to a lower spot. Usually this means that you will have to find a 6-8cell 2/3A split pack to mount on your front axle. Chris at the Chop shop can make you one for about $25, or you can make your own. next would be tires. the stock tires are terrible, and you will notice a HUGE difference when/if you swap them. I wouldn't worry about a chassis if you haven't been driving the rig for too long. I would learn the truck first. A 3-link is exactly like it sounds. There are 3 points on your axle that will stabilize it. A true 4-link will give your axle 4 points of stability. You know the Y-piece that connects to your axle? That will go away and each of those upper links will have it's own rod end so they can connect to the axle separately. Hope this helps, and please feel free to ask all the questions in the world. I look forward to seeing you at a get together or a comp in the future Last edited by helhedded; 03-11-2009 at 03:04 PM. |
